Old 02-08-2020, 11:36 PM #1
MarkBlack's Avatar
MarkBlack MarkBlack is offline
Real Name: Mark Black
MarkBlack is on a distinguished road
MY GARAGE
MarkBlack's Avatar
MY GARAGE
Issues with start up
I have a 97 with a 3.4L.
The other day my 4runner wouldnt start, so i changed the terminals and it started right up. But later in the day my 4runner struggled to start. After a few attempts it started. It cranked and wouldnt start and than It putts'd and than died.
I dont think its the fuel pump. My alternator and battery are working fine. I have already replaced the starter and fuel filter. So I am thinking it may be the crankshaft sensor, its about $100 so I figured Id ask you guys your opinions before I make a $100 guess.
Does anyone have any advice, or been in a similar situation.
It only happened that one day. But i don't want this to happen on my next road trip.
MarkBlack is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 11:43 PM #2
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76 is just really nice brillo_76 is just really nice brillo_76 is just really nice brillo_76 is just really nice brillo_76 is just really nice
MY GARAGE
brillo_76's Avatar
Real Name: Jon
MY GARAGE
Hmm... hard starts is mostly fuel related at times. How good is your fuel filter and what's your pressure at the rail?
2 seconds max and that rig should fire up.
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 02-09-2020, 07:02 AM #3
19963.4lsr5 has a spectacular aura about 19963.4lsr5 has a spectacular aura about
When was the last time you did a tune up?
AKA spark plugs etc.....
that also sounds like water in the gas and a bottle or two of “dry gas” will fix that.
Old 02-09-2020, 01:57 PM #4
brillo_76's Avatar
Real Name: Jon
MY GARAGE
brillo_76's Avatar
Real Name: Jon
MY GARAGE
Excellent thought but all the US gas is ethanol gas so 10% of the gas is dry gas already. Unless they run straight normal gasoline that costs a lot more. So it would take a pile of water to mess up your gas but possible. :-)
As it has to be a fuel or ignition issue as vacuum leak would be unlikely.
OP. No pending codes coming up??
Old 02-09-2020, 02:22 PM #5
Soren96 Soren96 is offline
Soren96 is on a distinguished road
That could also be crank sensor. I normally wouldn’t consider that except that it happened on my ‘98 VW. Though my only symptoms were either the engine just flat out shutting off with no sputters or refusing to start. It was indeed the cps.
Soren96 is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 02:53 PM #6
brillo_76's Avatar
Real Name: Jon
MY GARAGE
brillo_76's Avatar
Real Name: Jon
MY GARAGE
Mostly crank sensors just die though. Unless someone has had a cases of intermittent failure.
That can be easily checked with a bluetooth reader and an app like torque pro. Will let you read the crank senor. If cranking and it reads 200 then its functioning.
Old 02-09-2020, 03:16 PM #7
Hokie-Pokie VT's Avatar
Hokie-Pokie VT Hokie-Pokie VT is offline
Hokie-Pokie VT is on a distinguished road
MY GARAGE
MY GARAGE
Crankshaft sensor would likely be throwing a code (P0335). Especially if it can complete the startup process and get to idle for at least a second or two it will notice that something is wrong and turn on the CEL. I would continue to look at the fuel system, the intake system (the IAC valve, MAF, and the throttle assembly), and spark system (plugs and wires).
Best of luck.
2002 4Runner SR5 4WD
Hokie-Pokie VT is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 06:08 PM #8
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
I know time and money are not always abundant you need to have a base line when trying to find out whats wrong. I see that you did the fuel filter you also need to take a look at the Air filter and the spark plugs and wires. If you have the history on them then fine if not you may want to replace them look at the plugs do a google search on how spark plugs pics. They should all look the same white or a little tan on the insulator.
If replacing them go with the double sided ground not doing this can cause issues. When putting them back I use a Torque wrench the last thing you want to do is strip out the threads in the head. (HF have a decent torque wrench really cheap or borrow one.)
Checking fuel pressure is a bit involved you need to search some one out to help with that or take it in to a shop. Keep us up to date
plcfcng is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 12:03 AM #9
MarkBlack's Avatar
MY GARAGE
MarkBlack's Avatar
MY GARAGE
I replaced the spark plugs less than 6 months ago.
Old 02-10-2020, 12:05 AM #10
MarkBlack's Avatar
MY GARAGE
MarkBlack's Avatar
MY GARAGE
I checked all the vacuum hoses and nothings messed up, I replaced the plugs and used an OEM fuel filter. An no codes are coming up
I need to look up how to check the fuel pressue. Im not sure what it is at or how to check it.
I drove the 4runner around all day and it struggled to start once out of the 10 times I started it up. So it seems pretty intermittent.
Old 02-10-2020, 12:05 AM #11
MarkBlack's Avatar
MY GARAGE
MarkBlack's Avatar
MY GARAGE
Plugs have been replaced and I just installed a cold air intake a month back, so the air filters brand new. Also the spark plugs are new.
Old 02-10-2020, 12:39 AM #12
MarkBlack's Avatar
MY GARAGE
MarkBlack's Avatar
MY GARAGE
Mine struggles to start, it sputters and then dies. So maybe its not my crank position sensor.
Old 02-10-2020, 12:17 PM #13
thegipper's Avatar
thegipper thegipper is offline
thegipper has a spectacular aura about thegipper has a spectacular aura about
thegipper's Avatar
You'll need a banjo fuel fitting adapter like this one: Banjo Bolt Fuel Pressure Tester Adapter Asian European M12x1.25 thread Gauge | eBay
Then you just need any standard fuel pressure gauge that accepts a 7/16"-20 threaded schrader fitting (this is the standard size usually).
Search on the forum to find out the fuel pressure specs.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 02:49 PM #14
JMat's Avatar
JMat JMat is offline
JMat is on a distinguished road
JMat's Avatar
I would seriously doubt it's the crank position sensor... When mine went out it just wouldn't start one. Just nothing. Wouldn't even sputter.
As stated earlier it's super easy to find out with an OBD2 reader... If it shows RPM's when it's turning over its not the CPS.
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
JMat is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 05:27 PM #15
MarkBlack's Avatar
MY GARAGE
MarkBlack's Avatar
MY GARAGE
I took it O rilleys and had them use the reader. It didnt show anything.
$100 , figured , fuel , issues , start
Intermittent Start Issues johnsIslander 3rd gen T4Rs 17 08-25-2014 05:36 PM
cold start issues the great him 3rd gen T4Rs 6 11-07-2013 09:04 AM
Remote Start issues 014runnerowner 3rd gen T4Rs 0 07-08-2013 08:28 PM
Start Up Issues MoRamBen General Discussions 0 10-02-2011 09:54 PM
cold Start up issues rubbman 3rd gen T4Rs 0 02-04-2009 06:49 PM
Copyright © 2019
