Old 01-30-2020, 12:00 PM #1
Tiktiki Tiktiki is offline
Tiktiki is on a distinguished road
Dual Bagel mod AND Andy 2.0?
Anyone did a dual mod already?
I grabbed the rear heater switch (2-pos + off) off a junk truck to try to make the two mods at once.
"HI" position would enable the Bagel mod (reversible, VSC OFF only).
"LOW" position would enable the full Andy 2.0 (VSC and TRAC off, ABS still on, need restart to clear).
From what I understand, Bagel mod trigger 4 relays to switch from "normal" signal to ground, fooling the VSC into thinking the truck is in 4WD locked mode.
Andy 2.0 just disconnects EXI, which causes the whole VSC module to fault, disabling everything but ABS.
So if I use an extra relay between the VSC module and the relay for Bagel mod to disconnect EXI, it should work right (still would need to restart the truck to clear).
I am pretty confident it works, I was just currious to see if anyone did it.
Oh and also, for those that did the Bagel, are you pulling 12v off battery or Ignition?
Tiktiki is offline   Reply With QuoteReply With Quote
Old 01-30-2020, 03:37 PM #2
So, here is what it looks like pre-install.
Just one more relay under the dash, allowing to disconnect the EXI wire instead of grounding it.
Disregard the wire color, I got a 5-pack of cheap relays with holders and they came pre-wired.
In this case, red and white are all grounds.
Yellow is trigger (+12 via switch)
Black is VSC/ECU-side
Blue is Trans/sensor-side.
andy , bagel , mod , truck , vsc
Andy Mod Jack Wruff 3rd gen T4Rs 3 07-19-2019 01:38 PM
help! Andy mod 2.0 Jared_Rouse_o6 3rd gen T4Rs 0 01-04-2016 05:04 PM
Andy mod 2.0 slides 3rd gen T4Rs 2 11-08-2014 01:20 AM
Andy mod or something else JamesDean91 3rd gen T4Rs 0 09-24-2014 07:49 PM
Andy Mod 2.0? xskydivingdudex 3rd gen T4Rs 22 01-24-2014 06:48 PM
