Old 02-10-2020, 12:08 PM #1
4'running'26's Avatar
4'running'26 4'running'26 is offline
4'running'26 is on a distinguished road
Timing Belt "Triage"
Hello, all.
I hope the dead of winter finds everyone well.
I am planning some spring-time maintenance and first on the list is the timing belt and water pump.
My question is (as the title implies), what are the most important "others" to replace while getting the timing belt replaced? Last time I had the timing belt done (on a different 3rd gen) I bought on of AirCabinMan's kits on EBay. There are quite a few variations out there, both his and others', that use OEM (which is what I plan to do) but I'm trying to decide how much and/or how little I should have replaced. It seems like one could go down the rabbit hole pretty quickly.
For those more in the know than myself, if you were considering this a triage scenario, what would be your order? After timing belt and water pump...idler, pulley, seals, thermostat...?
FYI: I'll be having my trusty mechanic do this.
I'm assuming:
1. Timing Belt
2. Water pump
3. ...
Thanks for your input!
Cheers.
JT
--'00--Red--295k--Auto--SOLD
--'99--Green--204k--5spd--TOTALED
--'00--Black--165k--Auto--TRADED
--'14--Blue--250k--Trail Edition
4'running'26 is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 12:23 PM #2
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Lots of posts asking the same question on here.
Here's my take:
1. Timing belt, tensioner, water pump, idler/tension pulleys, crank bolt are bare minimum.
2. Front main seal, cam seals, thermostat and V belts are optional but I recommend doing them also while you're at it.
This kit has it all minus the crank bolt: Toyota 3.4L/V6 Complete Timing Belt & Water Pump Kit | eBay
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 01:05 PM #3
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
I've only ever bought 1 crank bolt, but haven't used it yet. Just bought it to see what all the fuss was about.
I've never seen a kit include one, including those kits sold by Aircabinman and advertised as being "complete".
For me its:
#1:Belt and water pump, then tensioner, tensioner pulley, and idlers.
#2:Replace any seals that leak, or all of them.
#3:Thermostat, alt, ac, ps belts.
#4: crank bolt.
#1 and #2 items are underneath each other and require removal of the Timing belt to replace. But I've run the crank and cam seals out past 200k with no issues.
#3 and #4 items can be replaced at any time with little trouble.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 01:20 PM #4
Bdnewyork's Avatar
Bdnewyork Bdnewyork is offline
Real Name: Robert
Bdnewyork is on a distinguished road
Bdnewyork's Avatar
Real Name: Robert
I too am compiling parts for a TB change. I went for a different Aircabinman kit:
15 Piece 3.4L engine TIMING BELT KIT WATER PUMP Genuine & OE Manufacture Parts! | eBay
To that, I've added:
OEM Crankshaft Bolt - 90119-16006
OEM A/C Idler Pulley - 88440-35060 - Has integral bearing.
Aisin FBT-004 Fan Pulley Bracket. Bracket Assy. contains a captive, non-replaceable bearing:
More Information for AISIN FBT004
As for the other spinning components - I'm holding off on the Fan Clutch, Alternator, PS Pump & A/C Compressor pending physical inspection.
While I'm in there, I will also be doing the PS flush / Pump reservoir filter screen cleaning via Tim's DIY as I have a whine upon cold startup:
YouTube
So i also purchased the OEM PS Pump reservoir o-ring - 90301-11016
Bdnewyork is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 02:12 PM #5
TheSaturnV TheSaturnV is offline
TheSaturnV will become famous soon enough TheSaturnV will become famous soon enough
Do it all, it's cheap insurance.
TheSaturnV is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 04:52 PM #6
cblock406's Avatar
cblock406 cblock406 is offline
Real Name: Christian
cblock406 is a jewel in the rough cblock406 is a jewel in the rough cblock406 is a jewel in the rough
cblock406's Avatar
I would do the radiator and hoses at the same time as well.
Build Thread: http://www.toyota-4runner.org/3rd-ge...ce-thread.html
@projects_always
cblock406 is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 05:01 PM #7
Coward's Avatar
Coward Coward is offline
Coward is on a distinguished road
Coward's Avatar
Here is what I recommend. Do it right!
