Old 02-01-2020, 09:55 PM #1
nobb nobb is offline
nobb is on a distinguished road
Part numbers for a Thermoplastic CV Joint Boot Kit?
Hi guys,
My 4Runner is lifted by ~3" and I'm really sick of having to re-boot my CV's every 1-2 years. I've tried a bunch of brands and they are all made of neoprene which just isn't as good as the OEM thermoplastic. I haven't been able to find a CV boot kit that uses thermoplastic. There is an OEM boot kit (04438-35060) but that doesn't appear to be in production anymore and it's pretty expensive.
Can you guys suggest some more durable CV boot kit part numbers I can look at? I'm located in Canada.
Thanks!
nobb is offline   Reply With QuoteReply With Quote
Old 02-02-2020, 02:17 AM #2
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
I found this searching for my 4Runner by VIN number:
1996-2002 Toyota 4Runner Boot Kit 04438-35061 | Conicelli Toyota of Conshohock
pluton is offline   Reply With QuoteReply With Quote
Old 02-02-2020, 05:44 AM #3
Thanks. It looks like the old 04438-35060 was superseded by 04438-35061. Unfortunately all those sites seem to be serviced by the same supplier because it's $300 CAD to get two boot kits
Old 02-02-2020, 12:22 PM #4
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
These are what you want.
High Angle Inner CV Boot - Products - Off Road Solutions
Yesterday though boot of the boots popped off on me while offroading and trashing my axles. At this point I can't recommend anyone to use the stock clamps, order some clamps from mcmaster and clamp that thing on solid. Its better that you rip the boot slightly rather than have it fall off.
APhelps is offline   Reply With QuoteReply With Quote
Old 02-02-2020, 11:29 PM #5
pluton's Avatar
Real Name: Keith
pluton's Avatar
Real Name: Keith
Have you priced it a Amayama or Partsouq? Lightweight items like these are usually shipped at reasonable rates, at least to California.
Old 02-03-2020, 10:22 PM #6
Unfortunately even my usual Amayama is too expensive. $150 per axle, not including shipping :O
I was browsing the Rockford CV catalog and I think the 335-10A (for a 1995 Jetta) should fit on the outer joint. The less ribs should also help with the rubbing.
http://www.rockfordcv.com/pdfstore/Boot_Assemblies.PDF
The dimensions I measured on my spare OEM CV axle are:
Inner shaft OD: 1.27"
Outer CV housing OD: 3.67"
CV boot height when installed: 4.25"
Number of ribs: 6
Assuming the dimensions of this alternative are correct, RockAuto even has some relatively inexpensive boots for a 1995 VW Jetta that are made of thermoplastic.
The inner CV boot I will just continue to use the neoprene ones but with a boot stretch mod.
Old 08-02-2020, 01:06 AM #7
FunBobby's Avatar
FunBobby FunBobby is offline
FunBobby is on a distinguished road
FunBobby's Avatar
@nobb did you ever try the Jetta boots?
FunBobby is offline   Reply With QuoteReply With Quote
Old 08-02-2020, 07:18 AM #8
Yes I did. I'm running the Rockford 335-10A as the outer boot and it's working great so far. Definitely a much higher quality boot than anything from those reboot kits. Only disadvantage is that the pleats are larger so there is some small rubbing on the LCA rivet under full droop. Unless you're doing crazy flexing offroading this should mostly not be a problem.
Unfortunately I couldn't find a cost effective inner CV made from thermoplastic so I'm sticking with a standard neoprene boot. I did install a differential drop which has greatly helped with the angles so we'll see how this holds up.
boot , kit , numbers , part , thermoplastic
U-Joint OEM Toyota replacement part numbers Billynath1988 4th Gen T4Rs 2 11-29-2018 03:10 PM
Part Numbers for Double Cardan Joint mtbtim 3rd gen T4Rs 17 01-03-2017 08:22 PM
Upper ball joint boot leak—replace UBJs or just boot kit? starclassic 3rd gen T4Rs 4 07-31-2016 02:50 AM
U-joint part # (numbers) Dzaster Classic T4Rs 3 12-15-2010 09:07 PM
Replacing CV Joint Boot MCT4Runner 4th Gen T4Rs 3 02-06-2009 01:17 AM
