Old 01-29-2020, 12:29 AM #16
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Originally Posted by VGKBlackhawks View Post
I bought Mike Studt links. I'm concerned that the additional length will cause full droop issues with the shocks I bought, but maybe I'm wrong. Wish me luck.
For the record I had no idea what I was doing when I 1. bought the truck, 2. had it modified. I should have done a lot more research... *shakes fist at the next dude who rushes into a mod.
I've learned to be grossly specific with any shop doing work on my rig.
I hope you all have better luck than I did.
Live and learn. Imagine trying to do all this before the internet existed.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 01-29-2020, 11:42 AM #17
mesooohoppy mesooohoppy is offline
mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about
im fairly certain his links are made for lifted trucks. his fixed my terrible sway bar angles and i have the same amount of lift as you do. send him a DM, he will help you. it just seems as if you have either installed them incorrectly, or something is binding that causes your rear end links to look like that. mine dont look all cocked like that.
start watching mtbtim's videos and do your own wrenching. you can do a lot with a simple set of tools and o rileys rental tools. if someone installed those endlinks for you, they did a shitty job.
99 4runner limited; imperial jade mica
IG: mesooohoppy
mesooohoppy is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 10:45 PM #18
VGKBlackhawks's Avatar
VGKBlackhawks VGKBlackhawks is offline
VGKBlackhawks is on a distinguished road
Okay... I got the links. It still seems like an odd angle. I only completed one side as I wanted some opinions/help.
I also noticed that the sway bar is chaffing on the shock body. I'm not sure that these links will do anything to correct that. I left the links at the lowest adjustment as the sway bar seems really close to the LCA.
Thoughts please... Thanks in advance.
Rear Sway Bar Links-20200131_182435-copy-jpg  Rear Sway Bar Links-20200131_182525-copy-jpg
01 SR5 4WD, 3" lift w/King Shocks, Toytec Superflex Rear Coils/Total Chaos Rear links/panhard/UCAs, 285/70 R17s, 4x Innovations rear bumper, ARB rear locker
VGKBlackhawks is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 12:26 PM #19
when i did my rear sways i made the sway bar parallel to the rear lower link (i was told by someone not on the forum that is the correct way to install). if you are lifted like me your link is way too short and you need to run it out longer. the nice part is all you have to do is undo the lower jamb nuts on both sides of the truck and run the links out.
@MStudt makes these links. you should probably DM him this thread and he will take care of you.
IG: mesooohoppy
Old 02-04-2020, 12:32 PM #20
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
The bigger issue is your links are seriously tilted in/out, which will not change with the link length. I believe mine are nearly vertical in/out.
Is that an OEM sway bar in there? Are both end links tilted inward (implying that the sway bar is too short for the body mounts), or is one tilted in and one tilted out (implying that the sway bar is shifted to one side)?
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 12:44 PM #21
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
First question is did you install the longer links in the rear? It looks like you have the longer links in the rear, but it's hard to tell from the picture. If this is the case they should be in the front, and the short links in the year. Sounds crazy, but that's how it is.
The next question is about the sway itself in relation to the links. Something is off with the sway bar, and the angle it's putting the links at. Either the sway bar is bent or shifted.
Mike
MStudt is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 12:47 PM #22
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Maybe your Total Chaos rear trailing arms aren't adjusted properly and you have the rear axle pulled forward???
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 01:16 PM #23
Real Name: Leon
Real Name: Leon
Or maybe the end link mounts were cut off and reattached to the frame? Seems odd that they're the only painted section on the frame rail, like someone painted over them after re-welding.
Old 02-04-2020, 01:48 PM #24
This fellow seems to have the same setup.
Doesn't look to still be active on the board, but maybe something in his build thread.
Patio's 2000 4Runner Buildup
bar , initially , lift , links , sway
Rear sway bar end links WHT003RZM 5th gen T4Rs 1 12-08-2016 04:17 AM
Front sway bar removal and extended rear sway bar links. morphious 4th Gen T4Rs 25 11-29-2015 01:36 PM
Rear sway bar links Thorgan112 3rd gen T4Rs 2 10-21-2013 07:48 PM
New rear sway bar links? seanshreds 3rd gen T4Rs 0 04-21-2013 03:07 AM
Rear sway bar end links? Crashnrondo 3rd gen T4Rs 18 02-01-2013 08:13 PM
