10-25-2009, 07:48 PM
Registered User
Registered User
LED 3rd Brake Light DIY
I ordered a flexible LED strip from Oznium.com and made my own LED 3rd brake light using the existing bulb base and brake light housing. It's almost the same as the aftermarket LED 3rd brake light, but a lot less $. The 4.7" strip is $6.99 and nearly fills the length of the housing. I was hoping to fit more in there so I ordered the 9.5", but ended up having to cut it down to the 4.7" since the LEDs have to be cut in groups of 3. Easy DIY mod if anyone is interested!
10-25-2009, 08:20 PM
98 4Runner Limited,265/75/16 Hankook Dynapros, KMC XD Black Hoss Wheels, Hella 500, Tokico, PP 1" Springs, Optima Red 34R, K&N, JL, Kenwood
10-25-2009, 08:38 PM
Looks good...I like it!..
2004 -SR5 V6 2WD-Gold-
Front Adjustable Bilsteins Shocks/1.5 DS Backspacers,265/70/17 Firestone Destination A/T's,Eclipse AVN6000 Navi HU,Python Remote Start/Alarm,Wet Okole Seat Covers,Steelcraft Bullbar,Go Rhino HitchStep ...and more
10-25-2009, 10:31 PM
Nice I might try and do this too, so I can have full LED's in the back. I'm assuming no ABS light with this 3rd brake light? Also, what kind of rear deflector is that?
'02 Limited 4WD
Stuff:OME 3"|ARB Tacoma|Light Racing UCA's|Savage KO sliders|285/75 Terra Grapplers|TRD catback|TRD wires|Brembo'd|VVME 4300K HID|LightForce 170|Exterior LEDs||Inside: Infinity Comps/Kicker/Nuvi625WT|Uniden 520XL|15% tint|Full LED swap|Backup camera
Pending Install:LC80 wheels,OME 883 and LC 8 wraps,panhard drop
10-26-2009, 12:15 AM
Real Name: Bryan
Real Name: Bryan
i like! well done, sir!
Millennium Silver 2001 4Runner SportR5lander
Photo Timeline - Solid Axle Club
All-Pro, Fox, Eibach, OME, Goodyear, Trail Gear, Yukon, Solo Fabworks, Marlin, TJM, Smittybilt, Front Range Offroad, Inchworm, Addco, Savage Offroad, B&M, Borla, Pioneer, Cobra
Northeast 4Runner Owners Association
10-26-2009, 01:49 AM
looks pretty good im gonna make a custom one using 20 or soo useing real lumiled superflux led's
98 4runner sr5 3.4L 5spd 4x4 e-locker sold 10/2/11
07 tundra 5.7L 4x4 limited dc was my moms r.i.p 3/19/11
Oregon Toyota Owners Club
10-26-2009, 03:51 AM
Real Name: Taylor
Real Name: Taylor
pictars or shens when you do it
10-26-2009, 12:17 PM
Registered User
Registered User
No ABS light and the deflector is the EGR DustGuard. This one mounts with 2 brackets on the side and tape on the top so no holes or permanent mods required.
10-26-2009, 12:30 PM
Cool thanks for the info
'02 Limited 4WD
10-26-2009, 05:11 PM
Real Name: Taylor
Real Name: Taylor
do you have led's in your tail lights as well or are those still hallogen bulbs?
10-26-2009, 09:24 PM
Registered User
Registered User
No those are still halogen in my tails. No $$ for that upgrade yet
10-27-2009, 03:26 AM
Real Name: Taylor
Real Name: Taylor
did you put resistors in your 3rd brake light? if you didnt, most likely your abs light will be coming on if and when you switch to led tails
10-27-2009, 09:24 AM
Registered User
Registered User
No resistors. When I checked the resistance of the LED strip versus the resistance of a 921 bulb, the difference was so small I figured it would be negligible. IIRC the difference was less than 1 ohm. That reminds me that I was planning on measuring the resistances myself but completely forgot
10-30-2009, 04:12 AM
how did you mount the leds and wire it up? thanks
10-30-2009, 08:10 PM
Registered User
Registered User
The LED strip is mounted onto 2 "L" shaped brackets with 3M automotive moulding tape and the brackets are mounted the same way to the base of the brake light housing. The brackets are small, each leg of the bracket being approx. 3/4", and were actually speaker mounting brackets I had left over. The LED strip was pre-wired so I just cut the wire shorter to fit in the housing and crimped spade connectors onto the ends. I used the 18-22 ga. spade connectors and just bent them slightly to squeeze between the electrical contacts of the brake light bulb socket. The only thing removed from the brake light was the 921 bulb. Hopefully these other pics will help!
