Old 05-01-2020, 07:55 PM #16
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is a name known to all gamefreakgc is a name known to all gamefreakgc is a name known to all gamefreakgc is a name known to all gamefreakgc is a name known to all gamefreakgc is a name known to all
Real Name: Jerod
Originally Posted by 3RDGENGuy View Post
Hey guys. So I rotated the tires and cleaned the rear brakes. No signs of gear oil on the pads I didnít adjust them because my e brake clicks about 7-8 times didnít think it was ideal. The drums look fine no gouges. I am braking downhill and I get a severe vibration in the back. Happens at highway speeds when slowing down. It happened before all this btw. Any help would be great!
Thanks have a good weekend!
Do you feel the vibration in the steering wheel or the body (your chair)? If it's felt in the steering wheel it's the fronts, probably has pad print on it or brake residue buildup.
If you are feeling it in the body of the vehicle the rear drums need a good looking at. When the drum brakes are replaced the springs are also supposed to be changed, they might have been re-used. You might have to turn the drums too, any warping is hard to see by just looking at them.
'98 4Runner SR5 - 4x4 5VZ-FE Supercharged - 222k miles, JDM engine @ 221k
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
Old 05-01-2020, 08:26 PM #17
3RDGENGuy's Avatar
3RDGENGuy 3RDGENGuy is offline
3RDGENGuy is on a distinguished road
3RDGENGuy's Avatar
Itís definitely in the chair and more rear body the back end shakes. Very annoying! I will look into the replacing the drum springs and turn the drums.
3RDGENGuy is offline   Reply With QuoteReply With Quote
Old 05-03-2020, 03:43 PM #18
Real Name: Jerod
Real Name: Jerod
Before spending money on parts though, take a look at your driveshaft too. Worth ruling that out with some grease since that's cheap/free.
Old 05-04-2020, 10:31 AM #19
3RDGENGuy's Avatar
3RDGENGuy's Avatar
Iím starting to think the front rotors are warped again. I installed them in December. They were resurfaced but makes me wonder. I had an older Camry shimmy like that after highway braking. I will grease the driveshaft easy and free like you said
Old 05-04-2020, 03:43 PM #20
Bad Luck Bad Luck is online now
Real Name: Patrick
Bad Luck is a jewel in the rough Bad Luck is a jewel in the rough Bad Luck is a jewel in the rough Bad Luck is a jewel in the rough
Real Name: Patrick
If the steering wheel doesn't shake or vibrate when braking then the problem is your rear brakes. Most likely one or both drums are out of round.
2000 Limited V6 Auto E-Locker
Bad Luck is online now   Reply With QuoteReply With Quote
bad , calipers , hard , horn , replaced
2001 4runner tranny questions possible swap questions. Did search samario1984 3rd gen T4Rs 5 06-09-2017 01:27 PM
Sub questions Funner Engines / Suspension / Wheels / Tires / Audio / Accessories 1 02-04-2011 01:54 PM
some 3.0l questions sgtarky Classic T4Rs 4 12-22-2005 03:30 PM
New and have a few questions Jay 3rd gen T4Rs 5 09-20-2005 09:46 AM
Garmin iQue voice nav questions and Topo maps questions. Expat Engines / Suspension / Wheels / Tires / Audio / Accessories 2 04-11-2005 09:49 PM