(Prices last year from Camelback Toyota)
WATER PUMP 16100-6939883 $100.31
IDLER ROLLER 13503-62040 $90.80
TENSIONER ROLLER 13505-62070 $121.40
TENSIONER 13540-62021 $41.60
T COVER GSKT UP 11319-20010 $4.61 I needed
T COVER GSKT LWR 11328-20020 $4.61 I needed
T-STAT 90916-03075 $19.31
TIMING BELT 13568-YZZ03 $43.42
CAM SEALS 90311-38051 $9.82 x2
UPPER RAD HOSE 16571-62070 $15.81
LWR RAD HOSE 16572-62090 $15.75
OIL COOLER O RING 90301-67004 $3.68
WASHER SEAL 90210-22001 $3.73
ALTER BELT 90080-9109083 $16.95
P/S BELT 90080-9112683 $14.63
A/C BELT 99364-2087078 $17.70
OIL CAP SEAL 90430-37140
96' 4x4 5spd-SS1.2
Coward is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 05:12 PM #8
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
This is a good list. Personally, I added the water outlet (16331-62040) and water inlet (16321-62020), because why not! Those are totally optional and I did them because they were taken off to do the timing belt and I didn't want to spend the time to get them all cleaned up. Now I have spares!
weekendclimber is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 05:20 PM #9
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
YouTube
Depending on the miles,,,there is lots you can do...I also did the a/c tensioner pulley and fan pulley bracket ( listed above) also called a false water pump..as it kind of looks like one. I also did my cam and crank seals and thermostat.
An option for is fan clutch which I already had anyway (already had from a previous miss diagnosed bearing noise) but that is easy to replace at a later time.
also as mentioned in other threads, not knowing age or miles...hoses.... radiator. Mine were relatively new at the time ( less than 20k)
If paying someone to do the work, all those parts have to come off anyway..so why not replace with new if you can afford the parts and should not be an additional charge for labor. Again..depends on the miles.
And use Asian Red antifreeze..or Toyota antifreeze with distilled water
Old 02-10-2020, 07:09 PM #10
Boy you guys have the opposite understanding of "Triage" than I do.
What's the point of replacing the oil cooler O-ring but not replacing the water lines to and from the oil cooler?
This line of thinking could go on right up till a guy just goes and buys a new truck.
15777-62020 Oil Cooler Hose
15778-62030 Oil Cooler Hose
Old 02-10-2020, 07:43 PM #11
Real Name: Scott
Real Name: Scott
Oh yeah, I did these too. Good point
Old 02-10-2020, 08:32 PM #12
Novashards Novashards is offline
Novashards will become famous soon enough
Be prepared to replace the fan bracket as well. I wasn't planning on it when I did my timing belt but noticed it was toast when I took it off my 4runner with 175k miles. The bearing made noise and felt rough when rotated by hand.
Novashards is offline   Reply With QuoteReply With Quote
Old 02-10-2020, 09:51 PM #13
rideexileex's Avatar
rideexileex rideexileex is offline
rideexileex will become famous soon enough
Get the timing belt kit from Rock Auto - OEM parts without the Toyota markup. You'll need to buy the thermostat, but otherwise it has all the mandatory components.
2000 4Runner Sport - TRD&AEM SuperCharged
Solo Long Travel & KING 2.5 & bumps, 4th gen rear axle & KING 2.5 12's
F+R ARB's, 4.88 Yukon's, 295 KM3s
rideexileex is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 08:32 AM #14
Thanks for all the replies!
I think I'll come up with a list of a bunch of stuff, show my mechanic, and see what he has to say about labor. As I said at the beginning, it's certainly a rabbit hole!
Old 02-11-2020, 12:49 PM #15
So when comparing kits on EBay, I found this interesting:
aircabinman's kit:$300
grapebaiwan-us's kit: $175
For Toyota 3.4L V6 Engine Water Pump &Timing Belt Kit Tacoma Tundra 4Runner T100 | eBay
It seems like the exact same kit, with the same part numbers listed, but for $125 less. Am I missing something?
I would like to use aircabinman because of his reputation and because I have used his kit before with great success...but $125 in savings is quite large.
belt , pump , replaced , timing , water
The "real" durability of timing belt and water pump on 5VZFE? BamaDrewski 3rd gen T4Rs 60 10-24-2019 10:22 PM
Timing off due to belt "jumping" on V8. Possible? shayk 4th Gen T4Rs 5 01-17-2018 08:16 PM
WTB: TRD Supercharger "Premium Fuel Only" and belt diagram decals kigmob Want to Buy/Trade 0 01-19-2015 10:05 PM
"Auto Tech" Timing belt. Troubleshoot HELP LCPLHumiston 3rd gen T4Rs 11 06-01-2011 11:14 PM
Timing belt walkthrough on "TRUCKS"! fightman80 3rd gen T4Rs 5 04-21-2011 02:16 AM
