Old 06-18-2020, 07:07 PM #1
tgreenwood75 tgreenwood75 is offline
tgreenwood75 is on a distinguished road
Wiring a Late Model OEM Toyota Radio
Hey there,
I have read the numerous threads regarding putting a modern Toyota/Scion head unit with bluetooth into older rigs but have not come across the same problem I am having.
I have a 2001 4runner with the standard stereo and am hoping to swap in a radio from a 2012 Rav4 with bluetooth. I picked up the head unit off of Craigslist but cannot get audio to come out of it. The plugs (minus antenna of course) match up with the connectors that go into the factory amp. I removed the amp, and connected those two plugs to the back of the Rav4 radio.
The unit powers on and switches between functions without flaw but will not produce sound through the CD function, nor does it have all menu options when I press 'setup.' Am I missing a key step or component?
If helpful, I can photograph the unit I am installing, it is a model # 86120-0R130 out of a 2012 Rav4 Limited.
Thanks in advance!
tgreenwood75 is offline   Reply With QuoteReply With Quote
Old 06-18-2020, 11:15 PM #2
T.Tech T.Tech is offline
T.Tech is on a distinguished road
You need to remove the wire for the power antenna motor from one of the plugs and you should get audio. I just wired in a switch for the power antenna.
T.Tech is offline   Reply With QuoteReply With Quote
Old 06-19-2020, 07:23 AM #3
Interesting! Would not have guessed it...
You're talking the tan/salmon colored relay box with plugs on the bottom? I disconnected this box completely but did not know I needed to remove a wire. Can you give more detail on which wire and what you did?
Old 06-19-2020, 11:17 AM #4
I think it need to see an antenna.
There is a post in the audio section of that very problem. As soon as he installed his antenna adapter he had sound.
Old 06-19-2020, 03:38 PM #5
I believe I did the black and white wire pin#8 . You can try disconnecting the antenna relay first and verify first.
Old 06-19-2020, 06:59 PM #6
Thank you both for the input! I will get it all setup with the antenna adapters and see how it works then.
Hopefully the antenna was the cause of my problem!
Old 06-19-2020, 08:12 PM #7
Look in the audio section for a title with 2016 radio from southern bike. And read the last few posts from southernbike.
I’ll bump it to the top
Old 06-19-2020, 09:09 PM #8
Thanks @19963.4lsr5 , I had actually read that post but did not understand the phrasing and context of the problem until I ran into the same issue! Now that I've figured out exactly what I need, all additional adapters are ordered up and I should be set. Seeing everyone else's touchscreen setups is making me want to upgrade before I even finish this install!
Old 06-20-2020, 11:33 AM #9
I love the T1819 but wanted a dedicated NAV unit in the 4Runner. It also rocks better. (At least in my little Saturn SL sounds great with 4 6.5” 3 way speakers) And I had done all the work fitting the T1819. I ended up using a 2013 Corolla unit. Mainly because it had built in XM radio if I ever wanted to use that. The T1819 required a external module. Plus I couldn’t find the newer NAV units with the entune module.
I miss the call button the T1819 radio has that the NAV doesn’t. Plus you can’t make calls through the NAV if your moving.
Enjoy. It’s a great “mod” if you spend a lot of time in your rig. I spend 50min each way to work.
Old 06-22-2020, 05:03 PM #10
Got my antenna adapter plugged up and now have sound but still no bluetooth connectivity!
I was worried that this might be the case without running a microphone. I don't care about the microphone but want an audio connection. What harness do I need or what can I modify to allow bluetooth pairing? I know I stumbled upon one person who claimed they paired theirs by splicing some wires but not adding any additional cables.
Thanks again!
Old 06-22-2020, 05:14 PM #11
Thanks again!
There is a mod to have Bluetooth but I don’t know what it involves. The mic is only 54 dollars.
Old 06-22-2020, 10:09 PM #12
Thank you for all your help @19963.4lsr5
So it is the microphone itself that needs to be attached? Or is it the 28-pin harness?
In @Southernbike 's install, he used listed microphone PT546-00120-CH along with a 28 pin conversion harness. Will I need both of these? Could I instead link in a cheapo microphone like this (Amazon.com: Genuine Toyota Accessories PT923-00097-MC Microphone: Automotive) direct to the HU or does this go through the 28-pin?
Old 06-23-2020, 11:44 AM #13
PT546-NU160 is the mic I used.
The AD and CH harness adapters break out the antenna and MIC connections
Search for the Bluetooth mod if you do not want to buy the mic.
The guy at the end of the southernbike thread did the mod.
I use my phone in my car all the time so I bought the mic
That mic you posted may work if it’s got the same plug.
Old 06-26-2020, 05:19 PM #14
Today I discovered a different way to do the bluetooth mod. I did not have the wiring harness, so I made my own jumper wire to jump the microphone sensor to the microphone ground on the 28-pin plug.
Only took 30 min total and was free with parts and tools I had in my garage. The photos should exhibit what I did but I simply located the SNS2 pin for Mic Detection (pin 6) and the appropriate ground (pin 18) and looped them with a single wire. The wire was attached using connectors stolen from an RC servo and they fit stereo pins snugly. I crimped, soldered, then heat shrinked the connections to be safe. You could probably do it a more ghetto way as it is merely a signal wire but this may be a permanent fix for me.
The benefit was not spending $100 for a wiring adapter and microphone online and (for me) not waiting on them. As compared to previous mic mods, you don't need to cut into a $30 Toyota harness and it is more easily reversible because it does not require any parts or cutting.
Wiring a Late Model OEM Toyota Radio-img_20200626_073110-jpg
Old 06-26-2020, 05:20 PM #15
Pictures continued
Wiring a Late Model OEM Toyota Radio-img_20200626_092547-jpg  Wiring a Late Model OEM Toyota Radio-img_20200626_092255-jpg
amp , plugs , radio , rav4 , unit
Late(r) model OEM wheels on 1st Gens Redthies Classic T4Rs 8 01-22-2019 12:04 AM
Late Model FJ Cruiser Springs sportsterchop200 3rd gen T4Rs 0 04-18-2017 04:44 PM
WTB, 4th Gen, OEM late model LED Right Tail Light Assembly webby For Sale: T4R Items 0 12-30-2012 08:50 AM
Late model 4Runner rust ? alotawatts 4th Gen T4Rs 5 01-03-2006 04:08 PM
