02-08-2020, 08:56 AM
Trying to correct my UCA rub
I'm running an OME 3inch lift, armored with winch upfront . I have 285s on stock 5 stars. I make contact wit UCAs at full tilt or if straight and stuffed. I know the discussion starts with UCAs being changed vs wheels with back space change. My question is which is going to give me more resolution to the situation? Both arent necessarily cheap. I know I may need to make both changes in the end. Just asking for your folks opinion in where to start between the 2...
Thanks in advance.
02-08-2020, 09:57 AM
Thanks in advance.
If your upper control arm is contacting the wheel or tire you need new wheels with different backspacing or wheel spacers. New wheels are going to cost $400-$1200, UCAs $400-$700, wheel spacers under $100
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
02-08-2020, 11:39 AM
Real Name: Sean
Real Name: Sean
As mentioned above, I would start with wheel spacers first as the cheaper option. Definitely upgrade your UCA's when you can. New wheels would be my last resort.
I ended up getting spacers and SPC UCA's with my Tundra split spoke wheels. Works great. I'm looking into buying new wheels now, but mainly for personal preference, rather than performance. I want a different look while going back down to 16's. Good luck.
02-08-2020, 01:16 PM
Or you can shave the UCA.
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
02-08-2020, 02:22 PM
Real Name: Tim
Real Name: Tim
Hate to be that guy but this is an issue you could have found out about with a little bit of research before purchasing the tires. Pretty much everybody and their brother knows 285's will rub the stock UCAs without wheel spacers or different back spacing rims.
I'm not trying to be a dick. I'm just mentioning the obvious that maybe others didn't want to say. Before spending over $1k on tires, you would have realized the issue and maybe either decided to not go with 285s or you would have saved more money so you could purchase wheel spacers or aftermarket UCAs to make your chosen tires work better for your rig.
02-08-2020, 04:20 PM
official vendor
official vendor
I second shaving the uca. I hate wheel spacers, and wouldn't recommend ever running them. Of course you'll need a welder or know someone with a welder. If you go this route I would purchase a used set from eBay or from a member here. Pop out the old bushings, and then shave the uca's. Install some new bushings, and install them.
Mike
02-08-2020, 05:03 PM
I think I might have a shaved set somewhere in my shop - if I can find them. Was going to use them on my son's 4runner but then I flopped it wheeling and totaled it.
02-08-2020, 10:07 PM
Tim you're not being a dick perse...I did know they'd rub. In fact I discussed it with you in a PM where you stated Camburgs UCA corrected your issue for the most part I believe. We even then discussed other brands like SPC and Total Chaos which you gave me your opinions on.
Hey Tim,
TBU went well and rear drums got new bleeders in. Now I have gotten mixed messages with my search of the forums about lift to tire size ratios. I know you have not only done a bunch of lifts for folks but have seen a bunch of 3rd gens lifted with various tires. I was going to do OME HD lift front and back with armored bumpers. I was thinking of putting 285/75r 16's on. Some people say no rub, some run spacers, some say minimal rub. Am I being overly ambitious to go that large? I don't want to run spacers at all. I'll be using my stock 16x7 5 stars.
I appreciate your input and help with my build.
Mtbtim response:
How tall of a lift is that? Will your lift include aftermarket upper control arms. With 285s and no spacers, your tires will rub on stock UCAs. The rear shouldn't be a problem. It's mostly the front. I have that size tire on my rig with a 3 inch lift and Camburg UCAs. My tires will rub in the wheel wells sometimes, usually when I turn and hit a hard compression.
:End quote:
So I knew what I was getting into.
With the that said. I refuse to run spacers for my own personal reasons.
Looking at the space between tires and UCAs I'm skeptical to think swapping UCAs will correct the situation. Although it would help my UBJ angles.
I really wanted to stick with stock wheels and while I knew the back spacing would be a potential issue. Based on our conversation I was optimistic about UCAs correcting most of the rubbing. But now im thinking the wheel backspacing is the greater issue.
In terms of running shaved UCAs while I appreciate the offer
@ rkntoy
but if I'm swapping UCAs anyways I'd rather use uniball and correct my ball joint stress.
So as stated in my original post I know I ultimately may need to change both my wheels and UCAs. I guess the question can be rephrased as at what back spacing on wheels will I start to see a better correction to the rub vs changing the UCAs?
Or rephrased as at what point does changing wheels with back spacing to correct my UCA rub start to create other contact issues in exchange for that less uca rub?
Or will a specific UCA create less rub than others?
Or what's the most efficient order of operations for this correction? UCAs then wheels? Wheels then UCAs? Does one of these corrections correct more than the other?
I think anyone who ends up here( these forums) all know the issues we are getting into when moding our rigs.or that we will run into issues in this process. Im purely looking for first hand expierence in correcting this issue I'm currently having based on the specific setup I have, which others don't specifically list in other threads I've searched.
02-08-2020, 10:32 PM
I have loved my SPC arms. Consider them if you are going to want to tweak with your caster down the road.
02-08-2020, 11:05 PM
I wasn't rubbing my UCAs on 285s with a 3" lift. Problem is the car drove terrible, couldn't get the proper caster. (3 spoke wheels though)
02-09-2020, 12:06 AM
Real Name: Tim
Real Name: Tim
You obviously aren't related to Everyone and Their Brother then.
02-09-2020, 12:09 AM
Real Name: Tim
Real Name: Tim
Hey Tim,
Mtbtim response:
:End quote:
@ rkntoy
The UCAs alone will correct it. I'm running stock 5 spoke wheels on my 98 with Camburg UCAs and no rubba dub dubby.
02-09-2020, 12:11 AM
haha!
Well I did/am running BFG KO2s which run a bit smaller than most 285/75/16s or so I'm told. This forum is sort of a mixed bag of information (unfortunately) since you'll find people who say A or B and etc. etc.
I will say a body lift and proper backspacing is the way to go when it comes to having the right setup.
02-09-2020, 12:14 AM
I appreciate that comment Aphelps as it further proves mixed messages I've gotten in my searches. You state clearly no rub with 285s, but run a different wheel and no mention of lift setup. This is sort of comment is what makes assessing and weighing decisions hard. We all get different results, and don't always provide all relevant information. This is to not say you're at fault of anything. I'm just using your comment as a means to an end for my explanation.
My concern with spc while being at a cheaper ( and more attractive) price point is the adjustability, and potential slipping of that adjustability causing alignment issues with heavy use.
I hear good things about built right as well. Anyone run those? Cost on those?
UCAs with wheels back spacing of 4 sufficient to resolve UBJ stress and uca rub? I guess this opens a different can of worms into pinch weld smashing and heatgun fender lining molding?
Damn rabbit holes. One upgrade leads to another
02-09-2020, 12:21 AM
I did mention I was running a 3" lift. ;)
I run built right UCAs, nice uniball design. I think I paid 600 or so for them. My next mod is spindle gussets that's for sure. That's a piece breaking that has me worried.
