Old 02-04-2020, 10:37 AM #1
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
All pro UCAs questions
I have a 3inch OME lift on my 99. I extended sway links and pan hard as well. My UBJ appear maxed out now. I also get rub on the control arms at full tilt.
I'm chasing a clunk which I believe is either my ball joints maxed, or sway bar rubbing.
Either way with the rub I need to change my UCAs.
So my question is anyone run All Pro UCA with 285s, does it correct the rub issue once alignment is done?
Also will moving to the uniball design correct the ball joint maxed out issue?
Thanks in advance.
G_Raw is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 01:10 PM #2
MattJakobs's Avatar
MattJakobs MattJakobs is offline
Real Name: Matthew
MattJakobs has a spectacular aura about MattJakobs has a spectacular aura about MattJakobs has a spectacular aura about
MattJakobs's Avatar
Real Name: Matthew
Thanks in advance.
I'm running the All Pro UCAs with 285s with no problems.
If you're rubbing on the UCA, it would be a combination of the UCAs and the BS on the wheels. The All Pro UCAs don't stick out as far as the OEM ones so I'm sure you'll have some help either way. For reference, I'm currently on 16x8 Konigs with a 4.5" BS.
Since running the UCAs, my ride quality improved, alignment was fixed, and my travel was increased. Would recommend for sure.
2002 Stellar Blue Pearl - Build Here
Instagram: mattyjako
MattJakobs is offline   Reply With QuoteReply With Quote
Old 02-04-2020, 01:56 PM #3
G_Raw's Avatar
G_Raw's Avatar
I'm running stock 5 stars wheel wise. I'm also armored and winched upfront if that factors into things. My UBJs are sitting at a pretty tweaked out angle too I noticed.
correct , issue , maxed , pro , rub
FS: 3rd Gen Running Boards (6Q7) and Stock UCAs [NorCal/will ship UCAs] mesooohoppy For Sale: T4R Items 3 08-16-2019 11:49 AM
Toytec Ultimate Lift Kit: UCAs or not to UCAs... W8kbrder 5th gen T4Rs 35 09-15-2013 10:23 PM
LR UCAs or Camburg UCAs kylebacc Engines / Suspension / Wheels / Tires / Audio / Accessories 6 08-29-2013 04:43 PM
ucas!!! slowteg97 Want to Buy/Trade 3 12-08-2012 05:04 PM
UCAs for OME? CU.T4R Engines / Suspension / Wheels / Tires / Audio / Accessories 2 11-09-2010 08:20 PM
