Old 02-08-2020, 11:35 AM #1
jpgade13 jpgade13 is offline
jpgade13 is on a distinguished road
Trac, vsc Abs light on no code
My trac , vsc and abs lights keep coming on but its not throwing any codes on my 2002 sr5. I read it could mean low break fluid which it had so I added fluid the light went off but then came back on and sometimes they are on and sometimes they are not. Checked all the connectors on the master break cylinder they all appear to be good anyone deal with this before?
jpgade13 is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 04:36 PM #2
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
Could be the brake light switch failing, and that's not uncommon. Could also be a wheel sensor.
If the brake light switch isn't the issue you can do a zero point calibration, and count the number of blinks your abs and trac like have. There's a certain rhythm to the blinks, and when combining the amount of blinks you can have an idea of where the issue is. For instance, the abs will blink 2 times, pause, and 1 blink (same with the trac light). This would be ABS 21 vs trac 21, and can pin point the issue.
Mike
MStudt is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 01:44 PM #3
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
Do you have any engine codes? Certain engine codes will cause the ABS to be disabled and turn on the ABS/VSC/Trac lights. Check wiring, and the electrical connectors for corrosion. If you have a way to view ABS data drive the vehicle and see if any wheel speed readings are inaccurate or lazy. (3 wheels show speed at 1.5 mph and the 4th doesn't show speed until 8mph for instance) Bad front wheel bearings or rear axle bearings can also cause the ABS light to illuminate with out codes, but would usually set a code saying signal erratic or something along those lines.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 05:22 PM #4
Jidaran's Avatar
Jidaran Jidaran is offline
Jidaran will become famous soon enough
Jidaran's Avatar
I'm also working through an ABS / VSC / TRAC issue. I'm still figuring this out as I go, so take what I say with a grain of salt.
How are you reading the codes? On some systems (ultragauge, for example), ABS errors don't show up.
First, do what this guy does to get the codes.
YouTube
Both your ABS and VSC/TRAC will likely show codes, you have to check both.
The go to page 410 in the FSM to read the ABS codes and (413 for VSC.)
The chart doesn't spell it out, but I assume that the last two numbers of the DTC No. are the code you're getting from the truck. So if you're getting 3,4 code from the flashing light, that matches C0215 / 34: "Left rear wheel speed sensor signal malfunction"
2002 Limited 4Runner
2001 Jeep Cherokee
Jidaran is offline   Reply With QuoteReply With Quote
Old 02-12-2020, 11:46 PM #5
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
Im not sure if those lights came on when my axle bearing started leaking and getting to the brake sensor ?
plcfcng is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 12:54 AM #6
Jidaran's Avatar
Jidaran's Avatar
Another thing I came across researching this is that a lot of people recommend a zero point calibration for the yaw and deceleration sensors as a first step in troubleshooting. I've been too busy this week to do it, but it looks pretty easy.
01-02 4Runner How to Zero Point Calibrate your VSC system. - YotaTech Forums
Yaw is at the top of the page, decel about half way down.
2001 Jeep Cherokee
break , fluid , light , trac , vsc
Check engine light, VSC TRAC & TRAC OFF lights crainmain Maintenance/Detailing 120 11-22-2023 07:11 PM
Trac light on after alignment, code C120A? Canazes9 5th gen T4Rs 31 02-05-2023 11:04 AM
C1425 Code: ABS, Trac Lights solid, Multi-Terrain Light Flashing Lost27 5th gen T4Rs 3 01-11-2023 02:31 PM
06 4.7L - Error code P2440 and VSC trac light warning rikclark 4th Gen T4Rs 12 01-23-2017 07:17 PM
Check engine light vsc trac & trac off lights come on piptraderfx New Members 5 03-14-2014 07:47 AM
