Originally Posted by TN4Runner07
I know front end vibration posts are never ending!
The issue I am having is that I am getting vibration more in the steering column around 2300-2500 RPM at HWY speeds around 70-75 mph.
I have ensured that the tires are rotated and balanced, however, I become completely lost when it comes to first things to check on steering/vibration issues?
I have also been chasing a p174. So might be a leak causing the vibration?
OEM Shocks, struts, etc....
Any suggestions?
I'd rotate tires again just to make sure it's not a tire balance issue. Where did you get the tires balanced?
Other things to check would be tie rod ends, inner tie rods, and front wheel bearing for any play. I'd also take a look at your upper/lower control arms bushings. Another thing to check is if the vibration goes away if you shift into neutral while it's vibrating.
A P0174 code shouldn't cause a vibration.
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
