Old 01-16-2020, 05:29 PM #1
HiMiles HiMiles is offline
HiMiles is on a distinguished road
34x10.5R17 KO2s: tall tires, minimal work
I think these are a nice option for people looking to get a large tire on a 4Runner without cutting or body lifts, and I wanted to give my review.
I picked up a set of these to replace some 285/75R16 Milestar Patagonia MTs. They measure out at 0.6" taller on my 4Runner. No, they do not measure a true 34", but no tire measures true to label size, and most fall short of spec sheet size under DIY measurements.
They are noticeably taller than any 285/75R16, including the Patagonia MT, which is known for running large.
Pros:
  • A bit taller and wider than 255/85R16s
  • Narrow enough to run stock offset
  • Load range D (not E) and light-ish at 55lbs
  • Ultra quiet, great balance
Cons
  • Price. This is a big con: I picked mine up on sale for $1300 for a set of 5, but they seem to have gotten even more expensive.
  • Must run 17s
I've been running them for about 6 months, and I have cycled the suspension without springs in place. I do not rub with the following relevant mods:
  • Front pinch weld hammered totally flat
  • Fender liner remolded with heat gun
  • Trimmed front bumper valence
  • Relocated washer bottle
  • SPC UCAs on 'G' setting
  • Extended-travel King coilovers (slightly longer compressed length than OEM)
  • 5.25" rear DuroBumps (already added these for LC shocks)
  • 17" Tundra wheels with the same 15mm offset as OEM 4Runner wheels
  • No wheel spacers
HiMiles is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 05:33 PM #2
One more con: they (obviously) won't fit the stock spare area.
Old 01-16-2020, 05:35 PM #3
TCMach's Avatar
TCMach TCMach is offline
Real Name: Tyler
TCMach will become famous soon enough
TCMach's Avatar
Real Name: Tyler
Any front or back shots? I'd like to see the profile on the vehicle. I like a skinny tire it just isn't to be on my 4Runner. Also not many skinny 37s. My 80s plow truck runs 235/85 which are basically a 32 x 9.25 and they rock on that thing. Look real good too.
EDIT: I guess you kinda posted a back shot. Hard to see the tire profile though. Looks good from what I can see though!
My build:TCMachs build
2000 4Runner:Kings, 37s, lockers
2018 TRD OR:stock and staying that way
TCMach is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 05:43 PM #4
SeaDug SeaDug is offline
Real Name: Sean
SeaDug is on a distinguished road
Real Name: Sean
Pros:
Cons
  • Must run 17s
  • No wheel spacers
I just picked up some Hankook M/Ts in 295/75/16 (not quite the same size but close 33.8"~) last week and love them, just need to clearance more. Mind sharing more on that process?
edit: forgot to mention the biggest advantage, price. All 4 installed and shipped for $750
SeaDug is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 05:44 PM #5
This photo makes it really easy to see the tire profile on the vehicle
Old 01-16-2020, 08:31 PM #6
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
Almost got this size but Discount Tire didn’t have them as an option on their promo so I went with 285/75/17 (33.8x11.2x17). Similar areas required cutting but being a bit wider they are most likely not going to clear the factory uca like the 34x10.5 will. I’m running Spidertrax so mine clear with room to spare.
34x10.5R17 KO2s: tall tires, minimal work-0101275a-38cb-450c-975e-5b95377befbd-jpeg
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 03-19-2021, 07:50 PM #7
Max toy Max toy is offline
Max toy is on a distinguished road
Hi!
I want to buy those tires. They look verry nice. I have a 3 inch lift with OEM UCA. will I need to change uca to get the space I need to put them in place?
Thanks!
Max toy is offline   Reply With QuoteReply With Quote
Old 03-19-2021, 09:35 PM #8
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
Originally Posted by Max toy View Post
Hi!
Thanks!
285/75r16 rubbed the stock knuckle at the upper ball joint... I only had hem on to drive to the tire shop as they came on the Tacoma take-offs I currently have. Sounds like ucas could potentially solve this
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 03-20-2021, 06:13 PM #9
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
glad you're liking yours. i've got the slightly smaller 33-10.50-15 on my truck and believe that will be my last set of them due to the mediocre road manners (wandering). they're of course fabulous on rock. in my experience they are quite disappointing on wet snow and ice, despite their snow rating. they work pretty well in fresh snow for me. i've got a set of duratrac on my 4R, seriously love the ride, and think i'll go with those for the truck when the time comes to replace the AT/KO2.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 03-20-2021, 06:20 PM #10
snydmax's Avatar
Real Name: Matt
snydmax's Avatar
Real Name: Matt
The 265/75-16 are 32x10.50... did great on the ice and dry snow we had... garaged her once they started treating the roads... here in AR it’s not too often we get to play in the frozen stuff for more than a few hours.
The AT3ws on my f150 did not disappoint, but again, we’re usually lacking here with regards to winter driving opportunities
Old 10-02-2021, 01:06 PM #11
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Could you give an update on this setup? This tire seems to be the most reasonable way to get a tall tire under a 4runner without going nuts to accommodate it. Lightweight and it looks like there are a couple of 17 inch wheel options out there that get me around the same wheel weight as the factory five star 16 inch wheels.
My goal is maximum clearance and off-road ability without destroying what this vehicle is.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
285/75r16 , 4runner , measure , patagonia , taller
35x12.5R17? CODERNR 5th gen T4Rs 13 05-25-2019 01:46 PM
would stock tall 99 front/906 rear work? hassos 3rd gen T4Rs 40 09-25-2018 04:43 PM
35x10.5r17 chaentjens 5th gen T4Rs 10 08-02-2017 12:31 AM
FS - WA: Extreme mud tires - Simex Jungle Trekkers II 34x10.5x16 - $950 thelal For Sale: Suspension/Wheels/Tires 0 07-20-2014 06:08 PM
