Old 01-30-2020, 06:39 PM #1
Hollywood1 Hollywood1 is offline
Hollywood1 is on a distinguished road
My Girls 02’ needs new front Shocks. Thinking 99’ New Coils as well?
My girlfriends front shocks need to be replaced in her 2wd 2002 v-6 3rd gen.
One of the shocks is blown and it’s leaking fluid.
I’m thinking of just going with OEM factory shocks since they’ve lasted this long at 180k. Daily street/highway driver.
But it currently has a 1.5” aluminum spacer lift.
I’m thinking if removing the spacer and going with a new set of 99’ coils which should be about the same amount of lift.
Do I need to go with 99’ shocks as well or do I just order them for her year 02’?
2000 2WD SR5 V-6
Hollywood1 is offline   Reply With QuoteReply With Quote
Old 01-30-2020, 07:29 PM #2
Brian.'s Avatar
Brian. Brian. is offline
Brian. has a spectacular aura about Brian. has a spectacular aura about Brian. has a spectacular aura about
Brian.'s Avatar
Shocks are the same OE part number across all 3rd gen years, both engines and all 3 trims: 48510-39585 You need 2, one for each side (plus the coils and don't neglect the lower ball joints so the wheel doesn't fall off).
Brian. is offline   Reply With QuoteReply With Quote
Old 01-30-2020, 07:42 PM #3
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
If you're looking to retain 1.5" of lift IMO you'd be better off replacing the shocks with bilstein 5100's and ditching the spacers. Your coils should be fine at 180k too IMO the front springs tend to hold up well compared to the rears.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 01-30-2020, 07:45 PM #4
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light gamefreakgc is a glorious beacon of light
Real Name: Jerod
If you do only the shocks & struts, they will fail prematurely if the springs have over-compressed and are sagging.
Spacers negatively affect the ride of the vehicle as well since you are pre-loading the coils so there's more "harshness" over bumps and potholes. Most people on here agree to avoid them unless you don't care about ride quality. However, others have shared that spacers actually double the lift. A 1.5" spacer creates 3" of lift or something like that. I don't know all the physics behind it, has to do with pre-loading the coils and compression rates. You might find that removing the coil spacers and putting in 99 talls you'll sit lower than before. But it will ride softer.
OEM coils and struts are pricey though. The rear coils and shocks are cheaper.
'98 4Runner SR5 - 4x4 5VZ-FE Supercharged - 222k miles, JDM engine @ 221k
AEM F/IC 6 Piggyback, 2.1" pulley at 11 PSI, Go-Fast Parts
Old 01-30-2020, 08:10 PM #5
Correction:
I will be removing the lift spacers, the 99’ coils should compensate for the lift vs. the lower 02’ coils.
I’ll have to compare pricing on the Factory shocks vs. Bilsteins. The Bilsteins will be a bit stiffer ride. Granted Los Angeles does have some crappy roads but it’ll probably never hit a dirt road aside for a random I paved parking lot.
As for the ball joint, yes that is on my to do list as well. I recently did the passenger side Upper and Lower Ball joints along with Hub Bearing.
Driver side hub bearing seems fine but I may as well swap it with a new one since I’ll have it apart.
I have to retorque the valve cover bolts as well to hopefully stop that pesky slow drip! 🤦🏻*♂️
2000 2WD SR5 V-6
Old 01-30-2020, 08:13 PM #6
Driver side Balljoints were on the to do list at same time as well. 👍
2000 2WD SR5 V-6
99’ , lift , shocks , spacer , thinking
WTB 2 Front Shocks with front Coils and 2 rear shocks Rambler2005 Want to Buy/Trade 1 01-19-2020 09:12 PM
WTB: Used 881 coils and front 5100 shocks RuggedRunner Want to Buy/Trade 1 05-18-2018 05:45 PM
2013 Fj front coils 4x4 and front and rear shocks blazier196 For Sale: T4R Items 0 12-30-2015 02:30 AM
toytec front coils with OEM shocks KBToys 4th Gen T4Rs 3 11-02-2011 09:43 AM
