Old 01-17-2020, 12:52 PM #1
levee-11's Avatar
levee-11 levee-11 is offline
Real Name: Levi
levee-11 is on a distinguished road
levee-11's Avatar
Real Name: Levi
RS3000 and Power Lock Problems?
Hey everyone. I've had my 4Runner for about 5 months now, and everything works perfectly, but I'm having some issues with the power locks/security system. Recently, when I open my door, and start the truck and it's cold or raining outside, the locks will cycle over and over, sometimes for 1 second or two, and other times for 10-15 seconds. I dislike this a lot because I don't want to wear out the actuators for the locks. It only does it after I start the truck, I've read other threads where it happens randomly, but mines only when the truck starts up, and only sometimes.
Next, I was going over the service records from the PO and found that he took it in because the piezo chirper stopped working, and I was like, "It's supposed to make a sound when it locks? That would be so much nicer" So I set off to figure it out. Couldn't get it working, tried everything. I was convinced it was blown. Yesterday, I decided to poke around in the owners manual just to check it out, and I ended up reading the RS3000 VIP System owners manual, and realized you could turn on and off the chirper. I turned it on, and it worked! I was stoked, but today, I go to unlock it, and the piezo didn't chirp. I turned it back on again, and it didn't even chirp to alert that it's back on.
I really want this chirper to work, and want to fix the locks going crazy, so any help would be amazing, and if anyone could link me a wiring diagram for the security system that'd be awesome (I'm hoping it's not a wiring issue). Thanks!
levee-11 is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 11:07 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
This could really be a pile of little issues. My locks freaked out when I changed my doors on the one 4 runner. I actually had to adjust the lock rods in the doors to get that to stop. I really doubt that's your issue.
In the early years the security system was and add on. In the later years it was factory built into the rigs.
Maybe I missed it but I didn't see a year of truck specified.
I would thoughly check the drivers side door and the tailgate boots for broken wires. If you have a lock mechanism or a broken wire in the door jam it may explain the behavior.
Are your door light switches functioning properly as they to can cause issues with your alarm as well.
Old 01-18-2020, 01:38 PM #3
19963.4lsr5 19963.4lsr5 is online now
My chirp doesn’t work more than it does. I figure the driver/relay is burned out.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 01-18-2020, 02:01 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Quite possible. Lots of wear in the contacts.
Old 01-19-2020, 01:52 AM #5
levee-11's Avatar
Real Name: Levi
levee-11's Avatar
Real Name: Levi
It’s a 98. So I think it’s an add on. I’ll take a look at the wires tomorrow. Thanks for the help
Old 01-19-2020, 06:13 AM #6
Pj Benn Pj Benn is offline
Pj Benn is on a distinguished road
Subbed. New 98 4runner owner here too. My piezo only works when it wants to. I think when it doesn’t work The lights don’t flash either, but could be it was too sunny to notice. My door open interior light switch works. I’ll look at my wiring too. Hope it just piezo is worn out. Where is the driver/relay usually located? On the chirper?
Pj Benn is offline   Reply With QuoteReply With Quote
Old 01-19-2020, 10:45 AM #7
It is most likely on the circuit board of the alarm. It could be a chip or a relay.
If you know how to solder it’s really worth reflowing all the solder joints in the board.
Old 01-19-2020, 11:27 PM #8
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
The piezos die. It is a Floyd Bell M-80. Located in that tight space to the side of the battery and fuse box. It is wrapped in foam and zip tied to the hood cable.
Old 01-20-2020, 12:39 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes Pre to 2001 they are all add-ons. I could be wrong but I think the dealers were the ones that added them in. After 2001 the wiring is in the truck harness and are basically built into the vehicles.
Old 01-20-2020, 01:37 PM #10
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
@levee-11 I had the same thing happen after I got water in the alarm's "control" box under the driver seat. The locks would cycle and the car was immobile and the horn was ON. I took the box out, let it dry and plugged it back in. (I later cleaned it more thoroughly when I was able to get home).
Side-note: this happened after a hike near Wenatchee in the middle of no-where!
My piezo has "never" worked. I say never because randomly last week it chirped a few times while lock/unlocking the truck, then stopped again.
@T4R2014 Thanks for the Piezo info! Might just order a new one for giggles to see if it works again. It's nice knowing when it's locked since the alarm is armed and disarmed (locked/unlocked) by the same single button.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 06:09 PM #11
Funny I just disabled the auto lock feature this afternoon and now it chirps every time. It even chirped during the programming which I figured it wouldn’t.
Old 01-21-2020, 09:55 PM #12
Thanks would never have found it without this description. I expected it to be bigger and wouldn’t have thought to look inside foam.
I removed my factory bug deflector and it started chirping every time. I read someone else hood switch was causing a problem. If there is something that detects if hood is open or closed fully I guess that was my problem?
Old 01-21-2020, 10:20 PM #13
I ordered a new beeper, but since I programmed the auto lock feature off and since I did that my beeper has worked ever since. Funny.......
Old 01-22-2020, 01:43 PM #14
T4R2014's Avatar
T4R2014's Avatar
Confirm that the RS3000 is what you have. The Securikey system has a hood switch, but I doubt your truck in Oahu has it.
Old 01-22-2020, 05:58 PM #15
levee-11's Avatar
Real Name: Levi
levee-11's Avatar
Real Name: Levi
Interesting, I'll try that as I was thinking about turning the auto lock feature off anyways
chirper , locks , system , truck , working
SOLVED - How to disable RS3000 VIP alarm but retain remote lock/unlock? 4Runner4Leon 3rd gen T4Rs 3 12-10-2018 01:28 PM
Power door lock problems... johnsuttontn 3rd gen T4Rs 3 12-03-2011 05:38 PM
Power Door lock problems Whaturunnin4? 4th Gen T4Rs 3 01-27-2010 08:42 AM
'03 SE power lock problems kroney70 4th Gen T4Rs 2 02-07-2009 11:42 AM
Problems with an RS3000 System pw1981 General Discussions 1 06-18-2008 07:38 AM
