It started fine after the incident but then I had all of the fuse issues. I drove it for several days just fine and then pulled it in the garage to see about the continuous Dome fuse blowing. Then all of a sudden it wouldn't start. I'll go back through your list tomorrow and try your tests as far as getting it started. |
Is your fuse panel like the one in the schematic you post?
If so your not pulling 1a. The drawing showing the connectors on the back is rolled over to the right. In the upper left corner of the back would be the power relay. You need to detail exactly what you did to the vehicle after you pulled it into the garage. Step by step in detail. Your posts are so all over the place it took folks 2 pages to realize you drove the rig after you suspect your brother damaged it. And it seems you have 2 threads going for the same issue. This is what I gathered: #1: You had to jump your rig to get it to start one day. #2: You loaned your rig to your brother and he had to jump it as well. #3: You got your rig back and lots of fuses were blown including the 100A ALT fusible link. #4: You replaced the ALT link and other fuses and drove your rig for a few days. #5: At some point presumably after #3 the 15A (dome?) fuse would blow instantly. #6: You parked you rig in the garage and started pulling stuff apart. #7: After step #6 the vehicle will not start. #8: You have determined that pulling the upper left connector from the back of the fuse panel driver side dash stops the 15A (dome) fuse from blowing. Questions: At step 2 did your brother ever get the rig running? At step 3 what exact fuses were blown and in what fuse boxes? Can we assume these are the same fuses replaced in step 4? Step 5 seems cut and dry, but you’ve stated “15 amp fuses”, plural. How many and what fuses currently blow provided the mystery connector is connected? In step 6, please detail exactly what you did step by step. We can help you, but you need to be clear and detailed. Try not to include speculation and assumption. Just tell us exactly what you know and exactly what the symptoms are. Don’t leave any details out. Something you regard as unimportant could be very important. |
edit: How many pins, how many wires and what colors are those wires on the connector you are removing? -Charlie |
Wonder if his EFI fuse is good?
1 Attachment(s)
My thought is the integration relay could suffer from a reverse jump attempt. It's an expensive little beast, so let's see if we can figure a way to rule it out. |
Sent from my SM-J337V using Tapatalk |
I was incorrect before. @Brillo _67 sent me the full manual. I was actually pulling 1J to stop the Dome fuse from blowing. I was following your previous posts which included 2002 relay locations. |
1. Truck wouldn't start. Jumped it off. 2. Loaned to brother. Returned with dome fuse blown, door locks not working, and turn signals not working. Tried to swap 15a dome fuse out, but it blew. I had to go somewhere for a photography job so I drove it anyway. Drove fine. 3. Came home to try to figure this out. Drove it in the garage. I swapped fuses - the 10a AC, 10a RR HTR, 10a Head (RH), 10a Head (LH), all under the hood and the ACC (inside truck) after using a test light. Now only the 10a AC fuse lights up using a test light out of that cluster of 10a fuses in that middle section of fuses under the hood. They aren't blown, the test light just doesn't illuminate on either side. Tried swapping dome fuses but they kept blowing again. 4. I began pulling the connectors behind the fuse box inside the truck. Narrowed it down to one connector which I now know is the 1J. I used my test light poking inside each slot for the wires on that connector. On one of them on the left side I heard the relay click under the hood as the test light lit up. There was one on the right side that made the test light illuminate, but it was very dim. Not sure what that means. 5. Truck would crank but not start. 6. I swapped the 100 ALT fusible link because it appeared to be blown, but I couldn't really tell for sure due to lack of visibility through the plastic. Also because other T4R.org members had theirs blown while diagnosing similar issues. Just figured what the hell. I'll swap it. 7. Here we are. Brother got the rig running fine... So did I. It only stopped running after pulling into the garage to diagnose. I only had to swap the other fuses once. Sorry I meant fuse not fuses. Thanks for your help. |
Did you try starting the rig between steps 3 and 4?
I’m not sure what to make of your comment about the 10amp fuses no longer having power. I take that to mean they did have power at some point? Do you only own a test light, or do you have a volt meter? I’m assuming you’ve tried plugging connector 1j in and the rig still won’t start. That should indicate that in the work that took place in steps 3 and 4 is most likely the event that caused the vehicle to not start. It seems suspect that in step 3 something happened to cause power not to be properly distributed in the under hood relay box. I don’t have the 97 schematics. You should investigate the power distribution in the under hood fuse panel. I suspect you’ve blown one of the larger (30 amp) fuses or fusible links other than ALT. ALT shouldn’t do much other than carry current to/from the alternator. Be careful poking around with a test light. You might accidentally short something. |
Not sure why your 10A RR HTR fuse wouldn't have power unless somethings not connected under the relay box, or bad connection. https://www.toyota-4runner.org/membe...under-hood.jpg |
Look at the EFI fuse under the hood and all the fuses under the dash, 7.5A ignition, ECU, ect….
Under the dash relay box looks to have the important stuff on 1H. Given the starter turns over the AM1 and 2 fuses should be good. |
1J connector has: 1 - R-L, 10A GAUGE fuse power output (to alternator and other stuff) 2 - R, Headlight relay trigger signal (pulls to ground when switch is ON) 3 - L-W, Power in from HORN relay 4 - B, Power to horns from HORN relay 5 - empty 6 - G, Power from TAIL relay for integration relay and interior light power 7 - R-G, LH headlight low beam ground connection to headlight switch 8 - B-W, 7.5A IGN fuse power output 9 - R-G, RH headlight low beam ground connection to headlight switch 10- G-Y, Front RH turn signal power out 11- G-B, Front LH turn signal power out 12- L-Y, Power input from 15A DOME fuse to integration relay and other systems 13- empty I'd try removing the integration relay and plugging 1J back in to see what happens. The next thing is to go down the line with every component that is connected to the DOME fuse... -Charlie |
Search Engine Optimisation provided by
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
Advanced User Tagging (Lite) -
