Old 02-01-2020, 07:45 PM #1
Tampa_T4R Tampa_T4R is offline
Real Name: Doug
Tampa_T4R is on a distinguished road
Real Name: Doug
IAC issue, cleaned, replaced, nothing helps.
I’ve searched this issue extensively.
P0505 code.
Thought it might need cleaning so I cleaned it and still code, but it was an aftermarket one, so I bought an OEM one and still the same code.
If I unplug the connector, it starts idling erratic, plug it back in it’s a smooth idle... In park it idles at about 1100 and in drive around 800. Is this correct?
I tested the connector for power and both sides of the connector (open and closed) are getting power at the same time, should that be the case?
I’m starting to think my rig is starting to show signs of a screwed up ECU as I do have another issue that could be ECU related too.
It doesn’t really seem to be idling poorly at all honestly, just the light is driving me nuts.
Tampa_T4R is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 08:53 PM #2
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
YouTube
Full video on JUST testing the IAC, step by step so you can know, beyond a shadow of a doubt.
Brian. is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 09:18 PM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Has the PCV valve and connections on both ends been checked for solid sealing?
Old 02-02-2020, 12:50 AM #4
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
P0505 isn’t exclusively an IAC issue. It just means the ECU can’t controll the idle to target.
Could be PCV, vacuum leak, throttle plate position, IAC, coolant temp/volume), ect...
800 and 1100 seems high. Maybe a vacuum leak providing extra air?
Search for threads where folks are trying to correct a “high idle”.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 02-02-2020, 08:24 PM #5
mmw0k7o mmw0k7o is offline
mmw0k7o is on a distinguished road
This may help...
My High Idle... CURED!!! - YotaTech Forums
mmw0k7o is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 08:14 PM #6
Real Name: Doug
Real Name: Doug
Already mentioned in my main thread, but figured I’d post here too in case someone has the same issue.
The ECU was the culprit of this issue!
code , connector , idling , issue , starting
Want a PA any ideas/helps 4runneracerunner Classic T4Rs 7 04-24-2014 09:25 PM
Battery replaced and Nav/Radio issue Placebo 5th gen T4Rs 1 01-09-2013 10:26 PM
Platinum mix helps gas milage and etc... MDT4RNR 4th Gen T4Rs 3 10-30-2006 07:10 PM
VIN Etch helps deter auto theft PROZAC 4th Gen T4Rs 9 04-28-2005 01:15 PM
