Old 01-18-2020, 04:06 PM #1
AZSportRunner AZSportRunner is offline
Real Name: Shadi
AZSportRunner is on a distinguished road
Real Name: Shadi
02 Multi-Mode 4WD Grinding (OTF Only)
Alright boys I've got a weird one.
My 2002 SE has been an amazing truck for as long as I've owned it and I've never had any issues with the 4WD until now...
When engaging the AWD (shifter push button w/out center diff locked) the truck makes a terrible grinding noise that I can literally feel bringing the truck to a halt if I don't slow down.
Now here's the kicker, if I come to a complete stop and THEN engage the AWD it engages fine and I can drive around completely fine up to speed and stop no problem. The center diff locks up immediately (4H) and putting the trans in neutral and then placing the t-case into low range (4L) work as they should.
The only time the noise occurs is if I shift "on-the-fly" so to speak, Toyota says you can do this up to 55MPH but I can't do it even below 5MPH.
01 and 02 Multi-Mode Avengers Assemble
@infamousRNR @jgue467 @Bandit Runner @BigFishAllDay @blackhammer0331 @Mtns_Yo @derpiful @Road Bull @Tyler James Inc
Maybe even the illustrious and gone but not forgotten @4-Ripcord would like to make an appearance?
Could this be something as simple as needing to change gear oil in the t-case?
Both Front and Rear Diffs have fresh fluid. Actually come to think of it I'm waiting for ECGS to finish my new 4.88 3rds (True-Trac and E-Locker) however I don't think that is the issue considering once the truck is in 4WD it drives as it should.
Maybe this is a sensor issue? The grinding doesn't necessarily point that way but the condition it occurs under might...
'02 Sport 4WD in Thundercloud Metallic Grey
Eibach 3" Coils w/ Billy 5100's up Front & LC 9 Wraps w/ Tokico Shocks out Back, Shrockworks Skids & ARB Front Bumper, E-Locker Rear / True Trac Front, TBU.
Sitting on 35/10.5/17 Kenda Klever RT's w Pro Comp 05 Series Torq 17x8 Wheels
AZSportRunner is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 04:21 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Sounding like a synchronization issue. Like the front differential isnt spinning the front driveshaft. So when stopped it goes right in.
You have any odd mods like manual locking hubs or anything that can interfere with the normal operation of the differentials.
That's odd for sure.
Old 01-18-2020, 04:31 PM #3
Real Name: Shadi
Real Name: Shadi
Not sure how I forgot these crucial bits but:
T-case gear oil was done when the trans was rebuilt ~20k miles ago
Noise seems to be coming from the front (ADD malfunction maybe?) but I know drive line stuff is hard to pin down...
Going to have a friend try to engage it while I'm walking alongside the truck to see if I can confirm this.
Old 01-18-2020, 04:32 PM #4
Real Name: Shadi
Real Name: Shadi
Hi Brillo, no manual hubs or anything like that... Odd for sure.
Old 01-18-2020, 05:45 PM #5
Tyler James Inc's Avatar
Tyler James Inc Tyler James Inc is offline
Tyler James Inc will become famous soon enough
Obviously a synchronization issue.
I would start out by seeing how your front driveline is behaving during the grinding. Have someone else driving, and hang out the pass door to watch the driveline- in a wide open lot. Have them drive as slow as possible, as you REALLY want to avoid damaging anything by whatever is causing the mis-alignment. That might help you nail down if it’s an issue in the tcase or front diff. Both front axles are in, right? �� Electrical connections are secure on the ADD motor on the front diff?
You say it’s acts as it should in A/4WD- are you 100% certain of this? 100% certain there is drive going to the front tires? Obviously something isn’t spinning that is typically spinning while driving.
My 2001 SR5 Ultimate Thread
My OEM+ '97 Limited Thread *Sold*
Anti-Satoshi Member #1
Tyler James Inc is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 06:40 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am suspecting the ADD motor on the front differential not functioning properly. As the T case is functioning if you stop and shift into 4wd.
Old 01-18-2020, 06:46 PM #7
Real Name: Shadi
Real Name: Shadi
Hi Tyler, appreciate the quick response.
