Old 01-27-2020, 02:31 PM #16
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
My old 4AFE alltrac corolla pinged like a bugger. I started frequent sea-foam through the throttle body treatments and it improved a lot, really a lot. Mind you that car was at about 350,000 at the time. Likely very carboned.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 03:35 PM #17
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Originally Posted by phattyduck View Post
How many manual trans vehicles have you owned? I haven't owned one yet that doesn't want to be above at least 1800 rpm when accelerating. Stop lugging that thing around.
The auto will downshift if you get on the gas and will keep RPMs above 2k while accelerating. Even cruising, it is hard to get the ECU to shift down to 1500 rpm unless you are coasting. You should be doing the same with the 5-speed. Stop treating it like a diesel engine (assuming that's where you get your user name?). Gas engines need RPMs to work well - keep it above 1800 RPMs unless you are coasting to a stop (and yes, that means going above 3k rpm in 1st fairly regularly!).
Also, the knock sensor is ignored below something like 3k rpm. The engine still shouldn't be pinging down there though (well, without a supercharger). You might have carbon'd up cylinders or something. Try running 89 or 91 octane and see if the pinging goes away, then figure out how to solve the issue.
I think your confusing me describing a symptom(?) of my engines operation with me actually driving the vehicle is some manner. Just because I know my vehicle pings below 1500 doesn't mean that's the rpm range I typically operate it at.
I'm of the opinion that my engine isn't running as well as it should. I believe the pinging is a symptom of the issue. Also the engine doesn't seem as smooth around 1000 rpm as it should. Its smooth at 700 and smooth at 1200 but between about 800 and 1100 its a little rough.
I'll work may way through the normal PM items and expect to resolve the issue while doing so.
I have ordered the air box, resonator, and bellows to convert over to the 99+ style intake and will replace the MAF.
I have cleaned the throttle body but haven't removed the IAC and done a thorough clean. I have the IAC gasket and throttle body gasket on deck ready to do that.
I replaced the O2 sensor. The pinging seems to be reduced slightly, but right now I have the tank filled with Chevron premium and 2 bottles of seafoam so its hard to say.
I don't expect much from the Seafoam as I just installed this engine(JDM) and I cleaned the chambers pretty well prior to install. The other engine exhibited these same symptoms as well. I was hopeful they were related to the head gasket leaking coolant, but it doesn't seem so.
Due to having 2 engines exhibit the same symptoms I expect they are related to one of the components not changed during the engine swap.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 02-05-2021, 02:52 PM #18
sbrkwc sbrkwc is offline
Real Name: KW
sbrkwc is on a distinguished road
Real Name: KW
I have a similar setup as a daily driver (Pacific Northwest Region), with overland equipment mounted on it:
98 SR5 V6 Manual with OEM Rear E-Locker
226k Miles
3" lift
running just under 32" tires
-235/85R16 during non-Winter months
-265/75R16 during winter months for more traction
Just did an engine overhaul, and cleaned up anything that needs to replaced, did find the engine run smoother in higher RPM, esp in 2nd 3rd gear.
I estimate I have added roughly 200 lbs (front) and 300lb (rear) of overland hardware to the vehicle. Usually carrying 1 adult passenger on overland trips. I find my 4th gear is lacking power/torque, especially staying at 60mph uphill to the mountain and ski hill.
Considering/researching gear ratio change to 4.56, most of the discussion threads I read through talked about tire size, but not on weight and tire width..
Questions to the forum:
a) Wonder if anyone knows much about gear ratio on added weight and tire width ?
b) If choosing Nitro gear, any particulars I need to pay attention to ?
c) Anyone in Seattle area knows a good shop for re-gearing ?
KW
sbrkwc is offline   Reply With QuoteReply With Quote
gear , size , speed , tire , tires
Re-gear to what ratio? robbymartin 5th gen T4Rs 9 09-17-2018 06:38 PM
gear ratio Daniel0013 3rd gen T4Rs 6 09-24-2013 01:15 PM
4th gen gear ratio Falls 4th Gen T4Rs 9 03-01-2008 11:20 AM
Rear Axle 91 T4R 'Third Member' gear ratio scudsrus Classic T4Rs 4 11-02-2007 08:30 PM
gear ratio 4runnerhyde 4th Gen T4Rs 1 08-31-2006 01:19 AM
