Old 02-15-2020, 04:02 PM #1
fixxor fixxor is offline
fixxor will become famous soon enough
Roof wiring location
Anyone know the best area to drill for routing wiring up to the roof? I'm going to use a Liquid-Tight Multi-Cord Grip (Mcmaster link). So I would need to make sure theres enough roof underneath for it. Thanks.
fixxor is offline   Reply With QuoteReply With Quote
Old 02-17-2020, 11:12 PM #2
bump
Old 02-18-2020, 01:42 AM #3
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
Do you have a roof rack; or the rails?
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 01:53 AM #4
I have a Prinsu rack.
Old 02-18-2020, 01:53 AM #5
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
I contemplated such a gland too for a ham radio coax cable to the roof rack mounted antenna. I decided it best to drill a hole in the rear hatch area and use a rivnut for an insulated cable clamp.
And into the interior through the taillight wiring hole...
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 03:46 AM #6
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
You'd never catch me drilling into my roof no matter how OK I am with permanent modifications. There's just no reason for it. You can fit 2-6 16ga wires on either side underneath the door seals on the A pillars and another 2-6 16ga through the rear hatch gap as posted above. Even if I couldn't fit all the wires I wanted into the space allocated (which happened on my Tacoma, running a large harness of 8 wires up to the rack.) the better way to go is to wrap all the wires nicely in a tech flex loom, and use stick-on zip tie anchors and flush ties to run the wires alongside the windshield. It may not be the most "clean" thing in the world, but on a heavily modified truck it's hardly a worry in my book.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 02-18-2020, 10:44 AM #7
Doc2012's Avatar
Doc2012's Avatar
Then use the stock holes under the rack rails.
Old 02-19-2020, 01:06 AM #8
Ok, that gave me a lot to think about. Thanks for the replies.
link , mcmaster , roof , underneath , wiring
Roof Rack Wiring Help ChrisK 5th gen T4Rs 19 05-18-2019 11:13 PM
Roof light wiring ry_034Runner 4th Gen T4Rs 3 06-06-2016 11:15 PM
need wiring diagram or location cennijimenez 4th Gen T4Rs 0 11-19-2008 03:11 PM
2003 4Runner Wiring Diagram - Permanent Host Location Mr Castulucci Engines / Suspension / Wheels / Tires / Audio / Accessories 10 09-26-2008 07:01 AM
Blower Motor Location and Wiring Diagram LarryJG Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-24-2007 08:30 PM
