Old 02-08-2020, 04:50 PM #1
benjamin247's Avatar
benjamin247 benjamin247 is offline
benjamin247 is on a distinguished road
Wheel bolt length greater than 27mm?
Planning on getting 1.5 wheel spacers to have my wheels stick out a little more. Current wheel has +15mm offset. The spacer manufacturer recommend having the original wheel bolt length to be 27mm or more. Do 1999 SR5 (Highlander Edition) have bolts longer than this?
1999 Black SR5 5-speed 4WD Rear e-locker
Suspension: Toytec 3" Ultimate Lift, JBA STD High Caster Upper A-arms, Eimkieth PCK
Wheels/Tires: Method 305 NV Bronze (16x8 | 0/4.5"), Goodyear Duratracs 285/75-16, 1.25" Spidertrax Wheel Spacers
Others: SRQ Fabrications Flush Grille, TJM T17 Front Bumper, Magnuson Supercharger, URD 7th Injector, Rock Gray Avery vinyl wrap, TG Sliders
benjamin247 is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 12:25 PM #2
yotamonkey yotamonkey is offline
yotamonkey is on a distinguished road
I went with Spidertrax Spacers and it bolted up like normal and then had studs on the other side that the wheel bolted to.
yotamonkey is offline   Reply With QuoteReply With Quote
27mm , bolt , bolts , length , wheel
Length of rear wheel studs Vs front(spacers install) benztech82 4th Gen T4Rs 22 06-21-2023 08:01 PM
Anyone change wheel studs to longer length? hrod79 5th gen T4Rs 12 02-28-2022 06:32 PM
Nut & bolt rather than rivnut install on full length Front Runner Rack? MtnMan219 5th gen T4Rs 22 06-10-2020 01:25 PM
Question on Wheel Stud Diameter and Length 77Bronc 5th gen T4Rs 2 03-27-2016 03:30 PM
Body Lift Block ID/Bolt length- Steering Shaft bolt length 02_SE_Runner 3rd gen T4Rs 6 03-15-2013 09:57 AM
