Old 01-16-2020, 12:20 PM #1
apache67 apache67 is offline
apache67 is on a distinguished road
Cost to Install Bilsteins?
Hi Guys,
Looking to replace a set of stocker shocks with some Bilstein 5100s (5th Gen 4WD with KDSS). Just the shocks not the coils.
What is a typical cost to have a Toyota dealership install them?
I understand an alignment is recommended as well with getting shocks replaced?
Thanks much!
G
apache67 is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 12:29 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I did mine myself but I have seen rates around the $400-750 area depending on who you ask + about $100 for an alignment.
I would not have a dealer do the work only from a cost standpoint… it’s a pretty straight forward job and most any mechanic can knock it out.
Old 01-16-2020, 12:34 PM #3
Ouch! That's a hefty cost.
Put out a "feeler" for a good 4x4 shop in the SLC area.
Thanks!
G
Old 01-16-2020, 01:18 PM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by apache67 View Post
Hi Guys,
Thanks much!
G
ProDemand lists the labor time for replacing front shocks w/KDSS as 3.7 hours and rear shocks (w/o REAS) as 1.0 hours. Plus alignment. I'm not sure what REAS is either. Depending on your area labor rates can be $60 to $200 per hour.
Old 01-16-2020, 01:23 PM #5
phattyduck phattyduck is online now
XREAS is a linked shock system - it would add a ton of labor to the job (and would be deleting the system if 5100's were installed). Available on the 4th gen+ 4Runners and some other Toyota body-on-frame SUVs.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 01-16-2020, 02:48 PM #6
Real Name: Patrick
Real Name: Patrick
That looks like a nightmare lol thanks for the info. I would definitely be deleting all that.
Old 01-17-2020, 08:46 AM #7
Thanks!
cost , install , recommended , replaced , shocks
How much would my lift install cost cgill00 5th gen T4Rs 29 01-24-2019 09:53 AM
Cost ARB air locker install? dhatcher General Discussions 30 02-14-2017 04:12 PM
Getting ready to install Bilsteins 5100's....a few ?'s Border411 Engines / Suspension / Wheels / Tires / Audio / Accessories 7 08-28-2014 03:19 PM
Install cost question RandyDaytona 4th Gen T4Rs 5 04-23-2013 10:14 AM
Finished bilsteins hd shock install. WHORERUNNER 3rd gen T4Rs 10 04-11-2012 01:20 PM
