Old 02-02-2020, 05:22 PM #1
ultimatt ultimatt is offline
ultimatt is on a distinguished road
Sunroof Leak Seal - DO IT
So had a sunroof leak the other day and was pretty sure it was not the sunroof drains.
From another thread tried this solution - YouTube
Start the video at 32:20
This seam on the front of my roof was the source of the leak. If you have a 3rd Gen with a sunroof I recommend you seal this spot even if its not currently leaking.
ultimatt is offline   Reply With QuoteReply With Quote
Old 02-02-2020, 05:31 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I sealed my few at that seam point mine one was seeping there.
Old 02-20-2020, 02:41 AM #3
Its GSatt Its GSatt is offline
Its GSatt is on a distinguished road
Thank you for pointing out that point in the video! I never made it that far looking for my leak that’s definitely going to be fixed by sealing that seam
Its GSatt is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 05:07 AM #4
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
So what is the failure point? Cause?
Just curious before mine starts....
Old 02-20-2020, 12:03 PM #5
jkoni426 jkoni426 is offline
Real Name: Joe
jkoni426 is on a distinguished road
Real Name: Joe
Yup had the same leak on mine, sealed it up with some black rtv.
'99 T4R SR5 V6 4WD Imperial Jade Mica | 199mm TBU
jkoni426 is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 01:22 PM #6
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Many times in life, patience pays off. Even though the video is 38 minutes long, there's nothing stopping you from skimming forward to see if there's anything else interesting to watch and learn from a video. Same goes for long write-ups or long forum threads. Skim through and seek out the information you're looking for.
Old 02-20-2020, 01:24 PM #7
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I think it's sun and time. I bet people who park outside are more likely to have this occur. The plastic trim around the sunroof shrinks from the heat of the sun over time. That's my guess.
Old 02-20-2020, 01:27 PM #8
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Yup it's sun damage. The crack runs deep and you can also see it from the inside.
Old 09-02-2022, 10:12 AM #9
Boreas Boreas is offline
Boreas is on a distinguished road
I finally figured out my sunroof leak and the fix wasn't too hard.
First, many people don't realize the seals on the glass are NOT designed to keep water out. This is why there are 4 drains - one per corner. I flushed my drains, and had good flow, but still was getting leaks at the front drains. So I bought a tool to clean the tubing (brush on a cable), thinking the flow was just impeded with filth. In so doing, I was a little too aggressive, and knocked the tubing completely off of the drain. Ugh. Small leak to HUGE leak!
I had feared the headliner removal scenario, tried and failed the impact driver removal of the A-pillar hand grip. So out of frustration, I just removed my visors and carefully pulled the trim away above the doors (did not have to remove) and pulled the corner of the headliner away from the roof. My headliner was water stained/damaged so was far from pristine anyway. I damaged (bent/wrinkled) the headliner a little, but was able to access the front drain. All looked well, and as I suspected, the Tygon tubing was stiff and the cheap wire clamp wimpy, so it was TOO LOOSE on the drain fitting, and would weep every time water went down the drain. Most water would drain, but some always leaked out. So, working through the small corner of the headliner, I cut about 3/4" off of the end of the tubing to achieve a smaller ID, then used a manly hose clamp to reattach the tubing. Then replaced the headliner. The only permanent damage was a wrinkle or two. Fine with me.
Repeat on passenger side, but had to remove the grab handle on the roof which was easy. Same scenario and fix on the passenger side.
LEAK FIXED!!!
I would start a new thread with this fix, but am not worthy yet - not enough posts.
Boreas is offline   Reply With QuoteReply With Quote
leak , roof , seal , source , sunroof
Anyone seal their sunroof? kolelt 3rd gen T4Rs 18 02-09-2019 01:00 PM
Sunroof Seal lonkelm 4th Gen T4Rs 3 06-23-2015 03:45 PM
Sunroof Seal lonkelm 4th Gen T4Rs 0 06-17-2015 09:44 PM
She's taking a leak! Rear axle seal leak that is.... fightman80 3rd gen T4Rs 76 09-18-2014 04:52 PM
Sunroof seal separating... werD 4th Gen T4Rs 0 10-22-2010 12:23 AM
