Old 01-24-2020, 04:48 PM #1
garn79's Avatar
garn79 garn79 is offline
Real Name: Jeff
garn79 is on a distinguished road
garn79's Avatar
Real Name: Jeff
yep another 99 Talls question
do all 99s have tall coils? thought id read somewhere here that it depended on your manufacturing date?
ive searched and cant find anywhere.
I have a 99 SR5 date of manufacturing 12/98...do I have talls?
salt belt...no color codes left.
garn79 is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 10:26 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 will become famous soon enough jgue467 will become famous soon enough
jgue467's Avatar
"Highlander" models. Check out post #190 on this page for the part #s:
Absalom's Cookie Cutter 4runner Builds - New and Updated!
Luck and enjoy the Runner.
2001 Limited 4WD - 320K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL
StopTech slotted rotors - Magnefine trans filter - In series trans cooler, Original: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and on and on. WooHoo!!
Old 01-24-2020, 10:43 PM #3
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears has a spectacular aura about 3bears has a spectacular aura about
like he said....only the highlanders and if you go to order springs, you have to specify that
also...last I checked...Toyota was phasing them out I guess because the highlander part numbers were superseded to stock #'s
I could be wrong...but that's what I thought I saw
2000 SR-5 V6 Auto . Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, Talls, KYB, Airlift 1000, DRL delete, Big 3 wire, full rack, TBU, Swapped in Elocker, some LEDs, PIAA headlights, , Amsoil
Old 01-25-2020, 09:40 AM #4
brillo_76's Avatar
Real Name: Jon
brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light
brillo_76's Avatar
Real Name: Jon
Dont be saying that. I just ordered a set of highlander springs.
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
Old 01-25-2020, 02:14 PM #5
said I was not sure....last summer a friend was doing shocks and springs and he said he tried to order highlander sprigs by part number and they superseded
to stock 2002 springs....that's what he said
Old 01-25-2020, 03:19 PM #6
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe will become famous soon enough Kanoe will become famous soon enough
Kanoe's Avatar
I'm still finding lots in the junk yards. I am basing this off color code, not vehicle specs. I have had 2 sets myself (kept 1) and the last 3 junkyards I have been to each had a set. Pair them up with OME2906s and good to go.
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
Kanoe is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 03:54 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well I was at the point that my A/m springs were done. So if an inch shorter will be better then the 2.5 inch difference in my rear bumper from drivers side to passenger side.
Old 01-25-2020, 03:55 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Well I was at the point that my A/m springs were done. So if an inch shorter will be better then the 2.5 inch difference in my rear bumper from drivers side to passenger side. As the sage was really bad. Barely no suspension left.
Old 01-25-2020, 08:46 PM #9
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a jewel in the rough TheDurk is a jewel in the rough TheDurk is a jewel in the rough TheDurk is a jewel in the rough
TheDurk's Avatar
This is wrong. All '99 4WD with 16-inch wheels from the factory got the tall springs, including my non-Highlander SR5. Just check the colors.
Front Right Springs - Blue / Yellow (48131-35400)
Front Left Springs - Blue / Pink (48131 - 35350)
Both Rear Springs - Yellow / Red (48231 - 35210)
The color on the rear is sort of a sick greenish yellow, not a blazing lemon yellow.
That said, as someone who ran the '99s for 18 years, use OME 906s in back and the '99 Talls in front.
EDIT: I just saw where you (OP) can't see the colors. NJ is as salt happy as they come and I could see mine just fine. Maybe the PO painted the springs. Mine was built toward the end (03/99). I'm pretty sure if you have the locker and 4WD you got the Talls. The 15-inch springs were pretty short, you should be able to just look at it. Post a pic....
My Backyard Frame Swap
Old 01-27-2020, 10:21 AM #10
thegipper's Avatar
thegipper thegipper is offline
thegipper has a spectacular aura about thegipper has a spectacular aura about
thegipper's Avatar
I can also confirm that my parts truck, a 99 SR5 4WD w/16" wheels (non highlander) had the tall springs, verified by paint markings.
I'm also running 906's in the rear with 99 talls in the front, nice combo.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 11:12 AM #11
Dieselchessy Dieselchessy is offline
Dieselchessy will become famous soon enough Dieselchessy will become famous soon enough
My 4x4, v6, auto, SR5, 99, 16” wheels rig has the talls from the factory per stance and color codes.
The back sags just like all the others if you put a box of doughnuts behind the seat. The rig sits about 21” rather than 20” like other years. Ride is nice even at 330k. But I put KYB’s on it some odd years back and firestone air bags in the rear.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof.
Dieselchessy is offline   Reply With QuoteReply With Quote
date , find , manufacturing , searched , talls
Bilstein 6112s & 5100 / 99 Talls for the Rear in the Mail - Question Mint 3rd gen T4Rs 11 05-25-2018 06:33 PM
99 talls vs. 881 or TRD Merninater 3rd gen T4Rs 9 12-06-2016 09:40 PM
3rd gen 2wd 906, 890 or 99 talls? 01thunder Engines / Suspension / Wheels / Tires / Audio / Accessories 1 08-24-2013 11:29 AM
99 talls yota runner 3rd gen T4Rs 7 12-28-2011 01:06 PM
99 talls? frayed 3rd gen T4Rs 7 04-14-2011 04:07 PM
