Old 02-11-2020, 10:34 AM #31
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by 19963.4lsr5 View Post
I tried the non ethanal gas and all I did was waste 50 cents per gallon. I got the same mpg.
Ethanol wants to absorb moisture so it will pull it out of anything if it’s available.
Could be. I never looked into it. I just dont put ethonal fuel in my classic cars. Also my small engines hate it. So I try to stay away from it in them. My standard cars run it.
Ethanol isnt very stable in gas. Not sure how long it lasts without breaking down.
I wish they just get rid of out of the fuel. Standard gasoline lasts alot longer then the mixed fuel.
Old 02-11-2020, 10:42 AM #32
busmup808's Avatar
busmup808 busmup808 is offline
busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough
busmup808's Avatar
Do you have a scanner that reads live data to make sure you are driving in closed loop instead of open loop.?
What is this closed loop u speak of? I just obtained a scan gauge from my friend and did even read about it. It’s in my truck for a couple of months and I don’t know how to operate it.
Busmup808 all day, all night!
busmup808 is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 10:50 AM #33
The only way you will see if it’s closed loop is if the scanner reads live data. Cheap scanners will only read the diagnostic codes.
Closed Loop is when the engine starts using the front O2 sensor to control the fuel mixture(14.7:1 air fuel ratio) In open loop it runs very rich (around 12:1 air fuel ratio) to not burn up the engine. The extra fuel it uses running rich will effect fuel milage and it can also gas your oil.
Old 02-11-2020, 10:52 AM #34
I run high test in all my small engines. Ethanol has never been a problem for me. High test will last a year untreated before it starts to skunk.
Old 02-11-2020, 11:54 AM #35
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
I've got about 27 years under my belt as a motorcycle mechanic, so I've worked right through the change in fuel. "Bad" gas can be a whole lot of things, but when talking about age it nearly always comes down to oxidization. Pure gas can go about a year before it starts having issues, same was true for the MTBE years (was fully phased out by about 2000). Ethanol fuel can go about 3~4 months, though if you're in a HOT climate, a month might be showing problems. On a similar vein, if the fuel is kept in a sealed container (the new gas cans that don't vent) that's as full as possible (as little headspace/air), it can go longer. The reason for the short time is that the H2O it absorbs is introducing more oxygen that causes the fuel to "varnish" and go bad. It's no longer just the surface touching air, but now it's the moisture being pulled out of the air and into the fluid too....
Octane ratings have NOTHING to do with time before gas degradation. Sorry, you can think that all you want but it's not going to make it true. In some, rare, cases the higher octane fuel have less ethanol (or did, I haven't seen any in a long time), but it's a safe assumption that the base fuel platform is the same for any given brand, and the Only difference is extra additives to rise the octane.
Get into additives like StaBil, and you can get most of a year out of ethanol fuel in most cases (extreme heat and a nearly empty tank would be the major exceptions). I'm sure most of the additives are the same, I've just been a StaBil user for decades and haven't had need to look elsewhere.
If you have small engines that see only occasional use and want to give them the best fighting chance, drain the carb float bowl after every use. No, running it till it stops is not good enough (it'll actually make things worse). Then, fully top off the fuel tank. I've made a lot of money over the years cleaning motorcycle carbs in the spring, the people who heed my advice never come back (well, for that service, it usually earns me a lot of Other work though). those who don't, I get to see year after year after year....
Brian. is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 12:10 PM #36
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I drain my carbs out of all my small engines. I still occasionally have to clean old carbs out because of the ethonal eating the varnish and lacquer out of the fuel system. I believe this is why we are seeing these fuel systems filter and screens plugging up in these 3rd gen 4runners. The ethonal is eating the systems out cleaning it out. I just wonder what components in our systems can be damaged by it?
Old 02-11-2020, 05:26 PM #37
Rpreme Rpreme is offline
Rpreme will become famous soon enough
I've been getting 15-16 mpg with 33' tires. Stock motor, stock body with no armor or added weight.
Rpreme is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 05:32 PM #38
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
My 01 gets between 15.5-16 (on a good day).
Interesting part is my '15 sequoia w/a 5.7 gets better mileage, not by much but it does, 16.5 (mixed in town and highway), haha.
Old 02-11-2020, 05:52 PM #39
lewiswilkinson's Avatar
lewiswilkinson lewiswilkinson is offline
lewiswilkinson is on a distinguished road
I get around 550KM to a tank in my Gen3 1kz-te auto. 2" lift and 33" muddies
lewiswilkinson is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 10:00 PM #40
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Just did 249.8 miles on 14.49 gallons for just over 17mpg. That’s with Costco regular.
That’s with the Volvo MAF in 98 5sp, stock except 265/70r16 BFG AT T/A’s.
I warm up to 120 water temp before rolling
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 10:48 PM #41
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
3rz 5spd 4x4
Average for the last 75,000km
10.98 l/100km or 21.42 MPG
That's total, the good hwy and the bad city included.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 11:04 PM #42
spartacus's Avatar
spartacus's Avatar
Originally Posted by Dieselchessy View Post
Just did 129.8 miles on 14.49 gallons for just over 17mpg. That’s with Costco regular.
129.8 miles on a 14.49 gallons is about 9 miles a gallon or am I missing something?
Old 02-11-2020, 11:10 PM #43
03V84R's Avatar
03V84R 03V84R is offline
03V84R is on a distinguished road
03V84R's Avatar
My 96' SR5 gets 12-14 mpg, 70% freeway @ 60-65mph. I have a Sonoran Steel 1.2(3"lift), a 1" body lift, welded on sliders, full under armor, ARB front bumper, tundra front brakes, a Tepui roof top tent mounted on a Thule system, running 285x70x17 Terra Ridge Grapplers mounted on Method 17x8.5,et 0 wheels. I also have a rear custom drawer system. Its easy to forget its 23 years old and has 160,xxx miles. It dosent burn oil and always starts. I dont think theres any gas driven 4WD on the market today that would get me 20 mpg setup the same way, and it would be a $50,000 truck pre- build!!
03V84R is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 11:25 PM #44
I fixed it. Not sure how I fat fingered that.
Old 02-11-2020, 11:37 PM #45
DerKaiser DerKaiser is offline
DerKaiser is on a distinguished road
17-18.5 calculated mpg average 70% freeway when I'm driving economically. Regular 87 CA gas.
Sunburnt 1999 SR5 4x4 E-Locker Bilstein 5100s OME906 FJ80 16x8 Falken 265/75r16
DerKaiser is offline   Reply With QuoteReply With Quote
gas , i’m , mileage , mpg , truck
