Old 01-25-2020, 05:45 PM #1
tbryanh tbryanh is offline
tbryanh is on a distinguished road
Injectors Interchangable: 4-Hole & 2-Hole?
I heard the 96-98 4Runners have silver/green injectors with 4 spray holes, and the 99+ 4Runners have orange injectors with 2 spray holes.
fuel injector replacement
Some say 4-hole injectors should not be used to replace 2-hole injectors because the control board might not work right with them.
I have access to a set of 4-hole injectors in good condition from a 98 donor vehicle that I want to put into a 2001 vehicle.
Anyone tried this?
1997 2WD Limited. 2000 2WD SR5. 2000 2WD Limited.
tbryanh is offline   Reply With QuoteReply With Quote
Old 01-25-2020, 10:26 PM #2
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
They work, but not as good as you think they might be. The spray pattern is very linear and shoots streams of fuel rather than a spray. Injectors with a spray pattern will yield better results than switching from one stream pattern to another.
I replaced the 2 hole injectors in my '91 with a spray patterned 8 hole injector and gained MPG's and power. I've yet to see any plug and play with the right cc's for our engines though.
326WHP 347TQ
Old 01-25-2020, 10:47 PM #3
Thanks for the reply and the info about stream versus mist.
Wasn't thinking that 4-hole was better than 2-hole and that switching from 2-hole to 4-hole would give a performance improvement.
The 4-hole are in good shape and and at least one of the 2-hole are bad.
Just want to get the car running good. Don't want mismatched injectors or injectors that won't work.
Sounds like the 4-hole injectors will work as a replacement for the 2-hole then?
2-hole , 4-hole , injectors , spray , vehicle
3VZE 3.0L V6 4-hole upgrade fuel injectors. BS? airdreams1 Classic T4Rs 31 03-29-2019 12:34 AM
FS, FJ 8 hole, set of 5, AZ $290 AZ07Runner For Sale: Suspension/Wheels/Tires 2 07-30-2018 10:04 AM
Replacing 4hole injectors with 12 hole? bassmacka 4th Gen T4Rs 0 07-28-2018 07:22 AM
2 hole or 4 hole injectors? neokhz 3rd gen T4Rs 17 02-03-2018 12:16 PM
Butt hole moved after Body lift (Spare tire access hole) KSWAY 3rd gen T4Rs 3 03-13-2013 11:09 PM
