Old 01-19-2020, 02:44 PM #1
Big-Boy Big-Boy is offline
Big-Boy is on a distinguished road
Manual Transmission hard to shift after 1” body lift
Hello all, I just installed a 1” Toytec body lift. In the instructions and videos I watched I saw it noted that for an automatic transmission you may need to adjust the shifting linkage, but nothing for a manual.
Any advice? I’m a pretty noob YouTube mechanic who’s learning as they go.
Thanks for the help!
Big-Boy is offline   Reply With QuoteReply With Quote
Old 01-19-2020, 02:56 PM #2
FYI it only seems to be 2nd gear that’s an issue. Not hard to shift into per say. But has a much shorter throw than it used to and doesn’t quite seem “seared” into gear. Almost like it wants to pop out but it doesn’t.
Maybe it’s not a big deal and I’m just making it one but want to be sure.
Old 01-19-2020, 03:31 PM #3
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
I have a 5 speed and a toytec 1 inch body lift also. I do have a Hurst short throw shift though. Body lift shouldn't effect the shifting per say. The shift boot should have enough give. It could be coincidental, the symptoms you describe sounds could be syncro wear, providing clutch action is alright. Can try changing the gear lube with a fresh batch. Also the clutch cylinder and slave cylinder could be failing, but I swapped both mine and no change when I had your same symptoms.
2nd gear hard shift is a common syncro symptom, had one myself on another transmission. It also would pop out of gear from a dead stop if I did lazy quick shift into 1st, I'm thinking the gears were worn also. I just threw out the old 5speed and found a good one cheap and rebuilt it.
If the symptoms get progressively worse, time for a rebuild or swap out if you can find a good one.
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
Old 01-19-2020, 09:02 PM #4
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
The rubber boots on the Shifters are probably just sitting weird. Take the knobs off and pop out the trim piece and mess with the rubber around the shifter. Should be able to slide it down the shifter to compensate.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 01-19-2020, 11:30 PM #5
blonde1boarder's Avatar
blonde1boarder blonde1boarder is offline
Real Name: Andrew
blonde1boarder is on a distinguished road
Real Name: Andrew
When I put a 1.5 inch body lift on I believe I had to cut the metal frame that holds the rubber boots around the shifters. Same location. 2nd gear. I imagine you are right near the limit with a 1 inch body lift.
1997 4Runner SR5, Deckplate Mod, Eibach Coils w/ Bilstein 5100, Toytec Diff Drop, LC 8 Wraps w/ OEM LC Shocks, Custom Front and Rear Bumpers, BAMF Slider w/o Kickout, Tundra Brake 231 mm, Retrofitted E-Locker, Procomp 7089s with 35x12.5x17 Fierce Attitude MT
blonde1boarder is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 10:11 AM #6
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
how collapsed is your transmission mount?
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 01-20-2020, 11:32 AM #7
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
^^^THIS^^^
On mine, I think I might have slotted the mounting holes, but it's been years. I do recall having to deal with that shifter plate before it was all wrapped up.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
body , lift , manual , shifting , transmission
Transmission shifter very hard to shift dphflytyer 3rd gen T4Rs 5 03-09-2023 10:52 AM
Transmission hard shift from 1st to second.[Automatic] redneckstarterkit 3rd gen T4Rs 17 12-30-2020 08:54 PM
Manual hard to shift after warming up Timjtitus 3rd gen T4Rs 7 08-22-2017 02:51 PM
Manual tranny hard to shift when cold mudhead 3rd gen T4Rs 8 12-17-2009 10:39 PM
Manual Trans. Hard To Shift into 1st. RonGee Problems & Warranty Issues 4 12-11-2006 12:51 AM
