Old 02-02-2022, 08:32 PM #1
Ben590 Ben590 is offline
Ben590 is on a distinguished road
Power windows and locks stoped working
This weekend I did the so called "grey wire mod" (despite the wire not being grey) to my 4Runner so I could use my rear E-Locker in 2H and 4H instead of just 4L.
The locker now works perfectly in all transfer case modes, so the mod works as expected.
But now (and it could be pure coincidence) my power seats, windows and locks stopped working, which is a bit of an issue because my window is halfway open and it’s the middle of winter in Canada.
Dose anyone know what could be wrong or has had this happen to them
My 4Runner is my only car so I would like to fix this ASAP
Any help is appreciated
1997 Toyota 4Runner limited with E-Locker
Calgary, Alberta Canada
Ben590 is offline   Reply With QuoteReply With Quote
Old 02-02-2022, 09:02 PM #2
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
I'd start checking fuses first. I don't have the wiring diagram for a 1997, but based on the 2000 diagram I'd be looking at the 30A Power Fuse. It should be in the drivers kick panel.
Skulking is offline   Reply With QuoteReply With Quote
Old 02-02-2022, 09:31 PM #3
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
Yes check that, but it is in the junction block, not the kick panel. It's the body ECU which you can access through the left lower dash area.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 02-02-2022, 10:12 PM #4
nissanh nissanh is offline
Check for any broken wires inside the rubber boot between the drivers door and Body.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 02-02-2022, 10:34 PM #5
Thanks for the help everyone
I found the pink "power" fuse in the inside fuse box in the lower left dash board i checked it with my multi meter and i cant get continuity across it.
So is this my problem?
Old 02-03-2022, 12:24 AM #6
The square pink one that is in the upper right corner? If it doesn't have continuity it needs to be replaced. It may just be a fluke, but you may also have a problem which will blow the replacement fuse as well, so be ready to troubleshoot further.
Old 02-15-2022, 09:53 PM #7
I replaced that fuse about 2 weeks ago and it has been working well since
Thanks everyone for your help
4runner , mod , power , windows , works
Power locks, windows, rear hatch working intermittently Rob_E 5th gen T4Rs 3 01-20-2023 10:41 AM
power windows / door locks / chairs control / sunroof / back window stopped working Magiclamp2012 3rd gen T4Rs 5 09-08-2014 09:43 AM
Power windows, mirrors, and locks not working Master Bator Classic T4Rs 5 04-09-2012 09:40 AM
Some windows stoped working pistenbully Classic T4Rs 4 08-29-2011 02:21 PM
Power windows, power door locks, sunroof, rear window ALL DEAD JAKE_S 3rd gen T4Rs 2 03-18-2009 12:30 PM
