01-24-2020, 04:48 PM
Real Name: Jeff
Real Name: Jeff
yep another 99 Talls question
do all 99s have tall coils? thought id read somewhere here that it depended on your manufacturing date?
ive searched and cant find anywhere.
I have a 99 SR5 date of manufacturing 12/98...do I have talls?
salt belt...no color codes left.
01-24-2020, 10:26 PM
"Highlander" models. Check out post #190 on this page for the part #s:
Absalom's Cookie Cutter 4runner Builds - New and Updated!
Luck and enjoy the Runner.
01-24-2020, 10:43 PM
Real Name: 3 Bears
Real Name: 3 Bears
Originally Posted by jgue467
like he said....only the highlanders and if you go to order springs, you have to specify that
also...last I checked...Toyota was phasing them out I guess because the highlander part numbers were superseded to stock #'s
I could be wrong...but that's what I thought I saw
01-25-2020, 09:40 AM
Real Name: Jon
Real Name: Jon
Dont be saying that. I just ordered a set of highlander springs.
01-25-2020, 02:14 PM
Real Name: 3 Bears
Real Name: 3 Bears
said I was not sure....last summer a friend was doing shocks and springs and he said he tried to order highlander sprigs by part number and they superseded
to stock 2002 springs....that's what he said
01-25-2020, 03:19 PM
I'm still finding lots in the junk yards. I am basing this off color code, not vehicle specs. I have had 2 sets myself (kept 1) and the last 3 junkyards I have been to each had a set. Pair them up with OME2906s and good to go.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
01-25-2020, 03:54 PM
Real Name: Jon
Real Name: Jon
Well I was at the point that my A/m springs were done. So if an inch shorter will be better then the 2.5 inch difference in my rear bumper from drivers side to passenger side.
01-25-2020, 08:46 PM
This is wrong. All '99 4WD with 16-inch wheels from the factory got the tall springs, including my non-Highlander SR5. Just check the colors.
Front Right Springs - Blue / Yellow (48131-35400)
Front Left Springs - Blue / Pink (48131 - 35350)
Both Rear Springs - Yellow / Red (48231 - 35210)
The color on the rear is sort of a sick greenish yellow, not a blazing lemon yellow.
That said, as someone who ran the '99s for 18 years, use OME 906s in back and the '99 Talls in front.
EDIT: I just saw where you (OP) can't see the colors. NJ is as salt happy as they come and I could see mine just fine. Maybe the PO painted the springs. Mine was built toward the end (03/99). I'm pretty sure if you have the locker and 4WD you got the Talls. The 15-inch springs were pretty short, you should be able to just look at it. Post a pic....
My Backyard Frame Swap
01-27-2020, 10:21 AM
I can also confirm that my parts truck, a 99 SR5 4WD w/16" wheels (non highlander) had the tall springs, verified by paint markings.
I'm also running 906's in the rear with 99 talls in the front, nice combo.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
01-27-2020, 11:12 AM
My 4x4, v6, auto, SR5, 99, 16” wheels rig has the talls from the factory per stance and color codes.
The back sags just like all the others if you put a box of doughnuts behind the seat. The rig sits about 21” rather than 20” like other years. Ride is nice even at 330k. But I put KYB’s on it some odd years back and firestone air bags in the rear.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
