Old 02-26-2020, 07:21 PM #16
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Interesting...….
I'm not 100% certain on where the 2 part numbers go. I've always bought the #30 and one time I did thinking that's what I needed and then the Tranny had a 2 hole one (#20).
In this old post Tim says #30 and his picture is of the 3 hole unit.
Transmission Strainer for A340F?
Lets us know what you find out. Maybe one day we'll have it figured out.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 10:13 AM #17
garn79's Avatar
garn79 garn79 is offline
Real Name: Jeff
garn79 is on a distinguished road
garn79's Avatar
Real Name: Jeff
disclosure: not the most mechanically inclined individual but quite handy in general...
I noticed in Tims Vid comments section someone asked about part# and he wisely told them to chk with dealer depending on his vehicle yr etc or something like that.
i cant imagine the tranny from my 99 being drastically different from even the 02, like others have said, they've used the part#----30 on their 99s so its prolly not any big issue.
regardless Toyota is doing this for some reason, heck maybe they have a massive surplus of part# ---20s lol.
garn79 is offline   Reply With QuoteReply With Quote
Old 02-27-2020, 02:57 PM #18
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Once in a while. You will notice Toyotas part number will change. They do this for several reasons. The part goes thru a revision upgrade. Price changes at times will on occasion change numbers.
Lots of times my local dealer will go through 3 to even 4 supercededs set of numbers before you get the current good part number.
I always suggest everyone verify part numbers before ordering. This is one of the reasons why the dealers ask for VINs to verify parts. Granted this is if your components match their build sheet. Naturally if engine, transmissions, axle housing are from different rigs. Always keep that donor VIN handy as Toyota can and will change things on the assembly lines.
The transmissions did have changes over 1996 through 2002. The valve body is an excellent example of a change. Now did the filter change any from 1996 through 2002. I honestly dont know. As a guess they be extremely close.
I just figured I would add this to this thread for other users in case they are unaware of this.
Maybe it will help someone down the road.
Old 02-27-2020, 03:41 PM #19
jimmyrecluse jimmyrecluse is offline
jimmyrecluse is on a distinguished road
Im ordering both and will replace with what I pull out
jimmyrecluse is offline   Reply With QuoteReply With Quote
Old 03-01-2020, 11:46 AM #20
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
I’m hoping to drain, drop the pan, replace filter, clean magnets, Clean surfaces and FIPG re-install, and then do a full fluid exchange 1qt at a time
I am just nervous to drop the pan now because I’ve got a filter ending in #60020 and I’m not sure if it’s the right one for a 2000 4x4 SR5. Would hate to drop the pan and have the wrong filter
Can anyone confirm they’ve used a 60020 filter (not a 60030) on a 4x4 trans?
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 03-02-2020, 11:54 AM #21
Finished the project with 60020 and 60030 in hand
What came out of my 99 4x4 was 60020
That is what shows up when I reference my VIN. I doubt the 60030 will hurt in the short run, if ever, but I used what came out of my 99.
60020
Old 08-16-2020, 05:46 PM #22
toverturf toverturf is offline
toverturf will become famous soon enough toverturf will become famous soon enough
I ordered the 60030 for my 99 4x4 Limited and took the pan off today and found out there's a 60020 there. Guess i'll be calling dealers around me to get the 60020 tomorrow.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
toverturf is offline   Reply With QuoteReply With Quote
filter , flush , oem , order , part#
Oil change, filter and parts needed? Ripper238 5th gen T4Rs 25 02-26-2022 08:53 PM
Filter kit part #'s Gstick 5th gen T4Rs 0 09-02-2019 03:40 PM
Auto Transmission filter bolt part number fourfive 3rd gen T4Rs 5 03-25-2016 05:47 PM
needed air filter door/cap/lid for 3rd gen air box. the great him Want to Buy/Trade 0 08-11-2011 07:32 PM
Secondary Air Filter Needed? dipNrip Maintenance/Detailing 1 04-08-2009 06:22 PM
