Old 02-13-2020, 01:56 PM #1
RunningForNow RunningForNow is offline
RunningForNow is on a distinguished road
Low Idle After Battery Disconnect for 11 Days
I had disconnected the battery for about a week and a half because my wife drove my truck while I was on a long business trip, and one of the buttons on the key fob got stuck, and triggered the panic button in the back of the fob. Before she realized that was the cause, I told her to just disconnect the battery to stop the alarm from going off (I was at a job site and couldn't spend too much time troubleshooting).
When I came home last night, I took the truck out for a drive and run some errands, when I noticed the idle was pretty low, at about 500 rpm, sometimes lower, when in gear. However, after driving around for about 4 miles, the idle slowly went back to normal. I was wondering if this is the expected result after losing electrical power for a prolonged period of time, or should I be concerned? I know the idle rpm is controlled by the ECU, but I wanted to make sure.
Thanks for your help!
RunningForNow is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 03:13 PM #2
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
is it back to normal since then or low again on the next restart?
when my alt went out it was doing a similar thing on a test drive and turned out it was barely charging over the amount discharging and i was able to see that by testing the voltage at idle. not certain but maybe low battery couldve caused it and once recharged via alt it came back to normal.
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
Old 02-13-2020, 04:01 PM #3
It needs to relearn the adaptive parameters. Position of the IAC during different conditions is one of them.
It should get better.
Old 02-13-2020, 05:03 PM #4
It’s back to normal now. I just wanted to make sure that I don’t need to do anything during the re-learn process. I figured if it didn’t die at stop lights, then chances are things are ok.
Thanks for the information!
Old 02-13-2020, 06:24 PM #5
Even if it did die it would still relearn pretty quick. You may notice a cold start issue with temperature changes. Warmer or colder doesn’t matter. It seems like every 20 degrees is a new adaptive that needs relearned.
The fact that your default adaptive do not work anymore to me means your engine is old and tired, I’m sorry to put it that way......
Old 02-13-2020, 10:06 PM #6
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
I briefly had a 1st gen sequoia that would do that if the battery died, it would stall usually once and then run normally, my 4Runner doesn’t do that but I’ve never had the battery disconnected for more than a day or two and never had it die
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 12:04 PM #7
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
My wife's 05 Subaru Outback is can-bus and requires a lengthy procedure of key off/key on, run for a few minutes blah blah blah after a power interruption for idle calibration. If not performed, it will not idle properly. It never re-learns on its own.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 10-05-2021, 03:18 PM #8
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
I've got a low idle issue myself. I've seen as low as 450 on the UltraGauge at stop lights since returning from 3 days in the dirt and a 1000 mile road trip. Will see what it takes to fix and report back.....
Also - it's intermittent.
Old 10-05-2021, 06:48 PM #9
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Have this issue too (also intermittent) but the vehicle is driven every day. I cleaned the IAC Valve a couple of days ago which did help but it's still doing it a little bit.
2000 4Runner Limited 4x4 V6
back , battery , fob , idle , low
RPM at idle lower than usual after battery disconnect insaniak 4th Gen T4Rs 5 05-17-2016 10:21 AM
Another disconnect battery thread.. genest1417 4th Gen T4Rs 0 07-05-2013 06:54 PM
Battery Disconnect help NoMoreJeep 4th Gen T4Rs 2 10-06-2012 03:51 PM
Radio ID # after battery disconnect fjbj40 5th gen T4Rs 0 08-06-2012 11:51 AM
If I disconnect the battery... mtnet2000 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 08-24-2007 05:02 AM
