01-24-2020, 03:39 PM
#31
+1 on the 4XInnovations bumpers. I have them on both ends of my '99. They are 100% bolt on.
Small note, however - they have LOTS of large bolts holding them on with a 99+ 4Runner. They bolt on to a 96-98 4Runner as well - but they won't be as securely bolted in place because it uses the crash beam mounts that the 99+ trucks have. 96-98 trucks just have little replaceable crush cans on the end of the frame, held on by a single small bolt. The 4XI bumper can use that small bolt, along with the 2 larger 'side facing' bolts on the frame. But it's not quite as strong as the 99+ mounting.
My wife initially bolted hers onto her '96 with no frame mods, but after a bit we decided to make it a bit stronger. Took the bumper off, carefully cut the early style end off the frame, and then I used the flanges from my crash beam and welded those on in place. Now it bolts on with the full complement of large bolts (10 instead of 4).
01-24-2020, 04:07 PM
#32
Originally Posted by absalom
You'll be surprised just how useless a plate bumper is on- and off-road.
+1.
You can do amazing.. and I mean amazing.. things offroad with a 100% oem bumper (front or rear).
I've even seen people fab up winch mounts inside the 99+ fatlip bumpers, too.
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
01-25-2020, 01:39 AM
#33
Originally Posted by Iffykid
Just re looked at the 4Xinnovations
$175 shipping WTF
COB retired with more time than money anyone thinking about ordering one from the Minneapolis, Mn area and want to split gas money?
Originally Posted by MStudt
You also need to consider what your time is worth? You'll have to pick this up during the week unless you can arrange a special pickup on the weekend. If it's during the week are you going to have to take off work? Is wasting 8-16 hour of PTO really worth the drive to save $100?
Personally, I'd pay the shipping, and have someone deliver it to my door. I like saying my PTO days for real adventures. Not driving 500+ miles to pick up a bumper. Either way, you'll be happy with a 4x bumper! It's a great bumper for the price, and you can't pass up $606.
Mike
As previously stated in post #12 R E T I R E D
01-25-2020, 10:11 AM
#34
Real Name: Robert');DROP TABLE Students;
+1 for 4xI. I don't have one of their front bumpers but I have a rear bumper with a swingout and it is a fantastic product. Beautiful welds, perfectly square, and bolted on like a factory product.
They are HEAVY, so the shipping is reasonable for what it is if you ask me. Mine showed up on my front porch 2 days after it shipped. I'm pretty sure my fedex guy is plotting his revenge though...
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
01-25-2020, 07:48 PM
#35
Trying to figure the weight penalty. Can anyone tell me what the OEM bumper weighs?
01-25-2020, 10:55 PM
#36
I have the same question.
I am sure there is a slight weight difference between the 96-98 and the newer fat lip bumper which has more plastics included, I have read reference to 40lbs but not indicated which model year and I also looked at individual fat lip
components which indicated 20lbs for the inner and 36lbs for the out assembly for a total of 56lbs.
If it wasn't middle of winter and I wasn't so lazy I have considered removing mine and weighing just for personal knowledge, Weight is weight but I dont think a 50lb weight penalty would be all that unreasonable.
$606 sale price good thru 1-26-2020 I am still hoping to luck into a used bumper for a good price.
01-25-2020, 11:35 PM
#37
Still, adding front and rear bumpers will cost you around 100 pounds or more over stock. These things don't have a big payload capacity.
01-26-2020, 12:53 AM
#38
I just put an order in for the 4X Front and Rear bumpers
Anyone have preferences for which Winch to use? I'd like something that can fit easily inside that bumper w/o any mods or changes and of course won't fail when you need it. I'm also leaning towards synthetic, but am open to opinions. Most of my wheeling is rocks/desert (some forest, but in general I hate mud). Thanks!
2000 Limited V6 4WD | Factory Locker | 2nd Gen SC | NGK Spark Plug Wires | AEM Boost/AFM Gauges | Scangauge II | Sonoran Steel 1.2 Lift/Washer Reservoir | AirLift Rear Airbags/Wireless Compressor | 4XInnovations Front/Rear Bumpers | Schrockworks Skid Plates/Sliders | Warn 12k LBS Winch-Synline | LED Halo Driving Lights | LED "Satoshi Cover" Lightbar | Thermal IR Cam | BFG All-Terrain KO2 | Kenwood with Sirius/Garmin Nav and Surround-View Cam | Heated Seats | Lumbar Support | Blacked out Emblems TRD Badge | Rear Diff Breather Extension | LED Taillights | LED 6k Headlights | 120V Power Socket | Flipped Hood and Fuel Release | Rear Window Switch in Cargo Area | Custom FlipBlade Key | Warm White LEDs
01-26-2020, 03:38 AM
#39
And yet you see others adding bumpers trailer hitches, high lift jacks, winches, roof racks and or roof tents,air compressors etc etc.
Maybe I can loose 10lbs per side removing running boards.
01-27-2020, 11:17 AM
#40
And then drill lightening holes in the OEM bumpers!
01-27-2020, 12:11 PM
#41
keep in mind you arent accounting for the weight of a winch. i did a quick google search and the first result i found that actually had good info said 70-100lbs with steel cable, subtract 30lbs for a synthetic line. other responses seemed in line with this.
some quick and dirty math:
80-100lbs for bumper
70-100 lbs for steel wire winch:
150-200lbs bumper with steel wire. subtracting 30 from both ends yields 120-170lbs with a synthetic line.
subtract that from your 56lb # you got and we are left with:
94-144lb weight increase with steel line
64-114 lb weight increase with synthetic line.
again, just some quick and dirty math. but you can see how quickly the weight adds up; even with removing the 56 lb stock bumper. we havent taken other things that hang off the bumper (such as shackles, lights, or any hoops) into weight consideration so your end number may acutally be slightly higher.
99 4runner limited; imperial jade mica
IG: mesooohoppy
01-27-2020, 01:03 PM
#42
Obvious if you hang more shit on it its going to weigh more.
If you could add all the same crap to a stock bumper it would weigh more as well.
Heehawed back and fourth for several days and finally hit the order button a few minutes ago, Should find out if it was worth the $ in 2-4 weeks.
01-27-2020, 01:12 PM
#43
The early bumpers have no inner bumper reinforcement. What you see on the outside is what you get. The 99+ went to the fat lip to add 5mph bumpers (basically) to the structure, which required pushing the outer bumper forward.
So, for early 4Runners, there is a larger weight penalty for a plate bumper.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
01-27-2020, 01:31 PM
#44
well duh, thats how weight/mass works. i was merely showing that you dont just 'loose' the 56 lbs when removing the stock bumper and adding a winch and a plate bumper via some quick and dirty math. the weight adds up really quickly.
even with a synthetic line, the winch takes up all of the 56lbs you just lost and then some. and we havent even factored in the additional 80-100 pounds a steel plate bumper adds yet. the last potential issue you are introducing with all of the added weight is sag if you dont have the correct spring rate (more $$). thats why ive been in the market for a lighter weight minimalistic bumper that can take a winch. im probably limited to tube bumpers at this point, but i havent found one that looks good yet (IMO).
IG: mesooohoppy
01-27-2020, 02:57 PM
#45
Real Name: Jordan
Real Name: Jordan
Mstudt's point still stands. Burning that much windshield time pretending to be a UPS driver is a poor use of time.
I sure I'm doing more exciting things when I'm retired than couriering bumpers to and fro.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
