Old 01-15-2020, 03:50 PM #1
4runnerfiend's Avatar
4runnerfiend 4runnerfiend is offline
4runnerfiend will become famous soon enough 4runnerfiend will become famous soon enough
Smittybuilt 5.65 CFM compressor cheap right now
Cheapest I've seen them. Hopefully some people can score.
Normally these are 150-180.
https://www.amazon.com/Smittybilt-27...language=en_US
1999 SR5: ELocker Retrofit, 99 talls-tundra Billy/LC 8 wraps-FJ Billys, Rokmen lower links, rear swaybar delete, Savage skids, TruckShopSD Sliders, Eimkeith PHC, ARB diff breather, F/R DuroBumps, 285 BFG KO2, Doug Thorley Headers
4runnerfiend is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 03:55 PM #2
05knightrunner 05knightrunner is offline
05knightrunner is on a distinguished road
Has anyone mounted this compressor in their engine bay? Looking for set ups
05 Limited 4x4 - lift/ 33s/ etc
05knightrunner is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 04:05 PM #3
SeaDug SeaDug is offline
Real Name: Sean
SeaDug is on a distinguished road
Real Name: Sean
Look at @/overlandunderbudget on Instagram. He has it done and will be posting a guide soon.
SeaDug is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 04:18 PM #4
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
damn good price!!!
I got mine years ago for $130. that was the lowest I had seen it.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 04:43 PM #5
rickashay's Avatar
rickashay rickashay is offline
Real Name: Addison
rickashay is a jewel in the rough rickashay is a jewel in the rough rickashay is a jewel in the rough rickashay is a jewel in the rough
rickashay's Avatar
Real Name: Addison
Can't say enough good things about the PUMA PD1006.
Puma PD1006 3/4-HP 1.5-Gallon 12-Volt Continuous Duty DC Air Compressor
A little more money but having ran the ARB CKMA12, two separate ARB CKMTA12, and an old MV-50, the PUMA can't be beat for the value. It's as quick (or very very close) airing up 35's as the ARB twin and it's less than a third of the price. Still 100% duty cycle as well. Only downside is it's size but you can split the tank if it makes sense to mount it that way.
rickashay is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 04:50 PM #6
That would be sweet! not sure how water proof they are though.
Old 01-15-2020, 06:29 PM #7
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy will become famous soon enough Wedgy will become famous soon enough
Wedgy's Avatar
I almost bought the Smitty but most of the reviews on a 4x4 site said they died after 3 times and the warranty was useless. It look like the Hong Kong Freight model is the same. A lot of people in my friends Jeep club use the Tsunami Air on 35's and it's cheap.
12V 150 PSI Compact Air Compressor
MasterFlow Tsunami MF-1050 12 Volt Portable Hi Volume Air Compressor MF1050 | eBay
Smittybuilt 5.65 CFM compressor cheap right now-63184_w3-jpg
Wedgy is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 07:05 PM #8
I don't know about that. I personally know several people with these larger ones that have had them years with no problems.
Old 01-15-2020, 07:27 PM #9
nevada's Avatar
nevada's Avatar
mine is 5 years old now. still working great. the only real issue, the filter cap doesn't like to stay on. it would be a simple fix, if I cared to mess with it.
the master flow is closer to the smaller smittybilt pump. a bit less than half the output of this large one.
Old 01-15-2020, 07:46 PM #10
jross20's Avatar
jross20 jross20 is online now
jross20 will become famous soon enough
jross20's Avatar
What's this about them getting extremely hot?
jross20 is online now   Reply With QuoteReply With Quote
Old 01-15-2020, 07:56 PM #11
nevada's Avatar
nevada's Avatar
compressed air is hot. they will all do that. you wont want to touch the metal part of the hose, where it comes out of the compressor after airing up 4 tires. it will burn you.
that said, I have many times filled up my 37's, and 42s, and have yet to need to stop so it can cool down. it puts out so much air, the tires are up to pressure long before the pump could ever overheat.
Old 01-15-2020, 08:08 PM #12
yep they get hot. really hot. Pretty sure this one has a thermal cutoff. as to protect the unit from overheating and burning itself out.
Old 01-15-2020, 10:04 PM #13
jross20's Avatar
jross20's Avatar
Ah got it. Thanks for the clarification guys.
Is this unit a good choice to mount under the body or would a different one be better for that?
Old 01-15-2020, 10:07 PM #14
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold
Bumbo's Avatar
I kinda want two of them... put them in parallel for very fast tire fill speeds.
Old 01-15-2020, 10:40 PM #15
not sure if they are waterproof.. but I have heard of people mounting them under the hood. to each his own.
150-180 , cheapest , people , score , smittybuilt
4th gen ARB onboard compressor mounting bracket-CHEAP how to 4RunnerAquasport 4th Gen T4Rs 13 05-01-2020 09:15 PM
Cheap air compressor for off roading Majindan General Discussions 20 08-01-2017 07:07 AM
Smittybuilt MAGARMOR paulndot General Discussions 3 03-26-2017 11:55 AM
Smittybuilt G.E.A.R. KCcarguy 5th gen T4Rs 2 09-26-2011 02:33 PM
