Old 02-11-2020, 01:27 PM #16
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Originally Posted by 4'running'26 View Post
So when comparing kits on EBay, I found this interesting:
aircabinman's kit:$300
15 Piece 3.4L engine TIMING BELT KIT WATER PUMP Genuine & OE Manufacture Parts! | eBay
grapebaiwan-us's kit: $175
For Toyota 3.4L V6 Engine Water Pump &Timing Belt Kit Tacoma Tundra 4Runner T100 | eBay
It seems like the exact same kit, with the same part numbers listed, but for $125 less. Am I missing something?
I would like to use aircabinman because of his reputation and because I have used his kit before with great success...but $125 in savings is quite large.
Them kits are always annoying. Its hard to get a vendor that tells it straight. Air Cabin Man seems to be one of the good ones.
He offers a kit for $220 that uses a few non-OEM belts and seals.
For those $175 kits the pictures look wrong. The Toyota water pump has "Toyota" and "Aisin" cast into it. The Aisin ones have the "Toyota" ground off and only the "Aisin" still there. In those kits the picture of the water pump has neither "Toyota" or "Aisin" cast into it.
The Rock Auto Aisin kit ($171) only has the timing components and in the water pump pic you can see where "Toyota" and "Aisin" were ground off and an Aisin sticker placed on it. I've installed a few like that.
This is a picture of a Toyota water pump. When you look at the Aisin branded ones you can see where they ground "Toyota" off and often the grind "Aisin" off and then put on a silver Aisin sticker where they ground "Toyota" off. All them "genuine Toyota" kits on Ebay for $174 have pictures of some other water pump sitting on a Toyota box.
https://www.amazon.com/Genuine-Toyot.../dp/B00FZPSSUY
I'm not a loyal Toyota fanboy, so I wouldn't fault a guy for using different belts, tensioner, thermostat. But the water pump is driven by the timing belt and the high tension of the belt puts a fair bit of side load on the bearings of the water pump. And the design is such that the bearings don't have much in the way of leverage. You want Toyota or Aisin for the water pump. Otherwise you risk the bearings wearing and the seal goes out before you get to 90K.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 01:43 PM #17
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
If they are already Aisin, why would the name get ground off and then a sticker put on ? In the "olden" days that meant they were a manufacture reject and someone later put the sticker on
Old 02-11-2020, 01:48 PM #18
I'm guessing there is some branding/marketing agreements between Aisin and Toyota.
I've pulled a few water pumps out of Aisin blue boxes that had both "Toyota" and "Aisin" ground off and a silver Aisin sticker.
Old 02-11-2020, 01:52 PM #19
O2RunnerSR5's Avatar
O2RunnerSR5 O2RunnerSR5 is offline
O2RunnerSR5 is on a distinguished road
There’s a kit on eBay claims everything is Toyota OEM besides a pulley or two. It also say “beware of fake Chinese parts” or something like that. The goes goes for 280$ish. Just know that they do not send you the exact part numbers that are in the description. Water pump and idler tensioner pulley are not Toyota brand but are listed as Toyota and the power steering belt that they send is from a 2.7l Taco. The seller claims it’s the exact same belt but what they list in the description isn’t what you get.
NEW GENUINE TOYOTA 3.4 V6 5VZFE WATER PUMP TIMING BELT KIT 17 PCS 4RUNNER TACOMA | eBay
2001 SR5 4x4 Premium
2017 SR5 4x4 Premium
17 SR5
O2RunnerSR5 is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 02:00 PM #20
In that adds pictures the pump has "Toyota" ground off, but still has the "Aisin" casting and no "Aisin" sticker. That's how they used to come....
Like I said, them kits are annoying. Big game of cat and mouse.
Old 02-11-2020, 02:08 PM #21
4'running'26's Avatar
4'running'26 4'running'26 is offline
4'running'26 is on a distinguished road
Ok, so I think what I take from this is: buy AirCabinMan's kit!
Thanks for the education on this.
--'00--Red--295k--Auto--SOLD
--'99--Green--204k--5spd--TOTALED
--'00--Black--165k--Auto--TRADED
--'14--Blue--250k--Trail Edition
4'running'26 is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 09:15 PM #22
rideexileex's Avatar
rideexileex rideexileex is offline
rideexileex will become famous soon enough
I advise to talk to your mechanic and clarify the work for all parts. Typical timing belt jobs don't include the tensioner, and replacing it is annoying. The AC pump and bracket have to removed - 8 more not super easy access bolts. More labor. Cam and crank seals are also 'extras' and are easy, but again, more time on the typical job.
