Old 01-27-2020, 05:21 PM #1
lockedlex's Avatar
lockedlex lockedlex is offline
lockedlex will become famous soon enough
lockedlex's Avatar
Removable Spray Paint for Bumper/Cladding
I can't remember, but is there a consensus on a spray "paint" that I can use on a 4XInnovations bumper and side cladding that would be fairly robust, but also removable down the road?
I'd like to paint my side cladding and wheel flares at the same time, but I want it to be removable later on. I don't want to use regular spray paint for that reason and I want to be able to "fix" any trail rash myself, so I don't want to power coat the bumpers either.
Basically, I thinking of black for the cladding, then wrapping the rest of the truck in Matte Black Vinyl.
2000 Limited V6 4WD | Factory Locker | 2nd Gen SC | NGK Spark Plug Wires | AEM Boost/AFM Gauges | Scangauge II | Sonoran Steel 1.2 Lift/Washer Reservoir | AirLift Rear Airbags/Wireless Compressor | 4XInnovations Front/Rear Bumpers | Schrockworks Skid Plates/Sliders | Warn 12k LBS Winch-Synline | LED Halo Driving Lights | LED "Satoshi Cover" Lightbar | Thermal IR Cam | BFG All-Terrain KO2 | Kenwood with Sirius/Garmin Nav and Surround-View Cam | Heated Seats | Lumbar Support | Blacked out Emblems TRD Badge | Rear Diff Breather Extension | LED Taillights | LED 6k Headlights | 120V Power Socket | Flipped Hood and Fuel Release | Rear Window Switch in Cargo Area | Custom FlipBlade Key | Warm White LEDs
lockedlex is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 06:10 PM #2
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
A wrap is the best solution for the plastic cladding. I haven't seen anything except good quality automotive paint with proper prep stick otherwise. For the bumper it's easy, hit it with regular spray paint, rustoleum professional is my choice, you'll want to scuff the whole thing first, then wipe down with wax and grease remover, use a self etching primer, followed by a high build primer (if you want a smoother finish) then paint, will give a decent finish.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 01-27-2020, 08:02 PM #3
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Sounds like you're asking about the "Plasti-dip" type product (there are several others with different names, this is just the most well known). It's not very durable, collects bug guts and dirt like nothing else and is impressively hard to clean. I have some on a white van and am finding that it Also holds onto more iron in the water, so it has yellowed significantly in a years time.
It's a good cosmetic short term option (a year or less based on my very limited experience). Maybe it holds up better in smaller sections, like over emblems.
If you want non-permanent but decent quality, get it vinyl wrapped. I don't see any reason to NOT paint though, these things aren't now,and will never be (in our lifetimes) "collector" items. Just make it how you'd like it and enjoy. No one wanting a clean stock rig will buy one with a plate bumper anyway, and anyone willing to have a plate bumper will be Perfectly accepting of other changes.
Brian. is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 12:44 AM #4
lockedlex's Avatar
lockedlex's Avatar
Thanks! I hadn't thought about just wrapping the cladding, etc. too. Mostly, I wanted something that would be easy to touch up if there's trail damage and I could probably replace the wrap just as easily.
Oh yes, Plasti-dip.. I couldn't remember that name. Yeah, if it's not easy to keep clean, then I might just skip it.
Old 01-28-2020, 01:33 AM #5
truc.karl truc.karl is offline
truc.karl is on a distinguished road
Applying a glossifier makes it easier to clean the plastidip.
truc.karl is offline   Reply With QuoteReply With Quote
Old 01-28-2020, 04:41 PM #6
lockedlex's Avatar
lockedlex's Avatar
In thinking about it, I might try the plastidip first (at least on the bumpers). ONLY because I want to see if the color change is something I'd like. I'm tempted to paint the new bumpers the same color as the body cladding too, so there's that.
Currently, the paint is in very good condition on the cladding and the rest of the car, so I don't want to commit to any spray paint yet.
The vinyl idea on the cladding is good though. So I might go either way with it.
Old 01-29-2020, 10:08 AM #7
Lamer's Avatar
Lamer Lamer is offline
Real Name: Jake
Lamer will become famous soon enough Lamer will become famous soon enough
Lamer's Avatar
Real Name: Jake
I have used plasti-dip many times, on small emblems and entire vehicles. DipYourCar - World Famous Peelable Auto Paint – DipYourCar.com
I clean the cars with a self-wash pressure washer and don't think twice about it. no issues at all.
the dip has been able to hold up for years (my charger was dipped for 2yrs, and my WRX for 5yrs) with no signs of fading, tearing, bubbling, or anything. this includes just emblems...
just go with many light coats and you will be fine.
here is the WRX. it was a beautiful chameleon fade of purple, green and pink.
and the charger, Anthracite Metallic.
https://i.imgur.com/WQdryKXm.jpg
The Sequel - 1996 4Runner SR5 - Houston, TX
The Original - 2001 4runner SR5 - SOLD
Etsy Page - Custom Pinstriping and Sign Making
@8LinePinstripe: Instagram
Lamer is offline   Reply With QuoteReply With Quote
Old 01-29-2020, 07:01 PM #8
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
let me know if you vinyl wrap the cladding, could be the best solution per $.
