Old 01-17-2020, 12:13 PM #1
FrogginAround's Avatar
FrogginAround FrogginAround is offline
FrogginAround is on a distinguished road
Coolant Overflowing
I took the dogs to the park the other day and I stopped for beer on the way back home. When i came back out to the car coolant was leaking pretty solidly onto the ground. I got home and started freaking out. It was really hot and the reservoir was so filled it was overflowing. I started doing some research and really started freaking out. Head gasket is just what I need right now. The wife came home and said she topped off the coolant. She missed the markers and filled the whole thing up. I'm really hoping that's all it is. I'll check the radiator cap just to be sure it's not that. Any damage I should be worried about? Only drove about 30 25 miles. Thanks.
FrogginAround is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 12:31 PM #2
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
That's not gonna hurt anything. Pressurized system with too much fluid so it overflowed. If it hurt anything it woulda been a blown radiator hose or blown radiator etc. Wont do anything to your engine, pressure leaves through the point of least resistance in this case your overflow tank.
VernySanders is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 12:39 PM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
Was coolant boiling in overflow tank when you saw it?
The wife topping off the coolant is suspicious on its own.
I mean why?
Has there been a slow leak that would cause her to look and top off? Again, why?
If you cannot recall when the radiator cap was replaced, then replace it with a genuine Toyota cap.
Luck and enjoy the Runner.
2001 Limited 4WD - 324K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
Old 01-17-2020, 01:01 PM #4
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
My thoughts.
Why did your wife need to top off the coolant?
What prompted your wife to even check the coolant in the first place?
When she filled the expansion tank, did she look in the radiator? Was it full?
Your comment "It was really hot" doesn't go along with an over filled expansion tank.
Sounds to me like you are loosing coolant somewhere.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 02:32 PM #5
rallypoint_1's Avatar
rallypoint_1 rallypoint_1 is offline
Real Name: Bill
rallypoint_1 is on a distinguished road
Real Name: Bill
I had a leak a few weeks ago. Pressure tested the system and ended up being the water pump.
Donít guess at it. Pressure test it and check for leaks first. Just my $.02
1998 T4R SR5 V6 2wd Evergreen Pearl OME 880 Toytec 1/4" spacer OME 906w/OME20mm(10mmx2)spacers Bilstein 5100 BFG KO2 31's Satoshi mod 1.5" BL(Fat Pats)
My 4Runner build:
http://www.toyota-4runner.org/3rd-ge...8-sr5-2wd.html
rallypoint_1 is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 02:54 PM #6
I could see where it was overflowing from the reservoir. It didn't appear to be boiling in there. I meant it smelt hot but that was probably just coolant leaking down and burning up. The wife topped it off because she was doing it to her own car. She asked me if she should do it to the 4runner but I was busy building her a garden work bench and not listening as usual and just said sure.... that's on me.
Old 01-17-2020, 04:15 PM #7
phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold phattyduck is a splendid one to behold
Probably want to go check her car for the correct level too! Set them at the max cool level on the bottle.
Sounds like it just overflowed because the tank was overfilled. There needs to be significant expansion room in the tank due to normal volume changes while driving. The max heat in the system happens right after shutdown, so that's when you are most likely to notice it.
The engine bay always seems hot during/after running - I wouldn't take a 'feeling' of it being hot as a problem.
'16 Honda Odyssey
coolant , filled , freaking , home , started
V6- coolant not siphoning back from coolant overflow (not overheating) djtc 4th Gen T4Rs 19 08-28-2015 09:11 AM
Overflowing Front Differential Brveagle 3rd gen T4Rs 2 01-16-2015 10:33 AM
Dealer Coolant Flushed with Wrong Coolant? peebee 4th Gen T4Rs 34 08-23-2014 03:33 AM
Coolant Leak- Drivers side coolant manifold? Shibby! 3rd gen T4Rs 19 12-28-2012 09:37 PM
22RE headgasket 'reversal' - coolant in oil, then oil in coolant kompression 3rd gen T4Rs 0 09-20-2005 12:23 AM
