Old 01-24-2020, 11:36 PM #1
NegroTundra NegroTundra is offline
NegroTundra is on a distinguished road
4WD not working
Have searched around and there seems to be many avenues for my problem, which is: Recently purchased a 1998 5 speed with locker (drool!) for cheap, knowing that the 4wd doesnt work. Seller said he never cared cause he never used it, and that the clutch was replaced about 5k miles ago. This is a 5 speed manual with the J-shift 4wd. Here's what I've done to diagnose:
1) Confirmed that when I switch to 4HI, the front drive shaft will not spin by hand
2) Confirmed that while in 2HI the front drive shaft will spin by hand
3) Only one side of the vacuum switch valve is pulling a vacuum no matter the position of the 4wd lever. I went to junk yard, pulled another vacuum switch of a wrecked 97 runner, same result.
4) If I switch positions of the 2 vacuum lines coming from front diff, there is no difference
5) When switched into 4wd, no voltage reading at the ADD actuator on the front diff
6) When switched to 4wd HI, I get 11V at the driver side plug that goes to solenoid on top of transfer case
7) When switched to 4wd LO, I get 11V at the passenger side plug that goes to solenoid on top of transfer case
This is as far as Ive gone. Any help would surely be appreciated!
00 T4R 3.4L Sc'd Locked 4x4 (140k)
98 T4R 3.4L 5-Speed Locked 4x4 (280k)
16 Dodge Ram 2500 6.7L Cummins fully deleted
NegroTundra is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 02:18 AM #2
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
I believe what your calling solenoids on the transfer case are just shift position sensors. Sounds like they work.
When shifting into/out of 4wd you should hear a relay over behind the glove box cycling. Not intimately familiar with it, but there should be a 4x controll module over there.
Sounds like it’s not responding to the shift position sensors input.
For the VSV you replaced both of the solenoids I assume.
Read this thread.
Won't go into 4 wheel drive
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 09:23 AM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
You need to remove the switches on the transfer case and one on the front diff and check for continuity when depressed.
Old 01-25-2020, 02:38 PM #4
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
sounds like you have done most of the check steps. Yes you should hear clicking on and off behind the glove box
Old 01-25-2020, 05:13 PM #5
I found the relay behind the passsenger kick panel. There is no click when switching from 2HI to 4HI.
Old 01-25-2020, 06:29 PM #6
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
This is actually meaningless. These switches send a GROUND signal. I am not sure what side you are reading on, but that is not the way to do it. I am virtually certain your issue is the passenger-side position switch. If you can access the plug, test the for continuity between the two wires coming from the TC in 4HI, 4LO, and 2HI. You should be open in 2HI and continuity in 4HI and 4LO. If not, order yourself a 84222-35110 and swap it out.
I am assuming it is wired the same as a J-shift, 5-speed 4Runner.
My Backyard Frame Swap
Old 01-27-2020, 02:53 PM #7
Originally Posted by TheDurk View Post
I am virtually certain your issue is the passenger-side position switch. If you can access the plug, test the for continuity between the two wires coming from the TC in 4HI, 4LO, and 2HI. You should be open in 2HI and continuity in 4HI and 4LO. If not, order yourself a 8422-35110 and swap it out.
Thank you. I have been busy and not able to dedicate time to this lately. I will try that out. Are you certain of your part number? I googled it and nothing is popping up.
Old 01-27-2020, 03:32 PM #8
TheDurk's Avatar
TheDurk's Avatar
No, I managed not to type a digit. I it needs another "2". As is, it's not even a Toyota part number.
Switch Transfer Ind 84222-35110 | Conicelli Toyota of Conshohock
Sorry about that. I edited the original post.
Old 01-27-2020, 11:16 PM #9
Thanks TheDurk. You called it. I lucked out and was able to save my switch with a good cleaning from a MAF cleaner. I may go head and purchase a new 84222-35110 so that if it does die again I can just swap it. Cheers!
Old 01-28-2020, 12:40 AM #10
TheDurk's Avatar
TheDurk's Avatar
Glad it worked out. Just out of curiosity, how did you access the switch? Unbolt the cross member and droop the trans?
Old 01-28-2020, 10:06 AM #11
I was able to get at it from the top. Most folks say this isn't possible but I think if you have the manual transmission it allows just enough room. I also removed the tranfer case gear selector (4x 12mm bolts).
Old 01-28-2020, 11:09 AM #12
Real Name: Patrick
Real Name: Patrick
I recommended drooping the transmission in the other thread because your signature lists you have an automatic in your signature. I forgot you mentioned in this thread that it was for a manual. Good to know you can get to it that way on a manual, but definitely not possible for anyone with an automatic.
Old 01-28-2020, 01:07 PM #13
TheDurk's Avatar
TheDurk's Avatar
I could get a wrench on it, but I could not get enough force on it to make it turn. So I McGuyvered a manual control until I did my frame swap, and then it was easy.
4wd , front , side , switch , vacuum
2003 4Runner SR5 V6 - Auto-door lock, not working for a year, now magically working! Cookster Problems & Warranty Issues 1 08-09-2019 05:39 PM
Headlights not working on low, high beams working. HELP buckeye4runner08 4th Gen T4Rs 8 02-12-2017 11:29 PM
Turn signal not working? Std trouble shooting isn't working swapmeet 4th Gen T4Rs 9 09-14-2014 11:21 PM
95 rear window not working, motor can be heard working DLPDLP Classic T4Rs 22 01-29-2012 08:17 AM
2001 remote not working, rear wiper/defog not working theedudenator 3rd gen T4Rs 1 02-06-2011 01:10 AM
