Old 01-26-2020, 02:02 PM #1
Ifirefight's Avatar
Ifirefight Ifirefight is offline
Ifirefight is on a distinguished road
Ifirefight's Avatar
Losing brake fluid mysteriously
2001 with the dreaded ABS system. Was having issues with the dash brake warning light,buzzer,trac, abs lights coming on and going off after a while. Decided to bleed the brakes a few weeks ago. Seemed to help as far as the warning lights not coming on all the time. Checked fluid level yesterday, it was at the low mark. Added fluid. All is good. My question is where did all that fluid go? I park in the same spot, no drops on the ground and no fluid anywhere under the vehicle. Is it possible that there was air trapped in the lines and it has since worked its way out?
Ifirefight is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 02:40 PM #2
As pads ware the fluid level goes down. When fluid gets to the minimum line you are supposed to check your brake pads and shoes.
Sometimes the rear wheel cylinders leak and it’s not obvious until you remove the rear drums.
Old 01-26-2020, 02:45 PM #3
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
I don't think air in the system would be it, it's a sealed system so air shouldn't be in there and couldn't work its way out.
There is not a lot of volume there. Maybe you wouldn't see a drip. It would only be a couple ounces over several weeks? Could you have a bleeder not quite tight enough? It would likely leak under pressure more so than resting. Get a helper to tromp on the brakes and look under for weeping.
I don't know if it's possible for the master cylinder to leak into the booster but maybe. That's one spot you wouldn't see.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 07:20 PM #4
BrianK14 BrianK14 is offline
BrianK14 is on a distinguished road
Agreed with all that 19963 said above
BrianK14 is offline   Reply With QuoteReply With Quote
Old 01-26-2020, 07:38 PM #5
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
+ 2 with the other 2 users. If your brake system doesn't have any leaks. It goes to min line. Brake are warn out. If a small seep in the back shoes can be hidden for a while.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 01-26-2020, 07:56 PM #6
Honda pc Honda pc is offline
Honda pc is on a distinguished road
I thought 4runner were plagued often by leaky wheel cylinder in back.. If its drum brakes.
Sent from my SM-N960U using Tapatalk
Honda pc is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 02:21 PM #7
Kanoe's Avatar
Kanoe's Avatar
You don't hear much about it on this forum. Maybe 1 or 2 over the years but not a common complaint like the rear ale seals.
-2001 Echo D.D.
Old 01-27-2020, 05:17 PM #8
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
Did you follow the instructions on the master cylinder reservoir for how to properly check the fluid level? On the 2001-2002s with the hydraulic brake booster you need to pump the brake pedal ~40 times with the truck off to purge the pressure from the accumulator before checking the level. Once you turn the truck on and the system "pumps up" the fluid level drops down a bit, so if you top it off with it pressurized, the fluid may be overfilled.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 02:18 PM #9
Ifirefight's Avatar
Ifirefight's Avatar
Yes, I did follow the instructions. I have the service manual for the 01 4Runner. I will pull the tires off and check the pads and drums in the rear. Thanks for the support.
Old 01-28-2020, 07:14 PM #10
Ok cool. It's an easy thing to miss and is unusual for most cars. Good luck finding the culprit.
1998 BMW M3/4/5
Old 08-04-2020, 04:52 PM #11
Ifirefight's Avatar
Ifirefight's Avatar
UPDATE. Been meaning to update this. It was a bad rear brake cylinder. Easy fix and cheap. I replaced both of the rear ones to be safe. Losing brake fluid mysteriously
Old 08-04-2020, 06:53 PM #12
gamefreakgc's Avatar
gamefreakgc gamefreakgc is online now
Real Name: Jerod
Real Name: Jerod
Great job being attentive to the signals your car was giving you! A lot of people would have just kept filling it up until the leak got worse and worse.
326WHP 347TQ
gamefreakgc is online now   Reply With QuoteReply With Quote
Old 08-04-2020, 09:44 PM #13
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
This point is very true. I realized this after replacing my rear shoes & drums and rebuilding bell cranks. I bled the entire system with Motive power bleeder with great results.
I filled reservoir up to max level and over next few days noticed the level is lower in the master reservoir after driving. Almost topped it up to max level again but waited overnight to check next day.
Fluid level was back at max level next day.
Monitored this over following weeks and noticed exactly what you have said in your explanation.
I now have very good working brakes and an effective and properly working parking brake.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 03:07 PM #14
OliviaBall OliviaBall is offline
OliviaBall is on a distinguished road
You need to check carefully all the hoses and clamps, usually it is the main problem if fluid disappearing. I had the same problem and not only with the brake fluid, but with engine antifreeze as well. When I was stopping the engine, I was hearing how the fluids were getting out little by little and I was feeling the smell of those. That scared me a lot and I thought that the car is dead and there is no chance to repair it. So I decided to read more about this and I realized that I can repair everything by myself. Now everything is works well and I am very thankful. I would recommend you not to hesitate to learn more information about braking system and to understand how everything works and what fluid your car needs.
OliviaBall is offline   Reply With QuoteReply With Quote
brake , coming , fluid , lights , warning
Losing brake fluid very slowly. Where from? Sporin 4th Gen T4Rs 23 06-13-2019 10:09 PM
How to redo thermostat (and install trans cooler) without losing much fluid DK327 3rd gen T4Rs 5 05-26-2016 11:48 PM
Brake fluid/dash light situation/ fluid level FlaskTL 5th gen T4Rs 19 06-03-2015 10:53 PM
Losing radiator fluid scoots0492 Problems & Warranty Issues 9 04-01-2008 11:05 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
