Old 02-03-2020, 09:41 PM #1
jimmyrecluse jimmyrecluse is offline
jimmyrecluse is on a distinguished road
Replacing ball joints and outer tie rods - anything else I should hit while I'm there
I replaced my steering rack 2 years ago, so the inner tie rods should be good, the boots are perfect at this moment .
The ball joints are not torn but they are pretty greasy and I have no idea if or when they were replaced, I'd rather be safe than having one fall apart while driving
My plan is to use oem outer tie rods but what has your experience been with aftermarket units? I'm thinking an aftermarket grease- able set. Generally when it comes to bearings and movable parts, I stick with OEM but thought I would ask
Since I will need to get the alignment done, I am thinking about replacing the bushings in the upper and lower control arms. Would you go with polyurethane energy suspension parts, or stay with OEM? I don't mind the stiffer ride or increased noise and vibration with the polyurethane. But I would like something that is going to last the longest
jimmyrecluse is offline   Reply With QuoteReply With Quote
Old 02-03-2020, 10:17 PM #2
mmw0k7o mmw0k7o is offline
mmw0k7o is on a distinguished road
How did the steering rack bushings look when you replaced it? What about the sway bar bushings? Say bar links are another item to consider. The upper and lower control arm bushing are a pain to get out. After hitting mine with a torch and then using a bottle jack I was able to get one side out. In the process of trying to get the other side out I bent the control arm. I ended up replacing the upper and lower control arms on both sides. The other item that you may consider are the cam adjuster bolts. Mine were so rusted together that I had to cut them to get the lower control arms free. I just finished a total front suspension rebuild and used Moog parts. I just finished so I can't speak to the long term viability of the Moog parts. They all went together nicely. The only exception was the sway bar link concave washers wouldn't fit, so I used the old ones. I attached a parts list that may help you...
mmw0k7o is offline   Reply With QuoteReply With Quote
Old 02-03-2020, 10:45 PM #3
Awesome input, thank you! I did order 8 new BJ bolts, ill look at my cam bolts - Cali car.
I have a ball joint and bushing press so I hope I can get those out with the presses
Having done the job already, would you have done anything different?
Aftermarket control arms or just buy the oem arms with bushings? I'm thinking about going with the white line bushings
Old 02-03-2020, 11:33 PM #4
Originally Posted by mmw0k7o View Post
How did the steering rack bushings look when you replaced it? What about the sway bar bushings? ..
I used energy bushings when I did the steering rack, I need to look at the sway bar set - that crossed my mind also
Old 02-03-2020, 11:39 PM #5
plcfcng's Avatar
plcfcng plcfcng is online now
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
Don't for get the brakes obviously, Transmission cooler lines are also worth a look.
plcfcng is online now   Reply With QuoteReply With Quote
Old 02-03-2020, 11:59 PM #6
Definitely things I should look at while down there, I just finished the tundra 231 mm upgrade and installed an all aluminum radiator with new transmission coolant lines.
Good there
Anyone do wheel bearings at the same time? Any reason to?
Old 02-04-2020, 09:25 AM #7
If I had the job to do over again I would have brought the upper and lower control arms to a local machine shop. There is an old school machine shop here in town that would not have charged much to press the bushings out and in. I was only using an Bernzomatic torch. I don't think it was getting the control arms hot enough. I've read that you need to hit them with an acetylene torch.
The new Moog control arms cost $344. The alternative would have been about $100 for the performance bushing set and around $25-50 in machine shop fees. $200 savings vs. shiny new control arms? Considering the rest of the car is certainly not shiny I would have rather had the $200 bucks.
aftermarket , ball , oem , rods , tie
GES ball joints / tie rods Bijan 3rd gen T4Rs 21 09-05-2018 01:35 PM
Tie rods and ball joints - where to buy?? Tstinson 3rd gen T4Rs 11 04-18-2017 09:08 PM
Ball Joints and Tie Rods larrylegend 3rd gen T4Rs 15 09-03-2013 09:31 AM
Questions: Clicking CV axle, leaky outer tie rods, leaky ball joints, etc. econhonda 3rd gen T4Rs 3 05-16-2011 08:25 PM
