Old 02-15-2020, 07:31 PM #1
Mudeprived Mudeprived is offline
Mudeprived is on a distinguished road
5 quarts lost in 2 weeks
I am scratching my head here. I changed the oil two weeks back. I decided to check the oil today just cause I felt like it and nothing was on the dipstick. I went in and purchased two quarts and that barely registered on the dipstick. I had to pour in three more quarts to get it up close to full line.
I have had a valve cover leak for the past two years and it has lost about a quart per oil change. Is it possible to lose that much in two week's time? It has been really cold lately so I thought maybe the gasket shrinks and leaks more?
It drips but no more than is usually does. No smoke out of tailpipe. Coolant is good. Runs like you don't know it's running.
What say you?
1999 Limited
265/75/16 AT51's
Bilstein 4600
Mudeprived is offline   Reply With QuoteReply With Quote
Old 02-15-2020, 07:38 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
What say you?
I thinking your oil filter wasnt snug enough and your oil went into your skid plate. ;) if there is enough grime on your skid plate it could hold a few quarts of oil. There should be a puddle of oil where you park as well.
Old 02-15-2020, 07:46 PM #3
I have a combination of situations that are making it hard to diagnose. My truck is heavily undercoated with a gallon of fluid film so it looks like everything is leaking. My gravel driveway is soaked from all the rain and snow so you can't really see an oil leak at this time. And i have no skid plate.
I moved the truck over onto a patch of snow to see if it leaks.
1999 Limited
265/75/16 AT51's
Bilstein 4600
Old 02-15-2020, 08:09 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
See if you can get cardboard underneath it and it will drip on it. Gravel, limestone can hide the oil patch at times. :-(
Old 02-15-2020, 08:25 PM #5
Well just one drip on the snow the past two hours. Filter is snug.
1999 Limited
265/75/16 AT51's
Bilstein 4600
Old 02-16-2020, 01:14 PM #6
So it sat all night and appears to be dripping from rear drivers side of engine right where the steering rack bolts onto the crossmember. Hmm....
1999 Limited
265/75/16 AT51's
Bilstein 4600
Old 02-16-2020, 02:05 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yup. Look in at your oil filter when the engine is running and make sure your filter is tight and not leaking oil. As that's exactly where it will leak of the skid plate when the oil filter is loose.
Old 02-16-2020, 02:13 PM #8
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
This can happen if the gasket from old filter stuck to the housing and new filter was installed. Even though the filter is tight it will still leak.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 02:17 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
If it's not the oil filter. Pull you skid plates and verify your oil cooler isnt leaking as it's on the same side of the block closer to the rear of your engine.
Old 02-16-2020, 02:19 PM #10
Post #3 indicates he has no skids.
_________
Old 02-16-2020, 02:55 PM #11
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Visually inspect while running. Could be leaking from somewhere while under pressure.
Long ago my Aunt had a car with a similar problem. She sold it to her son cheap. He found the oil pressure sender leaked only when th he engine was running. $10 repaired it. His mom was pissed.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 03:00 PM #12
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Ah.. I missed that. I also didn't see if its a v6 or 4 cylinder as I am uncertain the 4 cylinder has a oil cooler. With no skids the oil leak would a lot easier to find. However, the wet FF etc definitely isn't helping the cause. Loosing 5 quarts in 2 weeks is a very significant oil leak.
Old 02-16-2020, 03:22 PM #13
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
I think you're on it. I had the same exact symptom right after an oil change on my 2001 18 months ago. I had captured a grain-of-sand size piece of crud between the filter gasket and block. I found my leak by spraying degreaser over the the entire oily area and letting it dry, then starting the engine. Saw it instantly.
thennen is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 04:01 PM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I had this happen twice on my 3rd gens. I actually went out and bought an oil filter wrench to tighten the filters as they seem tight and will leak only when the rig is running. I couldn't tighten then tight enough by hand when I changed oil filter types.
The OP may have to degrease their engine to find it if its leaking somewhere else. As this leak is pretty significant losing that much oil that quick.
Unless a half moon or gasket chunked off and its just running out elsewhere. But when the engines running. The oil will almost have to be streaming out.
This is all I can come up with.
Old 02-16-2020, 04:13 PM #15
If the engine was, in fact, five quarts low I'm pretty surprised that it was even able to make pressure. I mean, isn't capacity five and a half quarts?
The leak would have to be from a pressurised source such as the filter, oil cooler or pressure sending unit in order to lose that much. That or a missing drain plug. A leaking valve cover (or other) gasket wouldn't do that.
_________
dipstick , lost , oil , quarts , weeks
WS ATF-12 quarts, $80-NJ rjb75 For Sale: T4R Items 0 07-18-2017 09:31 AM
How many quarts of oil? SCRunner12 Classic T4Rs 2 09-15-2010 12:25 AM
How many quarts of oil? RangerJ Maintenance/Detailing 3 09-23-2009 10:12 PM
4.0 V6 - how many quarts of oil... fearghal Maintenance/Detailing 8 05-31-2007 09:52 AM
How many quarts of oil? Wah Maintenance/Detailing 2 03-23-2007 11:50 PM
