Old 02-01-2020, 05:08 PM #1
T4Rscott's Avatar
T4Rscott T4Rscott is offline
T4Rscott is on a distinguished road
T4Rscott's Avatar
Tax refund maintenance advice
With my tax refund coming soon, I have a list of maintenance and replacement items I need advice on.
With the money I am planning on doing the timing belt, water pump and all the necessary items while I’m in there.
What I need advice on is, should I replace my radiator since I’m into it? It’s the original to my 994r and I’ve been seeing some spots along the top crimp where there’s some white residue. There has been no appreciable coolant loss, no over heating. I went to a B&M transcooler almost 10 years ago. Should I do a pressure test, or just keep running it?
I’m tryin to conserve some money, as the jury is still out on a fuel pump, cranks longer than I like, but starts fine.
Any advice would be great!
Thanks,
Scott
99 T4R SR5. OME 906s rear.Stock front springs with 1/4" spacers and Bilstein HDs all around. B&M trans cooler. Deck plate mod and rear diff breather mod. Blacked out bumpers and graphite wheels. Cobra CB in the ashtray. Tundra 199 brake upgrade. Pioneer MVH360BT head unit.
Necessity is the mother of invention.
Recent studies have shown that aggressive therapy combined with owning Toyotas, can be affective in breaking the cycle of Jeep addicition.
T4Rscott is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 06:07 PM #2
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
First... dude, you shouldn't be getting a "refund" bigger than what'll cover a pizza and 6-pack of beer. There's simply no reason to allow the Gov to have YOUR money at a zero percent interest loan. Just hate to see people not make the most of what little money they get.
Anyway, as for the radiator.. did you Bypass the oem radiator when you put in the trans cooler? If you didn't then replace the radiator, $100 vs $1000's if you pink-milkshake the transmission. Can't answer on testing the aux cooler, perhaps drop them a line (email or call) and ask if they recommend periodic testing and what that entails.
Brian. is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 09:04 PM #3
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I would do the radiator as a good interval for them is 10 years.
brillo_76 is online now   Reply With QuoteReply With Quote
Old 02-01-2020, 09:46 PM #4
spartacus's Avatar
spartacus spartacus is online now
spartacus's Avatar
if you can you might also want to look into'champion all aluminium radiator.
spartacus is online now   Reply With QuoteReply With Quote
Old 02-02-2020, 08:19 AM #5
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
LBJs?
Got the other 'achilles' area handled already, the LBJs?
When those fail it is catastrophic, instant drop to the ground for front end. OEM are best and pricey yet shop around...
Old 02-03-2020, 01:24 AM #6
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
A new radiator after 21 years is cheap insurance for what could happen. I'd do it. It's not an "every 100K" item like the timing belt but 20+ years for a part with plastic that's under pressure is a good use of maintenance time & funds. Plus you'll be taking it out for the timing belt job anyway.
326WHP 347TQ
Old 02-15-2022, 01:41 PM #7
qweer qweer is offline
qweer is on a distinguished road
The tax system has tested my nervous system quite often. So far, I have not learned how to manage my taxes because there are too many of them. I try to look for information about it on the Internet, in articles, blogs, and so on, but it is difficult for me. The only useful option is youngandthrifty.ca which I discovered recently. I read a few articles on this site and realized that I had misunderstood the tax system and the financial industry in general. Now I want to learn more about it to understand financial matters better.
qweer is offline   Reply With QuoteReply With Quote
Old 02-16-2022, 01:02 AM #8
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Originally Posted by qweer View Post
The tax system constantly confuses me.
I wished they made everyone have to cut a check every payday or monthly to uncle sugar instead of the scam of estimated withholdings…... We’d have a revolution before the end of the month……
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
advice , i’m , pump , refund , tax
Need Preventative Maintenance Advice 00GTvert 4th Gen T4Rs 15 07-10-2019 11:23 PM
Maintenance Advice and Instructions GroverTheRanger 5th gen T4Rs 4 03-12-2014 02:58 PM
New 3rd gen purchase, need advice for new maintenance! Tdaz250 3rd gen T4Rs 3 05-09-2013 03:58 AM
Maintenance advice 152 Sumo 3rd gen T4Rs 7 03-12-2013 10:10 AM
Need advice on 05 maintenance ddicosmo 4th Gen T4Rs 9 12-01-2011 11:09 AM
