02-06-2020, 06:07 AM
Anyone have recommendations on a good spring compressor for struts?
So i probably could have purchased one of these by now with all the money I've spent at the local tire store to use theirs, but can anyone recommend a good spring compressor? The two below are premium ones but I'd rather not spend quite that much, this is the design I would like to have though:
https://www.amazon.com/Branick-7600-...e%2C160&sr=1-7
https://www.amazon.com/OTC-Tools-663...omotive&sr=1-5
I also found this, a little cheaper but still a lot of money:
Manual Screw Type Floor Mounted Strut Spring Compressor
I'm just not found of the free Autozone style spring compressor, they're a pain to work with and can be dangerous...I'm ready for a decent one.
Thanks!
2002 4Runner Sport Edition-285/75R16 Duratracs, OME suspension, TRD wheels, Shrockworks front/rear bumpers, White Knuckle sliders, etc.
02-06-2020, 10:03 AM
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
Sorry! Something went wrong!
Thanks!
I have been searching for a nice one for a long time as well
I want to find this style used in vid... the only ones like this are pretty spendy.
YouTube
Sir Tools ST9050 Portable Strut Master Strut Compressor SIRST9050
I have been using my harbor freight press and it works ok. please post back if you find one you like.
02-06-2020, 10:52 AM
I have one like this that I bought at Princess Auto (Canadian version of Harbour Freight) about 15 years ago on sale for about $140.00 CAD. Have used it many times, you should be able to find one even cheaper in the USA
Strut Spring Compressor Hydraulic Automotive Coil
I like that the forks/claws that contact the coils have a rubberized coating on them and that they can be seperated from the tool so you can set them where you want on the strut then line it up and attach them to the tool before you start compressing....
02-06-2020, 10:53 AM
02-06-2020, 01:40 PM
It might not be very helpful for other cars, but I've become a fan of the no compressor method when I've needed one for my 4runner. Safer than the cheap sketchy options at autozone and much cheaper than buying one.
"Bettie" - 1998 4runner LTD E-Locker Evergreen Pearl 275K+, Alpine HU, Infinity Reference Speakers, Airraid MIT, B&M Cooler, Light Racing UCA, RCI skids, Bilstein Tundra 5100 and 4runner Eibach Coils in front/ Bilstein FJ 5100 and OME 890 rear, LC80 wheels wrapped with MT Baja ATZ 285/75/16, 99+ overhead console, 99+ center console, sound-deadening, Ditch lights
02-06-2020, 01:47 PM
Real Name: Todi
Real Name: Todi
+1 for the no compresor method
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
02-06-2020, 02:05 PM
official vendor
official vendor
I've been eyeing the ones below for a couple years. Haven't pull the trigger on one yet since they wouldn't get much use. The one from Jeg's can easily be converter to to air over if you wanted.
Mike
Jack Tek
Jegs
02-06-2020, 04:21 PM
Same situation looking for a good quality spring compressor & something safer than the rentals. My next set of coilovers will most likely not have a threaded shock body, like my current ones do, for easy adjustment. With the amount of times I go back & forth between lift heights on new coilovers until I find a position that works I think it would almost be worth it to buy a good compressor & much more convenient than having to take it to a shop every time.
Do you mean using a floor jack like in this video? I can see how this method can be useful for disassembling the coilover but wondering if it would work for reassembly if you wanted to raise the spring perch position?
YouTube
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
02-06-2020, 04:39 PM
YouTube
Yes, that method. Not ideal, but I did it with a bottle jack and it worked fine. I've used it to raise and lower the spring perch. It's probably a little more time consuming having to essentially take it all apart to raise the clip, but it's quicker and cheaper than if you have to take the whole coil/shock into a shop to have them do it, or buy a spring compressor.
I probably spent over $100 taking coils back and forth to a shop to have the clips raised, and then lowered and in the end they didn't clock the springs correctly. If you do it once, taking your time, the other side will take half as long
02-06-2020, 04:47 PM
Originally Posted by Brian.
Harbor Freight sells the same tool, ~$50 with a coupon. Used it for a recent strut refresh.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
02-06-2020, 06:04 PM
This is a good subject to cover. It is super important to know that basically all tools in the lower price categories are absolutely not meant to be used on our style of springs and struts. That should become quickly obvious as soon as you start to use them, they are simply inadequate. The amount of tension needed to collapse our springs enough (even in stock form, let alone preloading onto a 5100 shock) is extremely high compared to the tools intended use.
These low budget tools are intended to be used on passenger car Macpherson strut style springs which are longer, wider, have fewer wraps, less spring rate and more room to maneuver the tool between the coils and they do make that job fairly effortless.
I have a mid tier quality spring compressor like the one I pictured below and had been mentioned in the thread earlier. It is still barely adequate for our springs, with the heads barely fitting through the provided gap, and taking some serious effort to compress the spring. Putting a stiffer coil onto a 5100 is literally at the threshold of the tool's capability.
If someone was seriously considering dropping coin on a tool that's meant to do the job quickly, safely and effectively, the OTC strut tamer extreme linked in the OP's post is the proper tool to get the job done as that was actually designed to do it. It'll take a lot of work to make it worth $800 though, so at the end of the day I still recommend finding a local shop to do that one part of the job for you. It may seem like a waste of time and money, but you really don't want to be on the business end of that spring if something goes wrong.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
02-06-2020, 06:16 PM
I've used the cheaper one that
@ Drew76
mentioned, found it on amazon for around $100-130 bucks but it the teeth bent while compressing-it was a little sketch. I now own a Branick 7600 that I found on craigslist for around the same price. It is much safer to use. I've helped others with their 4runners, Tundras and FJ's so I definitely got my moneys worth. I will say it takes up a lot of space though. I would love to find an OTC strut tamer and give it a try but the Branick is found in every shop that does struts/shocks. It's an industry standard.
02-06-2020, 08:17 PM
@ Drew76
Really? I've used mine dozens of times on all sorts of vehicles, the only problem I had was the original long travel jack stopped working after like 10 years (new similar jack was more $ than the whole tool), I replaced it with a normal bottle jack that is from the 80's/90's and probably better quality than the new ones and some heavy wall square tubing as spacers to make up the difference in height, used it last to compress some Bilstein 6112 front coilovers no problems
02-07-2020, 03:44 AM
I have the OEM brand that I got from autozone. It has a solid design.
02-07-2020, 05:32 AM
Thanks for the feedback and recommendations, I'm kinda leaning toward the Jack Tech style now. Will let you all know how it works out