Both CV's are definitely in and all of the connections on the t-case and ADD motor/tube are connected. The t-case actuator engages immediately as does the ADD motor when stopped (the distinctive clicks are almost instantaneous).
Going to have a friend drive it while I hang out the side later tonight when I'm off work and check back in.
As for whether or not the front wheels are getting power... It certainly drives like it's in 4HI (heavier steering, more grippy, etc.) but I guess the only way to be sure is to get it off the ground and see if the front wheels spin so I'll go ahead and do that tonight as well.
Will update once I'm done.
Sent from my SM-N960U using Tapatalk
Old 01-18-2020, 09:45 PM #8
Road Bull's Avatar
Road Bull Road Bull is offline
Real Name: Ryder
Road Bull is a jewel in the rough Road Bull is a jewel in the rough Road Bull is a jewel in the rough Road Bull is a jewel in the rough
Road Bull's Avatar
Real Name: Ryder
Hard to say for certain. But from what you are describing, it sounds like when you are engaging AWD, something is moving, and something is at rest. The sudden introduction of movement to the "at rest" component is in conflict. But exactly WHERE that conflict is, is hard to say. But, my first guess would be either an actuator or a synchronization issue like brillo_76 mentioned.
I might take a look at post #3 here. It lists the section of the 2002 manual that goes through some inspection steps.
SOLVED 2000 limited stuck in awd/4wd, multi mode issues. Blinking 4wd lights
When was the last time you used your AWD and 4WD without issue? Has the 4runner had any service done between then and now? Just trying to narrow down what might have changed besides something going bad or seizing up.
2002 SR-5 in Millennium Silver.
Timeline>> http://www.toyota-4runner.org/3rd-ge...-timeline.html DEAD
2002 SR5 Changeling Build https://www.toyota-4runner.org/3rd-g...ing-build.html
Road Bull is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 11:38 PM #9
Real Name: Shadi
Real Name: Shadi
Road Bull, thanks for the FSM/thread link!
Going to borrow a multimeter from a friend and do some testing on the harness/actuator because come to think of it the last time I tried engaging the AWD on the fly was prior to the trans rebuild (done by a reputable local shop however it is an old truck with brittle wires). Not sure how this didn't cross my mind as it was the last major thing done to the truck.
I have used the 4WD (CD Locked) a few times since the rebuild but always engage it at the beginning of a trail head while stopped and have only done light trails to go shooting or to the lake since then.
I actually discovered the issue after it recently rained and I engaged the AWD while leaving my neighborhood just because the roads were wet and I hadn't engaged it in a while.
I'm off Tuesday so by then I'll have had some time to trouble shoot and provide a proper update.
Old 01-19-2020, 11:28 AM #10
Bandit Runner's Avatar
Bandit Runner Bandit Runner is offline
Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough
I agree with the above - sounds like a synchronization issue. Other than that, I'm no help. Good luck.
Bandit Runner, 2021 TRD Off Road Premium
Build Thread: https://www.toyota-4runner.org/5th-g...ild-2-0-a.html
Bandit Runner is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 03:38 PM #11
The standard j-shift transfer cases have a synchronizer in the shifting mechanism to get the front driveshaft up to speed when shifting on the fly (then the ADD engages to lock the front drive in).
I wonder how the multi-mode / AWD transfer case does this same function. With an open center diff, there would be nothing to get the front drive spun up to speed unless the ADD actuator locks first - but it couldn't do that because there is no synchronizer up there (just splines and a shift collar/sleeve).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
4wd , diff , grinding , noise , truck
2009 Limited V6 Multi Mode 4wd in 2wd mode JCSTEW 4th Gen T4Rs 2 09-11-2015 07:52 PM
Multi-Mode 4x4 Zulch_AW 3rd gen T4Rs 10 11-28-2013 09:05 PM
Multi-Mode in a 97 SR5 EmptyZ 3rd gen T4Rs 8 04-08-2012 09:18 AM
I rig has multi-mode, can I use reg. 4wd? Woodsie8 3rd gen T4Rs 19 12-22-2011 04:57 PM
V8 4x4 - Is Multi-Mode 2WD Possible? thirstyturtle 4th Gen T4Rs 5 04-08-2011 07:10 PM
