Old 01-20-2020, 09:55 AM #1
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 will become famous soon enough jgue467 will become famous soon enough
jgue467's Avatar
STUMPER: Added LED dash lites, Trac/VSC On if placed in reverse first
As the title says, I just swapped my dash lites to VLEDs, all good, nice Blue tone. Yet If I place vehicle into reverse and then D within seconds the TRAC/VSC lites fire up.
If I start engine and simple place into D (when no reversing is necessary), no dash lights. As soon as I place shifter into R, dash TRAC/VSC turn on.
I took the dash apart several times, double checking connections, connections on ECU under dash, all are tight.
Any ideas other than reverting to old style incadescent dash lights?
Previous to these new LED dash lights, TRAC/VSC would only come one when locking the center diff.
thanks for any advice.
2001 Limited 4WD - 320K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL
StopTech slotted rotors - Magnefine trans filter - In series trans cooler, Original: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and on and on. WooHoo!!
dash , lights , lites , place , trac/vsc
Reverse switch not reading on dash. yotaguy674 4th Gen T4Rs 3 05-10-2018 08:24 PM
TRAC OFF and no reverse Matt fe2o3 5th gen T4Rs 17 12-07-2016 12:38 AM
A little stumper Antpwr 3rd gen T4Rs 5 01-26-2011 02:09 PM
VSC/TRAC/CEL lites after checking fuses NCSCOTT Problems & Warranty Issues 0 03-30-2006 08:34 PM
Anyone ever added lights under the dash area? atomic punk 4th Gen T4Rs 1 02-18-2005 08:17 AM
