Old 01-18-2020, 04:31 PM #16
zwalker16 zwalker16 is offline
zwalker16 is on a distinguished road
Originally Posted by plcfcng View Post
I would pull the engine back out check the converter as described spin the converter it should feel very smooth as you spin it. If it feels ok change the converter seal reinstall the converter. When you go to set the engine back in when you line things up remember the converter holes need to line up with the flex plate I start with the matching holes straight down on both holes. A little grease on the pins and holes does help along with keeping the threads on the bolts clean. As It goes together it sometimes helps to lift either the front or the back of the trans to help with alignment using a floor jack. Using the bolts to draw it together should be done with caution. If it feel likes it's binding STOP and start checking for whats causing the bind.
You can do it
I didn't leave the motor in
Pulled it all out. Will check everything Monday and reinstall
zwalker16 is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 05:13 PM #17
When it’s in the right position it will go together with no gap. Then thread some bolts onto the bellhousing by hand and do your motor mounts.
My SR5 Build and Repair thread has engine removal and install.
1/2 , engine , guys , tips , transmission
engine won't start after Timing belt install audiness 3rd gen T4Rs 23 12-28-2017 02:17 PM
Extra engine bay fuses relay install octanejunkie 3rd gen T4Rs 17 12-19-2017 04:31 PM
Train horn install with engine mounted compressor?? Jason B 3rd gen T4Rs 5 02-02-2016 12:52 PM
Check engine + VSC/TRAC blinking after install baz Engines / Suspension / Wheels / Tires / Audio / Accessories 3 08-03-2008 08:14 PM
96 4runner 3.4 V-6 TB spacer install now check engine light pshred 3rd gen T4Rs 3 09-05-2007 12:20 PM