2000 4Runner Sport - TRD&AEM SuperCharged
Solo Long Travel & KING 2.5 & bumps, 4th gen rear axle & KING 2.5 12's
F+R ARB's, 4.88 Yukon's, 295 KM3s
rideexileex is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 03:00 AM #23
That kit is fine. The kit I got that is mislabeled will still work perfectly fine and all parts are legit. But, The problem is I paid the extra money for the Toyota branding and that’s not what I got. Oh and the belt, That i still dont know if it will work.
17 SR5
Old 02-16-2020, 08:54 AM #24
Mgyver1's Avatar
Mgyver1 Mgyver1 is offline
Mgyver1 is on a distinguished road
Mgyver1's Avatar
Both times I’ve done my timing belt I’ve never done anything with the AC compressor to replace the tensioner. A universal joint and tape like in Timmy’s vid made it a lot easier.
2000 Limited. Lifted....finally!
www.OverlandNV.com
Mgyver1 is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 04:27 PM #25
What special service tools are technically needed for this job? Assume for a moment I was going to do the timing belt, water pump, tensioner, pulleys, crank and cam shaft seals and wanted the special tools...what would I need?
Thanks!
Old 02-16-2020, 06:00 PM #26
Real Name: 3 Bears
Real Name: 3 Bears
Thanks!
watch timmys videos
Old 02-17-2020, 12:14 AM #27
Drillzzz Drillzzz is offline
Drillzzz is on a distinguished road
I bought the Aircabinman kit and let Toyota install all the components for 640 labor and another 24 bucks for some coolant. It took two days but I’m glad I let them do it. They do this stuff day in and day out on 4runners especially here in Colorado. Glad I spent the extra coin on the kit and mainly for the reputation that comes from the buyer.
Drillzzz is offline   Reply With QuoteReply With Quote
Old 02-17-2020, 02:33 AM #28
Tiktiki Tiktiki is offline
Tiktiki is on a distinguished road
I have ordered and received this kit:
https://www.amazon.com/Aisin-TKT-025...g+belt+kit+3.4
It was much cheaper than a Gates or Aisin kit/package from RockAuto.
I can confirm that the pump has Aisin cast in, but Toyota ground. It also has a sticker where TOYOTA would be.
Comes with OE Toyota (with label) tensionner and bearing, and Mitsubishi belt.
Everything in a blue Aisin box, really well packed and padded.
Next week-end my truck gets the whole thing, plus fresh coolant and T-Stat. The seals are in-stock at my local parts store so I will change them if they leak.
Tiktiki is offline   Reply With QuoteReply With Quote
Old 02-20-2020, 05:32 PM #29
nbach218 nbach218 is offline
nbach218 is on a distinguished road
Hello, all.
I hope the dead of winter finds everyone well.
I am planning some spring-time maintenance and first on the list is the timing belt and water pump.
My question is (as the title implies), what are the most important "others" to replace while getting the timing belt replaced? Last time I had the timing belt done (on a different 3rd gen) I bought on of AirCabinMan's kits on EBay. There are quite a few variations out there, both his and others', that use OEM (which is what I plan to do) but I'm trying to decide how much and/or how little I should have replaced. It seems like one could go down the rabbit hole pretty quickly.
For those more in the know than myself, if you were considering this a triage scenario, what would be your order? After timing belt and water pump...idler, pulley, seals, thermostat...?
FYI: I'll be having my trusty mechanic do this.
I'm assuming:
1. Timing Belt
2. Water pump
3. ...
Thanks for your input!
Cheers.
JT
I did pulleys, hydraulic tensioner, cam shaft seals, crank shaft seal, crank shaft bolt as Toyota doesn’t recommend reusing the original as it’s torqued to 217 ft lbs. Thermostat (don’t forget the gasket, radiator if it’s original, and that should do it!
nbach218 is offline   Reply With QuoteReply With Quote
belt , pump , replaced , timing , water
The "real" durability of timing belt and water pump on 5VZFE? BamaDrewski 3rd gen T4Rs 60 10-24-2019 10:22 PM
Timing off due to belt "jumping" on V8. Possible? shayk 4th Gen T4Rs 5 01-17-2018 08:16 PM
WTB: TRD Supercharger "Premium Fuel Only" and belt diagram decals kigmob Want to Buy/Trade 0 01-19-2015 10:05 PM
"Auto Tech" Timing belt. Troubleshoot HELP LCPLHumiston 3rd gen T4Rs 11 06-01-2011 11:14 PM
Timing belt walkthrough on "TRUCKS"! fightman80 3rd gen T4Rs 5 04-21-2011 02:16 AM
