02-10-2020, 01:31 AM
#16
Originally Posted by levee-11
Nope. No roof racks other than the stock one. Now that I’m getting all these responses I forgot to mention I have a 4wd and drive about 20-30 miles a day city miles(only like 6 stops but it’s about 40mph all the way to my destination)
I get 17-18 driving town and city. I get around 220 to 250 a tank and put 12-15 gallons in when I fill up. I probably average 225/13 per fill up. Been doing it for almost 20 years now. Both auto and manual. I’m not heavy on the skinny pedal, but I’m not driving miss Daisy either. Highest hw speed is 70.
If my rig was getting 14 and I wasn’t turning 33’s or pulling a boat Id be looking for something to fix.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
02-10-2020, 04:15 AM
#17
01 4wd. I’m getting on average 260 miles a tank.( tested with about 13 tanks so far). About 85% of it is highway driving
2001 SR5 4x4 Premium
2017 SR5 4x4 Premium
17 SR5
02-10-2020, 07:59 AM
#18
Try cleaning your MAF sensor.
02-10-2020, 09:44 AM
#19
There's a lot of variation in what people define as city driving. My commute is in downtown DC: 2 mi, with a dozen stop signs plus as many lights, which results in something close to 11 mpg.
If you're getting 14 with 6 stops at 40 mph, that sounds a bit below what it should be.
2002 Limited 4Runner
2001 Jeep Cherokee
02-10-2020, 04:00 PM
#20
Originally Posted by UnderFire
Yea, they don't get awesome mileage, I'd expect closer to 16, but there's not any drivability issues so I haven't bothered. It's been steady over 2500 miles and lots of different driving conditions, definitely strange.
Sent from my JSN-L23 using Tapatalk
Do you have a scanner that reads live data to make sure you are driving in closed loop instead of open loop.?
02-10-2020, 04:27 PM
#21
I would also recommend replacing your o2 sensors, oem ones aren’t very much from rock auto and I got at least a 1mpg gain when I did mine, if they are on their last legs you might gain even more. I think the service manual even states a recommended replacement interval though I’m not sure what it is
02-10-2020, 04:33 PM
#22
Eh, the torque converter doesn't lock below 45 (3rd) or 50 (OD), so that is pretty inefficient running.
If you try a road trip on the freeway at ~65 mph, you'll see what it will actually do...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
02-10-2020, 04:47 PM
#23
Real Name: Robert');DROP TABLE Students;
14ish mpg combined on winter fuel with 70% city, 30% highway. 33s, 4.56s, bumpers and sliders.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
02-10-2020, 05:00 PM
#24
For reference:
Mine is a '99 SR5 2WD automatic with a Yakima roof rack, Michelin LT's 265/70/16's and 200k on the clock. Original OEM O2 sensors. Recent aftermarket fuel injectors, NGK plugs and NGK wires. MAF sensor cleaned within last 10k miles.
I get 17-19 mpg around town, and 18-23 mpg on the highway (keeping it under 70 mph). 65 mph is the magic interstate speed for mine - covering ground while getting good mpg. Above 70 mph, and the mpg gets dismal, real fast. I have gotten as good as 23.5 mpg, going from Atlanta to Florida (slightly downhill the entire way), with the cruise control set on 60. I do not give a damn if I piss off people in the right lane on the interstate, "making" them pass me. The speed limit is not the minimum legal speed.
I'm not a candyass on the gas pedal, but I don't accelerate hard. I let off of the throttle early, when I foresee slowing or stopping ahead.
'99 SR5 V6 2WD named Jolene / In the T4R 200 Club
02-10-2020, 07:29 PM
#25
I get 13-14 in the winter, and 15-16 in the summer. About 225 miles a tank, and put about 16-17 gals in usually. If I get 12 on a tank right now, I just shrug and go on.
Type of driving makes a massive difference, as well as everything everyone else has said.
My truck with stock tires would get 375 miles a tank on the highway 5 years ago. That's about as good as you can ask for....but few people get that.
2001 SR5~Thundercloud Metallic~3.4L Auto~4x4~260k miles~TRD 2gen black Supercharger~URD AFR Calibrator~B&M 70264~Bilstein Adjustable w/ tall '99 fronts~ProComp 3" rear springs~Nitto Ridge Grappler 285/70R17's on 17x9 Enduro's~Yakima RailRider w/48" bars~ScanGauge II
02-10-2020, 10:19 PM
#27
Originally Posted by brillo_76
The 3rd gens may not care for the ethonal gas as they were designed to run standard gas. As federally all gas has 10% mixed in. I never did check the difference between straight gas and ethanol gas. I would suspect a slight loss in mpg.
I suspect your suspicions may be right. My averages always seem slightly better north of the border where premium is still non-ethanol at some stations. (and without the price hit non-eth commands in the US)
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
02-10-2020, 10:39 PM
#28
Real Name: Jon
Real Name: Jon
I can buy non ethanol gas at locations about 10 miles away from my house. However, it's mid grade only octane.
02-11-2020, 08:44 AM
#29
Real Name: Matt
Real Name: Matt
Originally Posted by SeaDug
A friend changed his fuel filter and that helped with his mileage.
This... helped me out bit
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
02-11-2020, 09:04 AM
#30
I tried the non ethanal gas and all I did was waste 50 cents per gallon. I got the same mpg.
Ethanol wants to absorb moisture so it will pull it out of anything if it’s available.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
