Old 02-12-2020, 08:03 AM #1
garn79's Avatar
garn79 garn79 is offline
Real Name: Jeff
garn79 is on a distinguished road
garn79's Avatar
Real Name: Jeff
Help needed Transmission Filter Part#
has anyone else had issues narrowing down this part#?
99 sr5 seems to have 2 or even 3 possible part numbers for this?
35330-60020
35330-60030
35330-30011
also we need to order gaskets separately it seems?
I have a new oem rad on order and figure I should do tran filter and flush at same time, appreciate any help.
UPDATE: Finally got around to this job & tranny flush.
35330-60020 was correct Strainer Part # (2 hole) for my rig again 99 SR5 3.4 4WD auto. @phattyduck @Dieselchessy @Brian @jimmyrecluse @WeakSauz
garn79 is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 10:10 AM #2
garn79's Avatar
Real Name: Jeff
garn79's Avatar
Real Name: Jeff
just noticing part # on Tims video, when on my tablet at home I didn't see his list. since most sites seem to approve his part# for mine I'm gonna use same one...
35330-60030
Old 02-12-2020, 10:25 AM #3
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
The auto-trans are all the same for all 3rd gen 4runners, I've personally used that part number in my '99 so that's an appropriate item.
As for the gasket, Toyota uses Form In Place Gasket (FPIG) for the transmission pan. There's a cork (I think, might be rubber) alternative out there through one of the auto-parts stores. Lots of people on here have reported no issues with them, but a few have said they had issues (weeping, pan deformation around the bolt holes, don't remember what else).
Personally I opted for FIPG before going in. In hindsight, I'm happy with that choice as I'll never drop the transmission pan again. The original filter at 200k miles looked fine, there was next to no schmoo on the magnets, and I've installed a MagnaFine inline filter that will be easier to change (and probably more effective as a filter). Personal choice.
Brian. is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 10:37 AM #4
garn79's Avatar
Real Name: Jeff
garn79's Avatar
Real Name: Jeff
thanks for reply, yes I agree ill probably go with FIPG also as I don't think ill ever drop pan again, fingers crossed!! and I will add an inline filter sometime soon, just not on current parts order...
did the filter gaskets come with the filter though?
Old 02-12-2020, 10:51 AM #5
Brian.'s Avatar
Brian.'s Avatar
It's one piece, ready to install out of the box ~ so, yes.
Old 02-12-2020, 11:16 AM #6
garn79's Avatar
Real Name: Jeff
garn79's Avatar
Real Name: Jeff
thanks Brian!
Old 02-12-2020, 02:04 PM #7
Watch out with that comment. The 2WD trans pan (and filter) is different than the 4WD pan. The main body of the transmission is the same generally year-for-year other than the output configuration (rear housing, output shaft, etc.)
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 02-12-2020, 02:36 PM #8
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
I agree..... That I know of there are 3 different filters. I've personally had the 3 hole one in hand and then realized the tranny used a 2 hole one mid job.
35330-35020 Strainer
3.4 LITER, 2WD
(2 cork lined holes and a deep sump)
35330-60030 Strainer
3.4 LITER, 4WD
(3 cork lined holes and a shallow sump)
2.7L Base model
35330-30011 Transmission Filter
Filter
4-RUNNER; 2WD; ALL
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 09:46 AM #9
garn79's Avatar
Real Name: Jeff
garn79's Avatar
Real Name: Jeff
perhaps I should've specified 3.4 4wd, got a lil lacksie daisy there...
thank you for input gents!
Old 02-13-2020, 02:20 PM #10
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy has a spectacular aura about Wedgy has a spectacular aura about
Wedgy's Avatar
When I did mine NAPA had 2 different filters listed for the 4WD so I bought both then took one back. I used to cork gasket that came with it and have had no leaks, they say to retorque it in a couple weeks as it may settle.
I did the flush, added an inline filter, and aux cooler as well. For ~$100 it's a cheap upgrade.
YouTube
YouTube
Wedgy is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 02:56 PM #11
jimmyrecluse jimmyrecluse is offline
jimmyrecluse is on a distinguished road
TOYOTA 35330-60030 Strainer Assy
TOYOTA 35178-30010 Gasket - drain plug
Genuine Toyota Fluid 00295-01281 Formed-in-Place Transmission Gasket
jimmyrecluse is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 04:23 PM #12
garn79's Avatar
Real Name: Jeff
garn79's Avatar
Real Name: Jeff
Thought I should post this.info.
So I ordered part # 35330-60030 online from Bommarito Toyota which forced me to enter VIN (normally optional) they wouldn't NOT process the order citing I needed part # 35330-60020. They called and.emailed me following day.
Not wanting to take only their word for it,.I want.to my local dealer, gave them my VIN and got same answer, 35330-60020
1999 SR5 4WD 3.4V6 AT. Truck is stock and unmolested. Haven't done.job yet but if I have any issues I'll post back here for anyone referencing in future.
Old 02-25-2020, 06:52 PM #13
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
Please let us know what you find out. I just got back from my local Toyota dealer and ALSO recieved the 60020 unit for my 2000 SR5 4x4.
They swore up and down it was correct based on my VIN despite me suggesting the 60030 unit.
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 08:24 PM #14
garn79's Avatar
Real Name: Jeff
garn79's Avatar
Real Name: Jeff
Yep I will for sure, legit probably won't be for a few wks still cold here and this is a driveway job for me and I'm using the Toyota FIPG so need warmer temps.
Knowing 2 dealers said same for me, one in U.S. one here in Cda and same for yourself, they're prolly right lol.
My local dealership here for anyone.interested quoted me 150.00 cdn, about 120.00 USD.
By ordering from U.S. I'll end up paying approx 56 cdn a savings of 115 cdn after taxes...
@jimmyrecluse @Dieselchessy @phattyduck @Brian.
Old 02-26-2020, 05:32 PM #15
I got mine here
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Will open it up this Sunday, let's cross our fingers
I also verified here
Strainer - Toyota (35330-60030) | Toyota Parts
Which also shows 35330-60020 as appropriate
Could 30 be an updated part?
If Tim used 30, im inclined to trust it
filter , flush , oem , order , part#
Oil change, filter and parts needed? Ripper238 5th gen T4Rs 25 02-26-2022 08:53 PM
Filter kit part #'s Gstick 5th gen T4Rs 0 09-02-2019 03:40 PM
Auto Transmission filter bolt part number fourfive 3rd gen T4Rs 5 03-25-2016 05:47 PM
needed air filter door/cap/lid for 3rd gen air box. the great him Want to Buy/Trade 0 08-11-2011 07:32 PM
Secondary Air Filter Needed? dipNrip Maintenance/Detailing 1 04-08-2009 06:22 PM