APhelps is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 04:53 PM #9
lockedlex's Avatar
lockedlex's Avatar
Thanks for everyone's input! I just got he bumpers in... wow.. 4xinnovations welding and manufacturing process is insanely good. This bumper looks great! Can't wait to actually put it on.
Side question, do you know if you usually paint/powerdercoat the outside and insides of a bumper like this? Or do people usually just paint the outside?
Once it's on, I'll figure out what route to take with "covering" it with something.
Old 02-13-2020, 05:22 PM #10
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Anytime I paint or have something painted or powder coated, I ask for complete coverage. You don't want exposed metal because it will rust. At the very least you would want the inside to have some type of coating like primer but personally I like for everything to get painted or powder coated.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 06:19 PM #11
lockedlex's Avatar
lockedlex's Avatar
Ok thanks for the heads up. I'll spray something on the inside parts then. Then worry about making the outside parts look pretty, lol.
I was worried about spraying it first, then mounting it and possibly marring the finish during the mounting. So I figured I'd do it after the fact. But yeah, I wouldn't be able to reach the insides as well. So I'll spray it while it's still off the car.
Old 03-23-2020, 04:00 PM #12
lockedlex's Avatar
lockedlex's Avatar
Thought I'd give everyone an update. So I decided to Matte Black spray the bumpers. Vinyl wrap would have just been too complicated and I realized I could easily spray them the cladding color down the road anyway.
I did Wrap the cladding, mostly to see if I liked Flat Black and I have to say, I'm not disliking it at all!
I'm going to get angled sliders, but that will probably be another 4 months before the arrive.
The next question is do I spray the wheels also a black color, or recondition them to the original silver?
Modifications so far: 4x Front/Rear bumpers, Warn 12lbs winch with Syn line, Halo/LED driving lights, LED light Bar, Flip up license plate holder for hawse fairlead.
Removable Spray Paint for Bumper/Cladding-img_20200323_122301042-medium-jpg  Removable Spray Paint for Bumper/Cladding-img_20200323_122308864-medium-jpg  Removable Spray Paint for Bumper/Cladding-img_20200323_122404025-medium-jpg  Removable Spray Paint for Bumper/Cladding-img_20200323_122325413-medium-jpg  Removable Spray Paint for Bumper/Cladding-img_20200323_122334987-medium-jpg  Removable Spray Paint for Bumper/Cladding-img_20200323_122316213-medium-jpg  Removable Spray Paint for Bumper/Cladding-img_20200323_122429350-medium-jpg  Removable Spray Paint for Bumper/Cladding-img_20200323_122350642-medium-jpg
Old 03-23-2020, 04:02 PM #13
lockedlex's Avatar
lockedlex's Avatar
OH, I also managed to add a Birdeye View Rear Cam system
Removable Spray Paint for Bumper/Cladding-img_20200323_122218912-medium-jpg
Old 03-23-2020, 04:04 PM #14
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
Thanks for the update, I really like the look. What did you use for wrapping the cladding (if you have a specific link)?
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 03-23-2020, 04:16 PM #15
lockedlex's Avatar
lockedlex's Avatar
Thanks. It's not perfect, but very good (the job I did, the Wrap itself is pretty awesome and forgiving). Also I like the wrap idea since if I get bad desert pinstriping, I can just replace that section.
I used this:
Amazon.com: VViViD Satin Flat Matte Stealth Jet Black 5ft x 25ft 125sq ft Cast Vinyl Decal Bubble-Free Car Wrap Interior: Automotive
cladding , paint , removable , side , spray
Have Cladding? Here's What DupliColor Trim & Bumper Paint Looks Like on Exterior Trim Bluesky 07 4th Gen T4Rs 3 06-28-2017 07:46 PM
Spray paint enamel that matches body paint code? luke87gt 4th Gen T4Rs 11 09-13-2016 05:06 PM
Spray can paint job Steven94 General Discussions 20 07-14-2013 12:07 AM
want to spray paint my emblems 02adventurer 3rd gen T4Rs 6 07-03-2011 02:03 PM
removable top PAINT Black_TurboSR5 Classic T4Rs 2 02-07-2010 12:39 AM
