Old 02-01-2020, 09:44 PM #1
Hokie-Pokie VT's Avatar
Hokie-Pokie VT Hokie-Pokie VT is offline
Hokie-Pokie VT is on a distinguished road
Aftermarket or OEM Wheel Bearings
Fellow 3rd Gen-ers.
I am very suspicious that my wheel bearings are beginning to go bad (or already are). All the noises are there and the truck has 218k on it with a decent amount of that being towing, not a ton of off roading but a bit.
My question, should I go with OEM bearings to replace the originals. I am usually willing to shell out for OEM parts but these bearings are PRICEY. Is anyone who cares to input running aftermarket bearings that they think can stand up to some abuse?
Looking forwards to your replies!
2002 4Runner SR5 4WD
Hokie-Pokie VT is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 09:57 PM #2
bkvan68's Avatar
bkvan68 bkvan68 is offline
Real Name: Brian
bkvan68 is on a distinguished road
bkvan68's Avatar
Real Name: Brian
Wheel bearings
I replaced mine with Detroit axle bearings 1/2 the prince 5k miles ago no issues ... inexpensive they are easy to swap out so if they crap out sooner than the pricey OEM bearings did 89k I can always upgrade..!
bkvan68 is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 10:37 PM #3
Hillbill's Avatar
Hillbill Hillbill is offline
Real Name: Andrew
Hillbill is on a distinguished road
Hillbill's Avatar
Real Name: Andrew
Koyo
Hillbill is offline   Reply With QuoteReply With Quote
Old 02-01-2020, 10:39 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by Hokie-Pokie VT View Post
Fellow 3rd Gen-ers.
I mostly go either OEM or OEM mfg as they are the same part. I am not sure who the OEM Mfg are for the front wheel bearings. However, I can guarantee you several of our fellow members can answer that question for you. Along with others using A/M bearings as well..
Old 02-01-2020, 10:40 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by Hillbill View Post
Koyo
Are those the OEM mfg bearing supplier?
Old 02-02-2020, 08:32 AM #6
tvpierce's Avatar
tvpierce tvpierce is offline
tvpierce will become famous soon enough
tvpierce's Avatar
When I did my axle, I ordered SKF bearings knowing SKF a quality Japanese supplier and quite possibly the OEM supplier.
When I got them they were labled "Nachi Japan" (which is good) but they seemed a little loose -- in fact, they had more play in them than the bearings I had removed. So I figured I had to bite the bullet and order OEM Toyota bearings for more than twice the cost.
When the Toyota bearings arrived, they were also marked "Nachi Japan", and fealt exactly the same as the SKF. I sent the Toyota bearings back and installed the SKF.
I guess I was just being too anal about the feel and looseness.
tvpierce is offline   Reply With QuoteReply With Quote
Old 02-02-2020, 11:21 AM #7
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Koyo FTW
JZiggy is offline   Reply With QuoteReply With Quote
Old 02-02-2020, 12:32 PM #8
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
I've had Napa install Koyo bearings from their "altrom" line. High quality and half the price of SKF brand.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 02-02-2020, 04:43 PM #9
Originally Posted by mtbtim View Post
These Koyo Bearings are equivalent to OEM and are a little more affordable. Amazon.com: Koyo Wheel Bearing: Automotive
Once again Toyota Time Timmy the Toolman coming in to save the day. Don't know how many times your videos have saved me hundred of dollars in maintenance. Much obliged my friend and I greatly appreciate your input.
Old 02-02-2020, 04:48 PM #10
So new topic, what about the oil seals and other O-rings that are also pressed into the hub and around the axle? Should any of that be replaced while they are in there for good measure? Are any of these also likely to be worn out?
Thanks in advance.
Old 02-02-2020, 09:13 PM #11
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Thanks in advance.
You should replace all the related seals and c-clips.
If you're going to do this job yourself, I have 3 videos that will help you out. Use our Upper Balljoint Replacement video to learn how to get the knuckle off the rig and back on. Use our Manual Hub Swap Part 2 video to learn how to accomplish the press work. All the tools and parts links are the in the Manual Hub Swap Part 1 so you'll need that one as well.
Old 02-03-2020, 02:31 AM #12
truc.karl truc.karl is offline
truc.karl is on a distinguished road
I put Koyo bearings on my rig and have no complaints.
truc.karl is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 03:41 PM #13
XtremeAdventurer XtremeAdventurer is offline
XtremeAdventurer is on a distinguished road
I bought the Timken Kit29 from RockAuto for $63ish a piece. They were marked Koyo and were the exact same as the one's that I took out of my '99.
Almost bought the Koyo ones off Amazon just to be safe, but since I've never had a problem with Timken bearings ended up buying them and saving ~$30. When I opened the Timken branded box to find Koyo bearings, I was glad I made that purchase.
XtremeAdventurer is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 11:53 PM #14
nissanh nissanh is offline
I got rear axle bearings (OEM) on a hilux 1990 diesel and the same shop did rear axle bearings on a Hiace van with Koyo (japanese) on the same day. The shop owner showed me the difference after the installation. The backing plate on the Hilux axle spun freely while the backing plate on Hiace axle spun bit tight. Prior to the installation toyota bearing was bit loose but Koyo was play free.
Even Koyo is toyota's supplier, Koyo must make these bearings according to toyota's specifications. Koyo cannot make bearings on those specifications. Just like Toyota denso alternators lasts 200K miles without any service while Denso alternators on Honda's lasts 100K.
Old 02-06-2020, 03:27 PM #15
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Just got a full kit, with OEM everything from partsuoq.com; bearings, seals, snap rings, and new hub covers (the things that get bent up trying to get to the hub nut if you're not careful). With shipping it was $257 and change. Even with the nearly $50 shipping it beat any price in the states I could find:
weekendclimber is offline   Reply With QuoteReply With Quote
aftermarket , bearings , oem , pricey , wheel
New wheel bearings; which way do they go in? eurasiaoverland 3rd gen T4Rs 4 07-24-2016 09:38 PM
wheel bearings lwd03 Maintenance/Detailing 0 12-09-2014 09:01 PM
wheel bearings Stgo2019 3rd gen T4Rs 5 08-25-2013 03:31 PM
Wheel Bearings mtngoat 4th Gen T4Rs 1 04-23-2008 07:54 AM
Wheel Bearings DIY HELP 2K34R Problems & Warranty Issues 2 04-16-2008 04:07 PM
