Originally Posted by thennen
I think you're on it. I had the same exact symptom right after an oil change on my 2001 18 months ago. I had captured a grain-of-sand size piece of crud between the filter gasket and block. I found my leak by spraying degreaser over the the entire oily area and letting it dry, then starting the engine. Saw it instantly.
I had this happen twice on my 3rd gens. I actually went out and bought an oil filter wrench to tighten the filters as they seem tight and will leak only when the rig is running. I couldn't tighten then tight enough by hand when I changed oil filter types.
The OP may have to degrease their engine to find it if its leaking somewhere else. As this leak is pretty significant losing that much oil that quick.
Unless a half moon or gasket chunked off and its just running out elsewhere. But when the engines running. The oil will almost have to be streaming out.
This is all I can come up with.
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
