Old 01-29-2020, 12:58 PM #16
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
Originally Posted by SasquatchRevenge View Post
I'm absolutely going to try this method tonight. Lots of great suggestions that I had not thought of here. I'll keep this post updated!
I have drum brakes on 2 of my vehicles............. I do the tire rotations and check all the brakes/pads/shoes ..if the drum has a ridge I grind that ridge down so the drum slides off .. also anti seize on the axle where the drum sets..
your problem is the shoes had most likely a spring failure causing the shoe to create high heat then the axle seal got cooked ..
catrains is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 09:20 PM #17
SasquatchRevenge's Avatar
SasquatchRevenge SasquatchRevenge is offline
SasquatchRevenge is on a distinguished road
Well, I got the drum off. Here's how it went down.
First, i jacked up both rear tires and attempted to drive off the drum like recommended. The side with the frozen brakes didn't budge, so it was on to the next method.
Put tire back on, and went for a short drive. I thought if i could break the shoes free and get everything warmed up, maybe that would do the trick. Although it did mostly break the shoes free from the drum, i still could not pull the drum off and the star wheel was still seized. On to next method.
Angle grinder with a cutoff wheel, chopped an access hole in the face of the drum. Once I had access, i bent away the plate that locks the star wheel, and attacked the star wheel with a hammer and chisel. It took some heavy, persistent work to break the star wheel free, but it did eventually back all the way off.
Drum was then just rusted to the hub. Penetrating oil, heat, and a lot of prying got her off. The hole I cut actually provided a great place to grab with the claw end of a hammer and pull. To my surprise, there were no broken springs. Just A LOT of baked on gear oil.
"When you don't know what you're doing, it's best to do it quickly"
-Jase Robertson
SasquatchRevenge is offline   Reply With QuoteReply With Quote
brakes , drum , gear , issue , wheel
Front Diff: Replace Axle Seal? or Both Seal and CV? Berty_K 4th Gen T4Rs 10 10-10-2021 10:36 PM
Rear Axle Seal: Axle Puller Tool Design nobb 3rd gen T4Rs 29 11-23-2019 07:39 AM
Inner seal/ axle seal replacement razzman1 4th Gen T4Rs 4 08-27-2015 07:07 PM
Price check - Brakes and axle seal RunnerAK 4th Gen T4Rs 6 07-17-2013 06:52 PM
brakes locked up- help dwmac64 Classic T4Rs 7 04-04-2011 04:15 PM
