01-18-2020, 06:20 PM
#16
Real Name: Tim
Real Name: Tim
Originally Posted by JZiggy
I have this irritating rattle that comes and goes in the passenger side of the dash. I know I have the take the dash out to deal with it... been putting that off for a while. I’d rather do a clutch job than that.
Come on Jordan, you haven't figured out that rattle is the Loose Nut Behind the Wheel?
01-18-2020, 08:03 PM
#18
Yes and gutentight didn’t fix it!
01-18-2020, 08:17 PM
#19
A leaking engine oil cooler gasket and water pump.
Having a place to wrench on it is my hang up.
01-18-2020, 09:52 PM
#20
Valve cover gaskets.
01-18-2020, 10:28 PM
#21
Building bumpers, full front suspension overhaul, manual hub conversion, redoing a lot of interior wiring, front brakes, etc. It's quite a list.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
01-18-2020, 10:33 PM
#22
Rear axle seals are leaking. Putting off doing them and rear axle bearings. Just don't have the time or money to do them right now in school.
2000 SR5 - Build Thread
01-18-2020, 10:58 PM
#23
-Replace driver side door lock actuator with new OEM Aisin unit
-Replace the oil cooler hoses (replacing them preemptively)
-Fix the heat/cold blend door actuator which goes complete bonkers in hot weather
-Replace LCA with new OEM LCAs and new camber adjustment hardware
Planning to knock this list out in summer.
01-19-2020, 02:39 AM
#24
Real Name: Keith
Real Name: Keith
Need but put off 'till timing belt time: Valve cover gaskets. Preventative: Fuel pump. Parts on hand soon: Heater hoses, heater valve, oil cooler water hoses.
01-19-2020, 12:46 PM
#25
Real Name: Brad
Real Name: Brad
Fuel pump and fuel level sender are sitting in boxes and are first on my list. Have and extended crank time and my gauge drops really fast. I can only get 13gal in at empty.
I've just spent $4k(more than I paid for my truck) on all new OEM suspension parts from McGeorge that need to get installed. Purchased all 4 ball joints, all 4 front and 4 rear control arms, steering rack, rack pressure lines and tierod ends, front and rear swaybar links and bushings, springs and shocks, and finally every single piece of hardware because of rust belt)). Chicago winter is forcing me to wait til spring. My truck rides like hell and has all original suspension(205k mi 20yrs old). Cant wait to get this done
Oh and those rusting rockers need to get addressed. Anyone have success with a body shop replacing rockers on a limited? I am comfortable doing everything except body work...
01-20-2020, 12:15 AM
#26
Power door lock switches... I guess I need see if I truly need that body ecu.
01-20-2020, 12:35 AM
#27
Originally Posted by brillo_76
Owning 5 3rd gens my list is too long to type.
How does one own 5 3rd gen 4R’s? I mean why would someone need...
*Looks over at the 75 different WWII uniforms I’ve collected over the years*
“ahem”
Carry on.
'98 4Runner Ltd 4WD.
A Ford might get you from point A to point B. But a Toyota will always get you home.
01-20-2020, 11:36 AM
#28
Last fall during my annual maintenance I discovered that the drivers front swaybar link had broken in half. Not noticing when driven, I just removed the 2 broken halves and moved on.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
01-20-2020, 01:06 PM
#30
One of these days I will:
Replace the axle seal on my front differential
Change the oil (assuming there is anything left to 'change') in said differential along with the trans and transfer case
Clean out my PS reservoir screen
Fix whatever it is in the passenger door that kills the stereo when I open the window
Would be nice to have a new vent door behind the back bumper so there wasn't always 4" of dust inside.
The tailgate latch could use some love, or at least some adjustment.
The rust. MY GOD the rust.
I got the diff lock actuator working last week at least. That makes me happy.
1997 4Runner SR5 4X4 5MT elocker.
2005 Echo Hatchback 5MT.
1990 Volvo 740 Turbo sedan.
1991 Volvo 740 wagon.
2000 Mercedes E55 sedan.
